Question about Car Audio & Video
Unlock radio caset Kia 98 sportage - Car Audio & Video
I need the code of radio caset Kia
Posted on Apr 15, 2009
My 98 kia sportage wont start
It sounds like the key sensor in the drivers door is malfunctioning, the drivers door is the only door that can enable/disable the alarm, if you try to unlock any of the others it will trigger the alarm.
Sometimes with my Kia I have to (without opening the door), cycle lock and unlock several times before the alarm is disarmed.
Have you tried this is succession, with all the doors locked:-
put the key in the drivers door, turn to lock and then to unlock, the alarm should disarm.
Also, if any of the door locks are jammed, the alarm will still activate when you try to unlock the drivers door.
If that fails and the alarm still activates, then it's a problem with the key sensor in the door.
Mar 30, 2014 | 1998 Kia Sportage
2005 Sportage - Doors lock/unlock while stopped at light, radio cuts out,
replace IC of car door lock... this is a little black box inside the steering wheel cover
Jun 12, 2013 | Kia Cars & Trucks
Service Manual 98 Kia Sportage 2.0 double overhead cam motor 4 cyl
i broked the conector of cam sensor kia sportage 98 and the problem is every cable of both sides are diferent color. and i need to know where is every one.
Sep 25, 2010 | Kia Sportage Cars & Trucks
I have a 2001 Kia Sportage. When I turn on the
There is usually a fuse in the radio itself,or in the radio harness .Also when you check the fuses there are two in the car-one for the always on power and one for the ignition power to the radio.Check the operaters manual to see which ones you need to check.If the radio need to come out you should be able to find the anchor nut under the radio knobs,they just pull off.Good luck.
Oct 18, 2009 | 2001 Kia Sportage
I need to know what these 2 codes mean that i got for my 98 kia sportage: p1700, p1300. And do some codes transfer to different cars the same because its hard to find any codes that are just kia.
Please let us know the exact error code.. there is no P1700 and P1300 are not an error codes on 90 kia sportage.
Thanks,
Jeep Brainy
Aug 13, 2009 | 1998 Kia Sportage
My 98 kia sportage wont crank.
http://www.kiatechinfo.com/index.asp
Good source for Kia its free to register NO STRINGS
May 17, 2009 | 1998 Kia Sportage
Radio unlock code.
I got mine from Kia Customer service 1-800-333-4542. They gave me the right code which actually worked. If the "Hold" sign comes up and locks your radio, you might need to leave the radio on for more than an hour for the "code" sign to re-appear.
Apr 06, 2009 | 1997 Kia Sportage
Missfire on #4 cylinder for 1998 kia sportage
had the same problem....broken spark plug. try replacing your plugs.
Nov 29, 2008 | 1998 Kia Sportage
I want to know the code for my radio in my kia sportage
try 1111 if that does not work radio needs to removed for dealer to use reference number on back so they can get code from kia
talk to dealer first.
Aug 24, 2008 | 2002 Kia Sportage
98 kia sportage
The radiator thermostat may be stuck. I've had that before. Just about any auto part store should have an employee that can help if you need it. Its a quick and easy fix/replacement. You'll definitely want to check your radiator coolant level as well.
Jul 11, 2008 | 1998 Kia Sportage
Car Audio & Video Logo
106 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
