Question about Panasonic 1250W 5.1-Channel Home Theater System with 5-Disc Upconvert DVD Player - Black
Unit power up
When i push the on/off button a error code pops up F61 what does this mean is it a major problem, or could i just take it to a simple repair shop please help me out here.
Thanks Alot
    Genius:
  • Panasonic Master
  • 1,689 Answers
If you want to have your system serviced, take it to the Sony authorised servce rep. This unit is mainly serviced at the board level. Independent service shops will not have the necessary setup and boards on hand to properly service your system.
It is very common that the power supply, and or the output stage fails in these systems.
Jerry G.
Posted on Jul 05, 2008
5 CD changer, model sa-ak600. What does code f61 indicate?
F61 means that the power amp has something wrong with it.
It could mean the IC501 has failed or that there is something wrong to the power supply to it.
The good news is the service manual is free online. You can get it by simply putting the model number into google and searching for the PDF of it.
Jan 02, 2016 | Panasonic Audio Players & Recorders
Panasonis SC HT70 Plays for about 1hour then comes up with F61 Fault code
This fault code means the speaker cables may have shorted, or the speakers are not the correct resistance (ohms) Are you using the speakers that came with the unit? If not, make sure the ohms rating of the speakers you are using are the same as the factory speakers. If they are the same, the unit may just be overheating, make sure it is in a well ventilated area, and dust-free.
Jul 16, 2008 | Panasonic Audio Players & Recorders
I have problem with my home cinema Panasonic home cinema SA-HT 870. I can't turn on. when i push the buton on/off i hear zzzzzzzzzzzzzzzzzzzzzz and i see on display EROR F61 and after 3 sec system is turn...
Hi
this error comes when you keep your device powered all the time.
Definition: power is constant to components always on so it heats up.
look for condensers that are popped up or seems to be
change it with same type and voltage
Description of Error Code. F61
State, Condition
When the power is turned on, the unit is automatically
turned off. The power does not turn on.
· Cause, Troubleshooting
Power circuit system failure and/or direct current flown to
speaker terminal
Good Luck
Nov 19, 2017 | Panasonic SC-HT740 System
F61 on panasonic SA-AK220
There are no error codes in the users manual. In this series of models panasonic has standardized error code meanings. F61 means a failure in the power out circuits. Your first option is to remove all your speakers and the associated wiring with the power off. Repower unit and see if error is still there. If not, you have a speaker or wiring problem. If still there, you have an internal failure requiring service.
May 19, 2012 | Panasonic Audio Players & Recorders
What does f61 mean?
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C.
If confirmed that the fan is working then I've suspect that your output I.C. is shorted.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 16, 2011 | Panasonic SC-AK18 CD Shelf System
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
F61 appears on my setero when i push play
my dear friend. this error message means something is broke on the audio power.
the unit give that message when the chipset find fix current or signal on any audio channel.
the most common means you have to change the audio amplifier unit. sorry but i know is the true.
Jun 15, 2009 | Panasonic SC-HT830V System
F61 error
The F61 error indicates that the unit is in "protect" mode. This means that an error condition was detected in the amp section and the unit has shutdown. This is usually caused by a defective amp chip. Expect a parts cost in the range of $60-$90.
Dan
Dec 05, 2008 | Panasonic SC-AK17 Shelf System
Panasonic Sa Ht 70 Problem F61
Hi, F61 usually means that the unit has some sort of DC error internally. One of the amplifiers could have failed. The HT70 is an older unit and dry joints around the voltage regulator and power amplifier is also very common. Also check that the fan is in good order.The unit will most likely have to be checked by a professional tech.
Jul 12, 2008 | Panasonic Home Theater System System
F61 error code
i have an error code coming up on my panasonic sa-ak640 it's saying error code f61 can you help me please
Apr 02, 2008 | Panasonic SC-AK640 Shelf System
Panasonic 1250W 5.1-Channel Home Theater System with 5-Disc Upconvert DVD Player - Black Logo
47 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
