Question about Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television
GHOSTING THE ISSUE OF GHOSTING.....OUTLINE OF IMAGE IS SLIGHTLY OFFSET AND GHOSTING ADJUSTMENT DOES NOT FIX I have the same ghosting problem. The lamp was recently replaced and the problem has gotten worse since. Anybody know how to fix this?
  • 84 Answers
Go to image revison in menu and try. auto, 0, 1, 2, or 3 for best picture
Posted on Jul 05, 2008
Ghosting image
Ghosting is caused by wires touching. The signal gets cross-talk. Separate the wires in back, and it is an instant fix, easy.
Apr 20, 2014 | Panasonic VIERA Televison & Video
Sony bravia 52 kdl xbr ghosting
Michael, does the ghosting go away of you tap the set? Or if you turn off the set and let it cool off and turn it back on, is the ghosting still here? One of the most common causes of ghosting or double image problem is due to a defective LCD panel tab. Sony's are known for this problem. I would recommend getting a diagnoses done on the set to be sure. If it turns out to be a LCD tab problem, the only true fix is to replace the panel.
Nov 24, 2012 | Sony BRAVIA Televison & Video
My printer is leaving faint marks of other words down the side of the page...any way to fix that?
Yes, It sounds like a ghosting issue. Several components can cause a ghosting issue. The distance between the first occurance(the one on purpose) and the second occurance(ghost image) can determine the part of the machine causing the image problem
56.6mm - Fuser
54.5mm - Transfer Belt
75.4mm - Drum unit (1 of toner carts)
Dec 11, 2009 | HP Color LaserJet 2600n Printer
Showing to of the same thing and colors
ghosting or convergance issue is what u have. if the image is in diff colors then deff a convergence issue. however, if the image isthe same color or shaded from the original then this is ghosting. this may be corrected through the menu settings(sinc settings).
Jan 15, 2009 | Toshiba TLP-380, TLP-780, TLP-781UF...
Konica 1015 copier with image ghosting problem
I hope the correct toner is in there.
It could be that the cleaning blade on the drum isn't working or the charge isn't working right.
Sep 17, 2008 | Office Equipment & Supplies
Blue shadow or ghosting on screen
  1. First try Magic Focus
  2. if this will not fix problem
  3. then you have a convergence problem
  4. You will need the Converg. Kit
  5. X480295 part number
Nov 12, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Ghosting
Get firmware upgraded.
Oct 30, 2007 | NEC VT465 Multimedia Projector
Ghosting image after 3 years of perfect operation
ghosting is a memory problem, the monitor has a memory chip this helps with the video rendering to display the image, the chip can over time become damaged like any other memory chip, its its read use delete type but some times it can take longer to delete this then gives you the ghost shadow. it can sometimes be the software glitching, but there is no way to fix the firm wear on the monitor as the chip is pre programed before the monitor is assembled.
Aug 11, 2017 | Hyundai ImageQuest Q995 19" CRT Monitor
Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television Logo
450 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
