Question about GE Refrigerators
Howling sound from freezer fan section
My side by side fridge/freezer makes a loud haunting/howling sound when evap. fan runs.
  • jgalindo Sep 08, 2008
    My fridge started to "Howl" right after I had my flooring replaced under it. So I thought that might have contributed to the noise. It is VERY loud and actually can be heard from 30 feet way. How would I lube the fan? Just go through the back panel?
    My unit is about 4 years old and after reading all the posts on problems I might just invest in a new one!
  • 481 Answers
It is most likely the fan bushings that are making the noise. you can try to lube them with a light oil if you want to buy some time. but the fan motor will need to be replaced soon.
Posted on Jul 05, 2008
Whirlpool refrigerator model ED5FTGHKQ02
the closest model i could find was ED5FTGXKQ02 instead of ED5FTGHKQ02,could you check that and also what's not cooling both sides or just the fridge section,all it does is the evap coil gets cold in the freezer and the evap fan blows cold air from the freezer over to the fridge section,couple of the ings to check is open the freezer door,you should hear the fan blowing,if not you have a bad evap fan motor,if it is blowing from the bottom up remove the second bin or draw full of food and touch the back inside wall of freezer,if there's frost or like ice on the back panel you have a defrost problem,if everything is melting in both sides the compressor isn't running,could be a bad timer located in the fresh food section up front where the controls are or a bad start device located on the side of compressor,you might hear a clicking sound every couple of minutes.let me know what you find and check the model number,open the fridge door,look up on the right side wall near the ceiling or down near the bottom hinge on the door.thanks
Jul 07, 2012 | Whirlpool Refrigerators
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My Samsung rs 2556 SH side-by-side fridge is making a loud whirring noise, but when I open the fridge the noise comes to a sputtering stop. It starts again a few seconds after being closed. Noise sounds...
there is a evaporator defrosting problem; ice building-up. the evap fan is mounted right on top of the evap coil. this will get progressively worse; and, the fan will get completely jammed with ice; and stop altogether. your fridge will get warm and the freezer will not cool properly. you should get it looked at asap..
May 18, 2010 | Samsung RS2630WW Side by Side Refrigerator
The refrigerator section has quit working but the freezer still works. It starting making a loud noise just before it quit. I'm just wondering if it's worth having a repair call or just replace the fridge?
Sounds as if the evap fan has quit or a defrost problem. Either is worth the repair. If the fan is running you will hear it when you open the freezer door. If you don't hear it replace the evap fan. If you have a lot of frost build up on the back wall you have a defrost problem and the air cannot flow properly. Either is worth the repair.
Jan 31, 2010 | Refrigerators
My fridge is howling pretty loudly when ever it runs , the howling is coming from behind the ice maker turned the ic e maker off but unit st ill howls what s wrong
Hi, It sounds like the evaporator fan motor is going bad or there is frost building up and hitting the fan blade.
Unplug the refrigerator and remove the rear panel inside the freezer and locate the fan.
You can plug the refrigerator in and see if the fan is making the noise.
I hope this helps you. Please let me know if I can assist you further.
Jun 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
My GE side by side refridgerator makes a "howling" sound. Any ideas?
the problem you are having is in the main control board. ge has had a problem with this part causing the fan motor to go into high and low speed which causes the howling noise. unfortunately it is a costly fix, around $125 for the part. if you are savy to changing this part it is a matter of unplgging about 5 connections and replugging them. the new board has an extra set of pin that nothing connects to. READ the instuctions and it is a simple fix, saving about $50-60 in labor costs.
Sep 08, 2008 | GE GSH22SGRSS Side by Side Refrigerator
GE GSL25JFR Freezer fan noise.
It is very common for the fan inside the freezer to develop a loud noise as it runs. Its in an environment that is hard on them, cold, wet. Its a small and simple motor, and you are right in believing there will be more problem in the future, as the stator is probably touching the housing. It has a sleeve type bearing, and its probably worn a little causing the shaft to wobble. Eventually it will stop completely and the freezer will get warm.
Mar 07, 2008 | GE DSS25KGT Side by Side Refrigerator
GE Profile stainless Steel side by side
Can u pin down a little more like coming from freezer or back by compressior? Could be one of you fans.. one in freezer .. one by compressor in back
May 03, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
444 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
