Question about Toshiba 53H71 53 in. Rear Projection Television
Suddenly double/triple images, bowed red at the bottom
I have a Toshiba 53H71 rear projection TV which has been great, but suddenly it has double/triple images and bowed red at the bottom. I've read something about changing IC's, but can someone confirm that? If so, what should I do?
  • Nmagnuson Jul 05, 2008
    I just want to make sure, since the link that I was given was for a Pioneer TV, and mine is a Toshiba 53H71. Also, I have bowed RED at the bottom, and the example wasn't red.
  • Toshiba Master
  • 6,487 Answers
Check this link hope thtis is the one that you're looking for http://www.scribd.com/doc/3110569/Toshiba-TV-13A21C-Service-Manual
Hope that helps..........
Posted on Jul 05, 2008
    Genius:
  • 1,030 Answers
Yes there is a possibility that the convergence ic or stk's have gone bad. they are usally the big ic on the beg metal head sinks....if you have any exzperience soldering you may be able to replace them....if not dont try it.. there are 2 that cost about 20 dollars apeaice a repair shop may charge 150 (or least ours do)... once you replace them you also have to go into service mode an make adjustments.,,something a non tech should not attempt
    President:
  • 2,712 Answers
Yes, the convergence IC's need to be replaced. If you are not experienced in TV repair, I would recommend getting a qualified repair man to do it for you.
Here is a link with instructions on how to do this, if you feel adventurous:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Should you find this info useful, kindly take a moment to "Accept" it. Thanks.
  • Swilin Sampson
    Swilin Sampson Jul 05, 2008
    The procedure is similar. Only the actual location of the STK's on the board will vary.
My Toshiba 53H71 rear projection TV's picture looks like double vision with a heavy tint outline how can I fix this???
Double vision/ picture problem occurs due to failure of convergence output ICs in rear projection tv and it is common problem of projection tvs.
Please replace convergence output ICs in tv to solve the issue, there is convergence repair kit available for $70 on This Site that has required parts/ ICs, instructions about how to replace ICs etc for a handy person.
Hope these info will help.
Thanks.
Jun 11, 2011 | Toshiba 53H71 53 in. Rear Projection...
Double image and colour
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 07, 2009 | Sony KP-53HS30 53" Rear Projection...
Toshiba 53H71
Either the convergence or cracked sautering. Just had my tv repaired but now I have a double blur in the upper left corner.
Jul 20, 2009 | Toshiba 53H71 53 in. Rear Projection...
Toshiba back projetion TV convergence problem
You probably have a convergence IC going bad. This is a very common problem. They run hot and wear out over time.
Jun 28, 2009 | Toshiba 53H71 53 in. Rear Projection...
Samsung SP42W4PHX convergance problem
Hi
The resistors are 39 ohms, metal oxide.
Usually both the stk392-010 ic`s (on heatsinks )
want swapping. You can get them off ebay..
Dave H.
Jan 17, 2009 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 53h71
Convergence amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
Feb 21, 2008 | Toshiba 53H71 53 in. Rear Projection...
Colors and Images
sounds like loose connections on the convergance amps ic's
Dec 25, 2007 | Toshiba 65HX81 65" Rear Projection...
The words on the screen is doubled or trippled.
Go to the picture control menu and turn the color to minumum so that you are watching a black & white picture. Do this to determine if the color offset affects the overall screen or just the lower corner. If the center is off, go to the convergence adjustment menu and align the red and blue onto the green as described in the owners manual. Some models also allow you to align the outer edges as well. If the bottom is still bad you may have a problem in the convergence circuit. If the outlines are not seriously bowed or distorted a minor convergence toutchup by a qualified technician should correct the problem, otherwise parts are involved and the repair is considered major.
Nov 21, 2007 | Toshiba 53H71 53 in. Rear Projection...
Help I have a 3 D image
You need to replace 2 ships stk 392-150 any question I'll be glad to help you 401 6170008 my name is George
Jan 19, 2007 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
74 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
