When I record vocals into Sonar 5 I get a worbley, clippy sound, and it won't sync up with the next track I lay down. If I record into Sound Forge, or send it over to sound forge,from Sonar 5, it sounds fine. I am a musician, but not too saavy with computers. My ex left me with a burned out hard drive and I am starting from scratch again. Any suggestions would be appreciated.
DH
hmm, it could be something simple such as a faulty cable from mic to pc, it could be a faulty input if you are using a mixer, could be a faulty mic, it could even be a piece of software running in the background that is conflicting with sonar and causing this problem. This should be an easy problem for your "engineer" to sort out. as seeing it makes it 100 times easier to fault find. Thats part of being an engineer!
you need to make sure that you are using the M-Audio sync and not your sound card to sync voice. I guess you could use your sound card but make sure your instruments are using that sync too. most sound cards don't do well at recording audio in an environment that includes instruments being recorded at the same time.. If you mic has line in or instrument in, use it instead of sound card to record your instrument.
If what you are doing is singing along to a sound track then use the same sync for both.
Whichever works best for you is best. You can always lay down a scratch track for each like this and then lay down another track to replace whatever you didn't like using the scratch track as a guide. Erase the scratch tracks that you don't need before you mix down. I hope this helps.
You can use any mic you want but you have to go to the soundcard mixer and enable the source for recording from the recording properties. If you have a separate soundcard not the onboard one usually it will have it`s own mixer software so you open that up and set it to record from the microphone input if that`s where your mic is inserted. If you use the onboard sound card then go to control panel - sound and select the device you want and also set the recording source. In sonar you have to right click on the track in the left part of the screen. This brings up the properties for that track. The you select the sound card input and output for that audio track. That shoudl solve your problem. Of course you will get a much better result if you use a good mic plugged into a mixer or pre amp and send the source into the line in of your sound card and adjust the rest accordingly.
it's not supported on that or any earlier sony software that I know of. have you tried running the program twice (simultaniously) and playing on one while recording on the other then mixing the tracks together after??
Disagree with previous post. The GTrack is designed to record vocals and a mono insrtument at the same time. That's its main selling point. It should also allow monitoring of both the vocals and guitar alongside the playback from the computer. In your computer's Control Panel, go to sound preferences, select the usb microphone and click on advanced tab. It is likely yours is set up to record 1 channel at CD quality - this is how many ship for some reason. Set it to 2 Channels CD quality. In Sonar, set your track input as USB Left for the vocals, and USB Right for your guitar.
If you are recording from bar 1 at time 1.00 you might want to start recording one or two bars later. So try starting your song on bar three istead of bar 1
Most recording programs have a some way to keep tracks in sync. It is usually some type of begining and end marker. When you press record for the second track it starts the begining marker. What is the program your using?
Try this experiment: Record a click track on track #1. Record track #2 of the output of a monitor speaker playing track #1.
Now you have two click tracks which will probably not be cooincident (like they should be).
Measure the offset of the two tracks! You now know your latency exactly, and can compensate by adjusting settings or moving the vocal track back manually that many milliseconds!
