Question about E-Machines eMachines Desktop PC
EMachine T3406 wont boot
I was on my computer browsing the internet as usual and without warning my screen just went blank. First I thought my video card went out so I shut down the computer and restarted it and now I dont even get a boot screen. I replaced the video card and even used the onboard video and still nothing. The computer turns on but i get nothing on the screen. Switched the monitor and still get nothing.
I've done research and found out that eMachines does this to alot of other people, and that the motherboard may have some bad capacitors. I checked all of them on the board and see no physical signs of them being bad. So I was wondering is it possible that if my bios chip went bad, will it cause my computer to blank out like that while im on it? Or I have some bad capacitors that isn't showing any physical damage?
Let me add that the power supply was replaced also with no luck.
  • 2 more comments
  • qTRUq Jul 05, 2008
    No there is no post beep. i took out everything 1 by 1 to see if any of them was the problem and yet i get the same thing. It powers up and the cpu fan is running at full speed as it normally does before idleling down again but it doesn't idle down, and the blue power light is on of course. No hard drive light is on either, but it does flicker right before it shuts off from me holding in the power button.
    No jumper by the cpu, but there is 1 by the battery for the bios. i resetted that too, even changed the battery and still no beeps or boot-ups. People are saying its a bad capacitor somewhere near the power supply connection to the motherboard. I see a few of them but they dont look burned out, eventho its still possible they could be bad.
    im actually testing them right now since i have some new ones sitting around lol
  • qTRUq Aug 14, 2008
    The CPU was fried, but showed no signs of it. I found out by getting the same model motherboard, then using the CPU from a friends computer to get my results. Not gonna replace the CPU since it was a Celeron. So now i have a ugly eMachines case, 2 working motherboards with no processors for them hahaa.
    Problem Solver:
  • 13 Answers
Is there a post beep when the pc is switched on. check the memory if it is a beep beep beep sound , also disconect the hard drive, dvd drive, floppy, and any usb devices and see if it boots up. if that fails it does seem like the mother board, also check the cpu fan has it stoped. also find out the power switch conector on the mother board, from the base unit switch to the mother board. also chech the power connector from the power supply to the mother board , on newer boards there are two that go to the mother board its self , a big one and a very small one .
Posted on Jul 05, 2008
  • 1 more comment
  • Storm Jetson Jul 05, 2008
    sounds like it is a mother board problem . is there a jumper near the cpu , normally resets the password feature , and some times resets the bios . might help normally situated near the battery and the cpu , need to be put on for about 2 seconds . then removed
    quite true it could be. would be very hard to resolder, you could try to read the out put with a multimeater, but sounds like a new mother board would be esier to refit in to the case
    cant think of wot else to tell you .. hope it helped ..
SOURCE:
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Somehow your MBR (Master Boot Record) likely got corrupted or possibly your hard drive went bad coincidentally.
Simply, you will start your computer from your Windows CD/DVD install disk, then when at a DOS prompt ( D:\ ) you will then type: FDISK /MBR (press enter).
Find your Operating System install DVD and start your computer with it, then follow instructions within this discussion:
Restore Windows XP MBR without Windows XP disc
Alternatively, review my search results for other instructions:
fdisk mbr windows xp Google Search
Nov 22, 2017 | Gateway MP8708 Notebook
EL1210...when starting up u see first messages but when finished u don't see main user windows to select user on screen and enter your window...its blank/dark..could it be the video card?
It could be... But check to see if updating the video card's drivers fixes it...
Restart your computer and keep hitting F8 once every second until the boot screen comes up. Then select - boot in safe mode with internet.
Your computer came with a NVIDIA GeForce 8200 video card so go here for the latest drivers and download them:
http://www.nvidia.com/Download/index.aspx?lang=en-us
Go into device manager and remove the old drivers for your graphics card.
Then install the new drivers.
May 15, 2012 | eMachines EL1210-09 PC Desktop
E640 REBOOT
Hi John,
I see you mentioned you update IE9 then you now get a blank screen...
If I may ask the blank screen showed up after the update or did it show up after restarting the computer?
If your getting a Blank screen when you boot into windows after the IE9 update, try rebooting then boot into Safemode.
Restart you computer then as soon as you see the Boot screen of you computer keep on Tapping f8 to get a list select safemode, then once it boots into safemode windows will load up in safemode on the issue and you can navigate arround to fix things that went wrong.
click on the Start Button on the lower left of the task bar then, click on Programs, select accessories then select system tools, look for system restore then select the option select a different restore point, on the window you may see a list of restore points hoping your system restore was turned on in the very beginning, once you have selected a restore point keep on clicking next then a warning will show just click next again then it will restart your computer.
System restore allows you to restore to a date where you had windows working fine without any problems so if you can get a restore point before updating IE9 then it is possible that you may be able to fix you windows back the way it was.
I hope that this will help,
michaelvincentc
Dec 22, 2011 | E-Machines W Computers & Internet
Monitor is black. How do I fix it?
if the monitor led indicator is amber and and the hard drive (usually red) indicator on computer is blinking red. that means your computer is working but onboard video is dead. if under warranty, bring it back for replacement or repair.
Sep 23, 2009 | E-Machines eMachines Monitor E15T4
Computer won't post, and I'm getting no screen
what i would do is remove all hardware connectors and cards from the motherboard and only leave the power supply and fan connections on. This will most likely allow you to boot the mother board. Remove the RAM as well. I'm aiming at the RAM is bad. But many things can have the same effect on the pc. If you have 2 sticks remove both and boot if you get lots of beeps it usually means it cant find the RAM or Video card. Attach 1 stick in and boot and will make a different beep code error. This prob means you dont have the video card put in the slot. It will not make a beep sound for video if u you onboard video.
May 23, 2009 | Dell Motherboard Dimension 4100 Intel 815...
Screen Resolution dropped since last boot - Fedora 10
try this link but always be carefull and watch what you click.
please keep me informed.
Feb 20, 2009 | eMachines T3406 PC Desktop
Machine won't boot to win xp
You have two choices:
1) Insert your e-machine system disk and boot from it. It should ask you if you want to install Windows or repair it. Choose R for repair. Then when you get the black screen with white writing, choose your windows installation (usually #1) and then press enter when prompted for a password. When you get the c: prompt, type chkdsk /r
This might fix it.
If not, then try the process again and don't choose "r" but continue through the screen when it asks you to accept the Microsoft agreement by pressing F8. Then on the next screen choose to repair the existing version of Windows. It will reinstall the system files and may actually fix your problem.
Feb 19, 2009 | eMachines T3406 PC Desktop
EMachine T1840 Will Not Boot
Well the first thing is first. Usually depends on the Operating system. If it is a later version of XP or even Vista. Try to boot it from the restore cd. They will usually tell you if your going to lose important information and ask you if you would like to back up the information. Based upon that you can move forward or not move forward.
Dec 03, 2008 | E-Machines -T1840-CELERON-1.8GHz,40GB...
Computer stopped working
try look your cord wire if connected is okay... or change your monitor
Feb 23, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
484 people viewed this question
Top E-Machines Computers & Internet Experts
Thomas F. Schneider
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
