Question about Yamaha DRX-2 DVD Recorder
Power supply drx-2 total damaged, tea 1507 burned and fet p3nc60 shorted 0 ohm also r3318 (47 ohm) defective.
My solution : replaced ic, fet and also optocoupler and resistor.
But no good result.
5 Vreg is to lo (1.5 V) and 12 Vstby = 10 V. There is also no display and the Fet is going very warm. Only the rec. button on front blinks (weak).
Most all components in live part are checked all good. Secundary fuses and Fet 7302 are all good.
Do you still have any repair idea ?
with kind regards,
Manuel Kessels
e.kessels@planet.nl
  • 6 Answers
SOURCE: YAMAHA CRW8424 gives Track following error..
PROBLEM DEFINITION: Basically, it is a hardware error that occurs when a drive is not capable of following a data track on a CD-R or CDRW or on the other hand, poor power flow may cause the problem SOLUTION: 1. Try use another disc, a disc with a different band. 2. If one doesn't work, you may have to open your system and use a different power connector, making sure no other devices are using the power connector in the same strand. 3. Lastly, if neither the above doesn't work, you may have to send your drive in for servicing as the head may be dirty or misaligned.
Posted on Aug 06, 2007
  • 4 Answers
SOURCE: Yamaha RX-V995 no power no audio [dead]
sounds like a short in the cpu of the unit
Posted on Mar 07, 2008
  • 319 Answers
SOURCE: no sound
Make sure speakers are hooked to proper connectors. Also check speaker switch "A"/ "B"/ "A+B" is positioned to correct speakers.
Also make sure mute switch is off
Posted on Apr 29, 2008
satavlad
  • 405 Answers
SOURCE: htr-5790: after power on, returns to standby, no
After you force it to turn on, what do you see on display? (PRT8**, DC**, etc.)
Posted on Nov 10, 2009
  • 2427 Answers
SOURCE: My Yamaha RX-497 bought 3
damaged yes... fix yes,, well hopefully,, ok frstly it seems you blew an output IC or a filter.. now i dont have a diagram and basically one isnt needed,, you will need some screw drivers, a soldering iron and some solder..and a multimeter if you have one..
  1. open up the unt (unplug it first)
  2. look at where the speaker's connect you will notice it leads to 4 - 8 huge IC's on heat sinks.. close to the heat sinks are a few capacitors (filters) look at them and pray you find one with an oily surface.. If so remove it by soldering it, take it to the shop and get a new one to solder in place.. and then test the system to make sure it works..
  3. IF not a filter then plug in and turn on the unit.. touch every one of the 4 -8 ic's to see which get HOT!!!!!! very hot,, that one is blown (actually will be more than one) again unsolder them,, get replacements and reassemble..
  4. turn on and enjoy!!..
Posted on Sep 17, 2010
Xtronie x20qa12074802 colour television burns fuses when i power it
that was mean has bad major component either in the power supply board or in the main board.check first shorted bridge type diode and regulator ic and FET transistor in the power supply board if getting shorted.
Sep 07, 2012 | Televison & Video
Tip
CHIPLEVEL SERVICE OF MOTHERBOARD
I AM A CHIPLEVEL SERVICE ENGINNER I DO CHIPLEVELSERVICING OF ALL MOTHERBOARD
FOR EXAMPLE THE SMPS FAN JUST INSTALIZING MEANS A DEAD SHORTING POWER SUPPLY SECTION OF MOTHERBOARD IF IT HAPPENS REMOVE THE PROCESSOR CHECK ALL THE POWER CONNECTION LINES FROM THE SMPS CONNECTION WITH ANY OF THE RESPECT OF GROUND IF ANY LINE IS FOUND SHORT CHECK WHICH COMPONENT IS PRIMERLY CONNECTED TO THE LINE AND REPLACE THEM
CONNECT THE PROCESSOR WITH ITS HEATSINK AND CHECK THE SYSTEM WETHER THE SWITCHING IS OK IF NOT CHECK THE POWER IC,RELEATED CHIP RESISTORS AND CAPCITORS,FET,TRACK OPEN
IF THE FET IS DAMAGED IT WILL SHOW INTIALL SWITCHING AT GATES IF IC IS DAMAGED IT WONT SHOW ANY SWITCHING
on Sep 11, 2010 | Computers & Internet
No power
Check the Mosfets on the P0981 pcb this is the pcb that has the inputs and such.. not the power Supply board. Fets are mounted to the Heatsink under this pcb, but you can get to the pins as they come up thru the pcb . T11, T7, T4, T1 These have 3 terminals Check for shorts or reading the differ from one to the next.. These are Fets so From G to D and G to S shoudl be open. D to S will read some value as there is a Diode across it.. Also If these are bad the Gate Driver IC IC 11 or IC 3 might be the cause. Mine had two shorted FETS and the IC that drove them was bad. IC is IRS20955 Found some tech reports that show this ic was updated to IRS20957 due to issues.. So I updated both mine and replaced all 4 FETS. Good luck .
Aug 21, 2012 | Behringer EUROLIVE B1800D PRO Active 18 In...
Can,t get it to turn on.
Does the red light come on? does it go green but no picture? Here are few possible solutions:
If you have no red light and you have a Megmeet MLT386 power supply, check these parts:
1) Swollen caps on the secondary circuit.
2) Blown fuse F1 (5A/250V) this is caused by a shorted FET at QA1 (20N60), you may also find that SMT cap CX23 is burned up (.001uf) which is in parallel with diode DA2 which may be damaged/shorted, replace these components.
If the power LED goes from red to green when powered up but no picture, then it might be lost +24VDC from the power supply:
3)Check fuse F2 (3.15A/250V, I put a 5A in), if it is blown, replace FET at QA2A (9N50C), replace QA2 as well (9N50C). Check SMT resistors at R233,R234,R235,R236 (.47 ohm). If open, replace with .1 ohm 1W or 2W resistor (easier to source). Also replace SMT transistor QF1 (2X4 or 2N4401 NPN transistor). And replace diodes at DS2 and DS1 (HER207), DS2 was shorted, DS1 was ok but I replaced it anyway.
I dont know as much about the Megmeet MLT169A, but it has similar problems and similar components.
4) I had to replace all of the capacitors in the secondary circuit (there are six in a 3x3 row marked EC9 (1000uf35V),EC10(1000uf35V),EC14(470uf35V) and EC18,EC19,EC20 (all 1000uf35V).
Sep 05, 2009 | Akai LCT3201TD 32 in. LCD Television
T.v. won't turn on
The following parts can be purchased at digikey.com or mouser.com web site. I am also posting all of the things I have found so far with these TVs.
1) Swollen caps on the secondary circuit (may cause the red light blink problem, but also see below).
OK for the Megmeet MLT169A with red flashing LED when turned on I found that IC7 was bad. This is an SMT component on the solder side of the power supply. It is a 4407P (P channel 30V MOSFET). For testing purposes, we jumped across it to feed +5V to the TV permenently instead of allowing +5V to go into standby.
Aug 19, 2009 | Akai LCT3785TA 37 in. LCD HDTV
TV won't turn onthe red light just blinks when I push the power button.
I think this might be bad/swollen capacitors, or something odd in the +5VDC circuits of the power supply, but I am posting all of the things I have found so far with these TVs.
1) Swollen caps on the secondary circuit (may cause the red light blink problem).
Aug 10, 2009 | Akai LCT3201TD 32 in. LCD Television
P4M800PRO-M478 doesn't function
I had told you I changed one Fet that positively had burned. I placed a IRFZ48N, a more powerfull transistor, unecessary of couse but the only I had in my old things. But the board doesn't function and so I searched for more damages and yesterday I found two resistances of 0 ohms opened. I changed its by a jumper and power on the MB. Today it is running with a Pentium 4 2Ghz, the OS Windows XP SP2.
Jul 09, 2008 | EliteGroup P4M800PRO-M478 Motherboard
Sony TV KV-XR29M31 with supply blow-up. Fet Q608 and Q607 short circuit taking horizontal output Q and R642 .1 ohm. Is it caused by dried-out caps and does it take IC 602? Appreciate any help. Thanks.
Replace the FETs with ones from Sony distributor. Do not substitute. Replace all of the small blue disc caps in the area. These can short causing the power supply to fry. In your case, the HOT probably was the initial problem, not the supply.
Dan
May 01, 2008 | Televison & Video
The power supply don't operates - INFOCUS X1
Usually the projector bulb, try to replace it first but I will not recommend you to do so but it is your decision.
Nov 21, 2007 | InFocus POWER SUPPLY CORD Multimedia...
250/1 powers on but no output
If the amp is not going into protect, the power supply FETs have probably failed. In the corner of the amp near the toriodal transformer, there are 4 FETs against the heatsink. When these fail, the 47 ohm resistors at the base of the transistors often fail. If the resistors are dark, it generally means the FETs have failed. If you disconnect the amp from power and measure the resistance from leg 1 to leg 2 of the power supply FETs, a reading of near 0 ohms indicates the FETs have failed.
Nov 06, 2007 | Jl Audio 250/1 Car Audio Amplifier
Yamaha DRX-2 DVD Recorder Logo
181 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
