NO display on Westinghouse monitor
Unplugging the cord and connecting it back would not work because I did that before. THe plug is not bad because it worked on another LCD monitor.
  • junicr Jul 05, 2008
    I have a graphic card with 2 output. I have one LCD connected to it and it is fine. I connect the WEstinghouse to the second port. No graphics. I removed the first LCD and still no graphic on the Westinghouse. I tried another computer with a single VGA card and same result no graphics on the Westinghouse LCD.
  • 3,422 Answers
Do you have any external graphic card to which the LCD monitor is connected?Or is it connected directly to an inbuilt graphic card on the mother board?
Another thing does the CPU power up?
Posted on Jul 05, 2008
My monitor won't come out of sleep mode
Try unplugging the power cord from the monitor for 10 seconds and plugging it back in.
Jan 31, 2018 | Westinghouse Computers & Internet
How do I fix my hp w17e monitor that reads "VGA no signal"? I've tried unplugging my power cord and holding the on button for 30 seconds to a minute and plugging the power cord back in it still...
VGA no signal means "no signal" from the computer on the VGA (blue plug) cable... ...if the computer works check the cord for loose connection or get a new cord...if the computer is hooked to the digital cable (DVI/white plug)...set the signal source on the monitor to digital...
Feb 14, 2011 | HP w17e Monitor
Today, my monitor went to a multicolored candy-striped screen. I have to keep unplugging it (at the back of the monitor) until it works again. Every time I plug it back in, it's a different weird screen...
1) Replace the Monitor Cable, VGA is generally a Blue connection and DVI is a cream/white.
2) Make sure there aren't any bent pins in the end of the cables
3) Try the monitor on another working computer to verify it works or not
4) Replace the monitor.
If the monitor works on another computer then chances are that your computer has corrupted video drivers or a bad video card.
Dec 22, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
I have a Westinghouse monitor Model # LCM-19v SL the monitor keep turning off. Unplugging then replugging gets it working then it shorts out again. Can I replace the power Supply cord - Potrans ITE Power...
i also have a 19" westinghouse monitor the screen on mine goes black i just turn the monitor of then back on the problem is it's overheating and from what i understand it's caused by faulty or worn capacitors the ones that are bad are vented on top so it's easy to tell the bad ones. you can see what they look like on line!
Nov 18, 2010 | Westinghouse LCM-19v1 Monitor
Power cord issue? Black Screen with image issue?
The powere cord you are using is fine (the cord is made to handle the 10A load, you are only drawing 1.5A). The monitor uses switching mode power supply that can handle any voltage INPUT between 100v up to 240v. More likely to be bad caps in the power supply. See example of failed Westinghouse due to bad caps:
Mar 01, 2010 | Westinghouse LCM-19v5 Monitor
19' Westinghouse Monitor - Intermitent come on.
The problem is either with the power cord itself (especially if it is connected to the monitor such that it stays bent all the time), or the problem might be with the socket into which the power cord plugs in the monitor. The solder joints fixing the power socket to the circuit board & connecting the power terminals to the circuitry usually tend to get loose after some period of usage either due to mechanical stress while connecting/disconnecting the power cord to/from the socket, or due to high currents passing through these joints continuously.
My suggestion is to test with a power cord which is known to work without problems. If this did not fix the problem, then the monitor will need service (monitor needs to be disassembled to a degree that permits re-soldering of the power socket's terminals to the circuit board).
Jul 19, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
I have a Westinghouse LCM-22W2 LCD monitor. I believe my power board is bad. I want to either replace the power board or bad capcitors, if I can find them. I do not know how to take off the back cover,...
Have you gone through the user's guide? There are some sleep settings and automatic adjustments that this monitor makes, and other changes that users have inadvertently triggered that seem to be causing quite a bit of confusion these days. Make sure you haven't overlooked the Troubleshooting steps outlined there:
No Power
• Make sure the AC cord is plugged into the back of the LCD monitor.
• Make sure the AC power cord is securely connected to an AC outlet.
• Plug another electrical device (like a radio) to the power outlet to verify that the
outlet is supplying the proper voltage.
No Screen Image
• Make sure monitor is turned on.
• Make sure the video cable is securely connected to both the monitor and PC or
Audio/Video apparatus.
• Make sure you have selected the correct video input source
• Adjust the brightness and contrast levels.
“Out Of Range”
• Restart your computer and adjust your desktop resolution and refresh rate to 1680 x
1050 at 60 Hz.
Fuzzy Image
• Set desktop resolution on your PC to 1680 x 1050 at 60 Hz.
• Adjust Phase/Sharpness setting on the monitor
Cannot find 1680 x 1050 under screen resolution on my Display Properties
• You may need to download and install the latest video card driver for your PC.
Listed below are websites for major video card manufacturers:
Image Too Bright or Too Dark
• Adjust the brightness and contrast levels under the OSD menu.
• Perform Auto Adjust.
Distorted Image
• Reset the LCD monitor by performing the “Reset” function using the OSD.
• Remove extra accessories (such as a VGA extension cord).
Image is Not Centered (size is not scaled correctly)
• Adjust the horizontal and/or vertical position using the OSD.
• Check image size setting.
You can see an online version here:
I do not know how to remove the cover from that monitor. Here is a link to Westinghouse customer service technical support: or
Our service and support team is available:
Monday through Saturday
9 AM - 9 PM Eastern Time
1 (866) 287-5555
I hope this helps to resolve your issue.
Dec 07, 2008 | Westinghouse 22" Widescreen LCD Flat Panel...
I have a Westinghouse LCD monitor It powers on but there is no display.
Unplug all the cords from the back and then plug them back in after 30min.If this doesn't fix the issue,then try replacing the power supply cable with a new one.
Jul 05, 2008 | Computers & Internet
Biostar P4M80-M7A motherboard
You're board does not use an integrated graphics card.
Monitor does not have video display. There can only be four reasons why.
1. The monitor's video cable is not connected correctly at each end (Video card & Monitor) or cable is bad.
2. The monitor’s power cord is not plugged into a good power source or cable is bad.
3. The monitor may be bad.
4. * The AGP graphics card is either not seated correctly in its AGP slot, (remove/clean copper contacts with alcohol/allow to dry & reseat snuggly), or graphic's card is bad.
Monitor’s power cord can be switched with the PC's power cord.
The video cable & monitor can be swapped by borrowing from a friend.
(Just make sure their stuff is working first).
Never open the PC case without unplugging the power cord first.
Apr 16, 2008 | Biostar P4M800-M7A Motherboard
Westinghouse lcd monitor 19" - screen turns white
I have the same problem with my LCD tv... The DVI-D (white connector in the back) and the D-SUB (connector on main-board next to the DVI-D) work great for my computer. However, the antenna returns only a white screen no matter what I plug into with it using a coaxial cable. Judging by the modular configuration on the TV (1 main board with LCD monitor attached to it and the 2 computer inputs, and a smalled board on the back with the antenna, component video, S-video, mini-jack out, and composite video.) I think the smaller board which I believe is called a "NR Unit" is what has failed. I took off the back mini-panel of the TV off, which just slides off when you press down 2 tabs. And, I found the small board which is only held down by 5 small screws, and it pops right off. So, if you can find a NR board from westinghouse that works, it's a quick and easy (hopefully inexspensive) replacement. Hope this helped.
Oct 13, 2007 | Westinghouse LCM-19v1 Monitor
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
