Question about Toshiba Computers & Internet
Need to replace lcd screen on notebook - toshiba Satellite M60-CD4 and inverter. can a novice do this successfully providing they can follow step by step instruction? if so, how does one get hands on these instructions?
    Master:
  • 507 Answers
Normally I have turned to YouTube on the know how to break down and replace the insides of a machine try ur luck there
Posted on Apr 27, 2014
gdmisp
  • 66 Answers
SOURCE: Damaged usb port needs to
1-Shut down you pc .2-unplug the power cord.3-open the case .4-Find the usb wires trac them back to the board. 5-mark were the wires go with a marker.6-plug new usb port wires in.7-put the case back on pc.8-plug power cord in.9-turn on pc.10-plug your usb device in.
Posted on Jul 02, 2008
  • 233 Answers
SOURCE: internal battery needs to be replaced on my Dell Dimension 4600.
Unplug the computer. Remove the side cover. This is probably held on by two or three philips head screws on the back left edge of the unit. On the motherboard, look for a flat, round, shiny piece that resembles a nickel. This is the battery. There should be a small metal tab that holds it in place. Push on the tab and the battery should pop out. Note the orientation of the battery and replace with a new one in the same position.
Posted on Jan 18, 2009
  • 3940 Answers
SOURCE: Hi there, I have a toshiba
A couple things to try, 1 is boot the system in the safe mode (F8 menu at boot) and see if the LCD turns off there. You can also attach an external monitor and see if the external looses video too.
If the system looses video in the Safe mode and doesn't loose video with an external monitor, then the LCD backlight is likely failing
LCDs run about $100 to $150 on ebay
Posted on Jun 23, 2009
Daniel S
  • 4323 Answers
SOURCE: i have toshiba satellite LToshiba
Hi
To bypass the BIOS password for your laptop press and hold Left Shift key and check if password is bypassed. If it is not then you would need to reset it. To reset the BIOS password you would need to remove the RTC battery on the motherboard and try and restart the laptop 2-3 times. With the laptop turned offf follow these steps--
  • Open Memory Cover
  • Remove Memory
  • Remove Black plastic insulation
  • Locate & Short CMOS CLR1 for 15 Seconds
  • Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
    Daniel
    Posted on Sep 13, 2010
    Blank screen when powing on, won't start.
    Toshiba laptop LCD screen. It is to provide you with high quality laptop inverter replacement. The design of the Toshiba laptop LCD screen is 100% compatible with the Toshiba digital or model manufacturers.
    Product Features:
    1. Model: Toshiba laptop LCD screen
    2. Each test notebook computer LCD screen before shipment, 100% of the working conditions:
    3.100% new high quality replacement Toshiba laptop LCD screen
    4. Toshiba inverter can be used for the other models and Inverter part No
    5. Toshiba the notebook LCD InverterDefective backlight inverter can have the following symptoms:
    Screen image, but the power light stays in
    Dark display, but still readable
    Flashing on and off of the screen between 1/2 to several seconds
    The power indicator stays on, but no display and sound
    Screen images, but LCD TV still has sound
    Picture cycle on and off, as well as high-power LED lights
    In good working condition. The best match for your device. High-quality, durable, easy to install. http://www.lcdinverters.net/Laptop-Inverter/Toshiba/Toshiba.html
    Nov 01, 2012 | Toshiba Computers & Internet
    Toshiba m60-104 screen dark new screen new iverter
    Have you tried an external monitor?
    Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the display shows on the external monitor that proves your video card is ok and your lcd screen is the issue. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
    If is shows on the external monitor, then you would have to question if the new screen and lcd inverter is bad. Just because they are new don't mean they work. Are you sure you purchased the lcd screen and inverter that is for your model?
    May 23, 2012 | Toshiba Satellite M60 Notebook
    Toshiba laptop satellite A75 dim screen
    The used inverter maybe faulty. The inverter supplies high voltage to the CCFL lamp in the LCD screen, the CCFL lamp provides the backlight.
    LCD screens and Inverters are available from this WEB site.www.lcdparts.net
    Feb 15, 2012 | Toshiba Satellite A75-S226 Notebook
    Toshiba A 75
    www.lcdparts.net
    Feb 15, 2012 | Toshiba Satellite A75-S209 Notebook
    Toshiba satellite monitor is scrambled, how to fix?
    Check to see if the problem is the screen Inverter, or the graphics chipset, or the LCD screen.
    Use an external monitor as a test.
    If the screen of the external monitor shows a scrambled display you have a problem with the graphics chipset.
    If the screen of the external monitor does Not show a scrambled display, you have a problem with the screen Inverter, or the LCD screen.
    90 PERCENT of the time the fault is the screen Inverter.
    External Monitor;
    1) You can use a CRT monitor, (Looks like a small TV), as a VGA monitor,
    Or
    2) You can use a flat LCD screen monitor that has a VGA cable.
    A) Laptop OFF, and monitor OFF, attach the VGA cable from the External monitor, to the VGA port on the Toshiba Satellite A205 series Notebook PC.
    This is an example of a VGA cable, and it's connector, and a VGA connector on the laptop,
    http://en.wikipedia.org/wiki/VGA_connector
    B) Turn the monitor on. If it is a CRT style let it 'warm up'.
    Turn the laptop on.
    C) The display is supposed to automatically show up on the external monitor.
    If it does not, press, and hold down on the Fn key, and also press the F5 key.
    Still no?
    Holding the Fn key down, tap the F5 key again.
    Display good on external monitor? Problem lies with the screen Inverter, or the LCD screen.
    Either OR.
    Primer:
    An LCD screen does not produce light. It needs an additional light source.
    A Backlight is the additional light source.
    A Backlight is a CCFL.
    Cold Cathode Fluorescent Lamp.
    Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
    An Inverter (screen Inverter) is used to convert the electricity provided by the laptop, for the LCD screen, and Backlight.
    As previously stated, 90 PERCENT of the time the fault is the Inverter.
    Laptop open looking at the display assembly, the plastic thin frame in front of the LCD screen, and surrounds the LCD screen, is the Display Bezel. (Resembles a picture frame)
    The Display Bezel is removed to access the screen Inverter.
    The Inverter is right behind the Display Bezel, and located at the bottom area of the LCD screen.
    The Display Assembly has to be removed from the laptop, to remove the Display Bezel.
    Toshiba's term for the Display Bezel is Display Mask.
    The Toshiba Satellite A205-S5804 Notebook PC is one of the Satellite A205 series of Notebook PC's.
    This is a link to a free Service Manual for a the Satellite A205 series of Notebook PC's,
    http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
    Scroll down to the second Satellite heading. The one that begins with Satellite A10.
    Scroll across, and click on A200.
    After you click on A200 it may take as long as 30 seconds before the first page comes up.
    It may also take additional time for the file to fully download.
    At the top of the PDF file is the page number box. It is to the right of the Down Arrow.
    Go to Page 146.
    4.10 Display Assembly
    Page 151 shows how to remove the Display Mask.
    4.11 Display Mask
    Page 153 deals with the screen Inverter.
    4.12 FL Inverter Board
    Takes a really sensitive (Read fairly expensive) multimeter to test an Inverter.
    Due to the low price, and ease of replacing, the screen Inverter is replaced to test whether the old one is bad.
    Example of a screen Inverter (FL Inverter Board) for a Satellite A205-S5804 Notebook PC,
    http://www.batterysupport.com/toshiba-satellite-a205-s5804-inverter-p-216526.html
    Compare to the price of a replacement LCD screen,
    http://www.laptopscreen.com/English/model/Toshiba/SATELLITE~A205-S5804/
    To summarize so far;
    1) Display shows good on external monitor. Replace screen Inverter. Still the same problem? Replace the LCD screen.
    2) Display on external monitor is scrambled also?
    Fault lies with the graphics chipset.
    Chip and Chipset are slang terms for I.C.
    Integrated Circuit,
    http://en.wikipedia.org/wiki/Integrated_Circuit
    The graphics chipset is a GPU.
    Graphics Processing Unit,
    http://en.wikipedia.org/wiki/GPU
    The GPU for a Toshiba Satellite A205-S5804 Notebook PC (Part Number PSAF3U-0NR00V), is an Intel (Mobile) GL960 Express,
    http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_mobile_chipsets
    It is soldered directly to the motherboard, therefore it is Integrated Graphics.
    {Integrated Graphics is also known as OnBoard graphics.
    ON the motherBOARD.
    The GPU is soldered to the motherboard.
    In comparison if the GPU were soldered to a removable adapter card, it would be a graphics card, and Not integrated graphics }
    This means if the graphics chipset is found to be bad, motherboard replacement is the solution.
    { Disassembly guide,
    http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm }
    For additional questions please post in a Comment.
    Regards,
    joecoolvette
    Nov 05, 2011 | Toshiba Satellite A205-S5804 Notebook
    I need to replace the LCD screen on my Toshiba Satellite P305D-S8828. Can you provide step by step guide with photos or a video?
    Replacing LCD is not a big deal. Just follow these steps:-
    1. Unplug your laptop and remove the battery pack.
    2. Locate the rubber screw covers around your laptop screen. There are typically four, but some models may have more.
    3. Remove the screw covers. Take care not to lose any. They pop off.
    4. Place your fingers between the front bezel (the plastic piece around the LCD screen) and the screen. Gently work your way around the screen to remove the front bezel and expose the screen assembly.
    5. Remove the inverter from the screen assembly. It is held on by tape in most models. To disassemble the screen, you will need to either unscrew the screen from its metal holder, or just lift the screen out.
    6. Disconnect the wires. One wire goes to the backlight, while the other goes to the video card.
    7.Use exact serial no. LCD for exact replacement.
    8. Connect the video wire and the backlight wireand affix it using the tape that held the original in place.
    9. Put the screen back in place if you need to, and snap the front bezel back on.
    10. Screw the front bezel screws back in, and place the screw covers back in place.
    Hope they work for you. All the best
    Dec 09, 2010 | Toshiba Satellite P305D-S8828 Notebook PC
    I can barely see the screen, its very dark. Its a toshiba satellite m115 s1061
    Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
    The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
    Sep 05, 2010 | Toshiba Satellite M115-S1061 Notebook
    Multiple squiggly lines fill the LCD screen, after
    Sounds to me like your inverter has gone bad. Typically it's situated just below your LCD. To get to it you will have to take out the screws around the LCD bezel. It's a long, skinny circuit board that the LCD plugs into. You can usually find a replacement on Ebay. Just be sure that you're ordering the correct part, otherwise it may not fit or work properly. I've also had times when the entire LCD was going bad and the display was full of squiggly lines. It's hard to say which one is the cause. I would try replacing the inverter first. That part is usually much cheaper than the LCD is.
    Apr 10, 2010 | Toshiba Satellite M60 Notebook
    I have a Toshiba Satellite A135 and not sure if blacklight or something else
    Your backlight lamp, (Bulb), or the Inverter is bad.
    1.General instructions, and photos, for replacement of a typical laptop backlight,
    http://www.ccfldirect.com/lcdtutorial.html
    2.Instructions for completely disassembling a Toshiba Satellite A135 laptop. The reason I included this is twofold.
    A.It shows, and tells exactly, how to remove the LCD screen from your laptop.
    B.It shows you that the following information in link 3, on how to replace an Inverter in a Satellite A105, will work for your Satellite A135.
    http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-1.htm
    (At the bottom of this page you will see Page1:: Page2:: Page 3:: Page 4
    You are on Page 1. Just click on the white Page2, and so on, to continue)
    3.How to replace an Inverter in a Satellite A105,
    http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
    FIRST! Always remove all power! AC adapter, (Charger), and battery.
    Second! Observe anti-static guidelines!
    Third! This ain't tough! It just looks hard. Once you see how simple this is, I'm sure you'll agree with me.
    May 28, 2009 | Toshiba Satellite A135-S2276 Notebook
    A305-S6858 Laptop screen replacement
    please reference follow steps to disassemble LCD screen
    http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A305/remove-replace-LCD-screen-inverter-1.htm
    be careful all small cable like KB top cover LCD cable and inverter cable.
    hope help you fix it, please take a rating let me know huw much helped you thanks! keep in touch your question.
    May 21, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
    Computers & Internet Logo
    54 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
