Question about JVC Audio Players & Recorders
I just picked up a used QL-A2 Direct Drive turntable. It sounded fine when I got it. But now that I got it home, and hooked up to my receiver (I tried two receivers, same problem with both), the volume is suuuuper low. Any suggestions?
  • 1,512 Answers
Hi clausjones
You will need to have a Phono preamp connected in line if you are plugging it straight into a new millennium amp. the output of the turntable is about 100 times lower than a CD player, and need RIAA equalisation for it to sound any good. They don't include them anymore. Good thing is you can get an outboard preamp to do the job. Go here for units starting at $30
I am more than happy to answer any other questions you may have aboutit, please get back to me here, or use the ASK function to go straightto me :) If you are still unsure, have problems, or we need to look atthe situation more deeply, then before you give a rating for thisadvice, hit the ASK buttonThanks for using FixYa, If you consider the advice I have given you assound, a FixYa rating is a great reward for my efforts to help you.Cheers.
regardsrobotek
Posted on Jul 05, 2008
  • Colin Field Oct 28, 2010
    I was about to scrap this turntable. With your advice I recovered an old amp from the attic and now I'm playin old singles full wellie . Thanks. Colin
What is the stylus weight adjustment and tracking weight for jvc ql-a2 quartz auto return?
Balance the stylus, then calibrate the counterweight to 0. Then turn it counter clockwise to 2. For the antiskate knob, set to 2. Use the inner numbers for an elliptical stylus, use the outer numbers if you have spherical stylus. Hope that helps, feel free to ask about anything :)
Sep 05, 2014 | JVC Vintage Ql-a2 Quartz Auto Return...
I have a JVC QL-L20B turntable, hooked to receiver directly and plugged through cable, cannot get any sound except very faint from turntable itself, any suggestions.
SINCE I DON'T HAVE THE TURNTABLE IN FRONT OF ME AND NOT BEING FAMILIAR WITH THIS PARTICULAR TURNTABLE, I CAN GIVE AN EDUCATED GUESS. WITHOUT GETTING INTO THE CONFUSING ELECTRONIC SPECIFICS, ABOUT PREAMPS, ETC. REMOVE THE TURNTABLE PLATTER. UNDERNEATH IT, IF I'M CORRECT, THERE SHOULD BE A SLIDE SWITCH. IF THERE IS, SLIDE TO THE OTHER POSITION FROM WHERE IT IS CURRENTLY. PUT THE PLATTER BACK ON, TURN ON YOUR SYSTEM AND SEE IF THAT SOLVES YOUR PROBLEM. IF NOT, YOU MAY NEED TO BUY A PREAMP FOR YOUR TURNTABLE. HOPE THIS SUGGESTION HELPS
TIM
Jun 13, 2014 | JVC AL A158BK Turntable
I've hooked up speakers to my PT 2410 turntable and i get no sound. Is there something missing or am I doing it wrong.
Speakers direct to a turntable? Was that in the manual? I'd think some electronics with amplifiers and volume controls might be useful.
May 12, 2011 | Audio Players & Recorders
Does my turntable need a new cartridge? I have a Technics SL DD22 which hasn't been used in a while. I hooked it up to a Bose receiver which works fine (hooked up an i pod to it before) & it plays...
The output from any regular turntable is far too low for most amplifiers to handle. You need to either run the output through a pre-amplifier first to bring the signal up to line output levels suitable for most recording devices and amplifiers or run it into an integrated amplifier which includes the pre-amp stage.
If your Bose receiver specifically includes a turntable input then it has a pre-amp built in, but as so few folks use turntables any more very few devices have the correct input. Pre-amps are still easy to obtain and can be very cheap, but cheap ones produce a noisy and unpleasant output which is magnified by the amplifier. If ever there's a choice to be made, spend the money on the pre-amp and go budget on the main amp.
I hope that I've saved you wasting money on something you didn't need. Please take a moment to rate my free answer.
Sep 24, 2010 | American Audio Vinyl 101 Direct-Drive...
Looking for manual for a JVC QL-A2 turntable
www.vintageaudiomanuals.com
if you email this company on there site there let you no avilability of it but i think itll cost you mate
Aug 08, 2009 | JVC Audio Players & Recorders
Table does no rotate
If it is belt-driven the belt may be broken or fallen off.  Lift the turntable to check underneath.  There may be a spring clip near the center of the turntable that you have to remove to lift it.
May 18, 2009 | Audio Players & Recorders
Low to poor sound out of turntable
this problem is almost 1 of two things
A) the new stylus is not seated perfectly into the body of the cartridge. if you suspect this, email pics to turntableneedles (the at sign) comcast.net before pushing too hard on anything.
B) if the setup changed you might need a preamp to boost the signal if it is not hooked up to the phono input on the receiver.
Apr 13, 2009 | Audio Players & Recorders
Technics SD-L3 TURNTABLE
Does your receiver have a dedicated phono input? If not you'll need to use a preamp between the turntable and receiver. Your other turntable may have a preamp built in and the Technics not.
If this does not help, please post the brand and model of both your receiver and your other turntable.
Oct 14, 2008 | Technics SL-1210 Turntable
85 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
