Question about Dell Inspiron 6400 Notebook
Laptop doesn't normally start
I have a dell laptop which i cannot log in using my original profile. It creates a temporary profile to use instead. And when i'm in using the temporary profile, all my files that were created and saved were missing.
Pls. advise
    Genius:
  • 2,028 Answers
This sounds like an operating system glitch. Enter safe mode at start up by pressing F8. Once in safe mode, log on as administrator and do a system restore to a point that you recall it allowing you to log onto your profile. This should cure it, if not, let me know and we'll try something else.
Posted on Jul 07, 2008
You have been logged on with a temporary profile. You cannot access your files and files created in this profile will be deleted when you log off. To fix this, log off and try logging on later. Please
Under assumptions your are trying to logon to a networked machine which requires that PC to contact a server to download your account.
now if this PC has been disconnected from the network but still has your temporary user profile stored on it, you can still log on but only as a temp user.
to solve this make sure your connected to the network either through wireless or wired.
Dec 20, 2013 | Computers & Internet
My Dell 1750 Inspiron laptop will power up, then my user profile appears, I enter the correct password and the screen says ''The User Profile service service failed to open the logon'' ''User profile...
It seems like the user profile is not working.
You can try to start computer with safe mode with command prompt (by pressing F8 while starting the computer) and then activate administrator profile (by typing : net user administrator /active:yes) in command prompt and after that you can create a new user profile.
Let me know if it will not work.
Oct 19, 2013 | Computers & Internet
How to get computer off a tempory profile
which operating system ?
Every time that you log on to a Windows Vista-based computer that is connected to a domain, a temporary user profile is created.
When you log off the computer, the user profile is deleted.
This behavior usually occurs because the account that you use to log on to the computer is a member of one or more of the following groups:
•Guests
•Domain Guests
If this is a school/work computer then this is most likely the way the NetAdmin has set it up.
If this is your home computer then a temporary user profile is issued each time an error condition prevents the user's profile from loading.
You may encounter profile issues if you log on with a user in the Guests group.
You need to remove the user in question from the local Guests or "Domain guests" group and that should do it.
1. Click Start
2. Right click Computer and Select Manage
3. Select Local Users and Groups > Groups
4. Double click Guests
5. Check if the user that is having the issue is a member of the Guests group
6. If so, remove the user from the Guests group
7. Log off the workstation and log back on
8. Verify the profile is now local
or
Try following these steps and check if it helps:
Important: This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly.
Therefore, make sure that you follow these steps carefully.
For added protection, back up the registry before you modify it.
Then, you can restore the registry if a problem occurs.
a. Log on to the system by using an administrative user account other than the user account that is experiencing the problem.
b. Back up all data in the current users profile folder if the profile folder still exists, and then delete the profile folder. By default, the profile resides in the following location:
%SystemDrive%\Users\UserName
c. ClickStart, typeregedit in the Start Search box, and then press ENTER.
Collapse this imageExpand this imageIf you are prompted for an administrator password or for confirmation, type your password, or click Continue.
d. Locate the following registry subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
e. Under the ProfileList subkey, delete the subkey that is named SID.bak.
Note SID is a placeholder for the security identifier (SID) of the user account that is experiencing the problem.
The SID.bak subkey should contain a ProfileImagePath registry entry that points to the original profile folder of the user account that is experiencing the problem.
f. Exit Registry Editor.
g. Log off the system.
h. Log on to the system again.
After you log on to the system, the profile folder is re-created
hope this helps
or
1. Use SFC / SCANNOW command to help you detect and fix any corrupted or missing system files.
1) Go to Start menu, expand "All Programs" - "Accessories" - "System Tools", right-click "Command Prompt" in the pop-up menu, select "Run as administrator", then input "SFC / SCANNOW" without quotation marks and press Enter.
2) When the "SFC / SCANNOW" command is running, this command will scan every corner of your system, and repair the missing or corrupted files.
2. Shift to another administrator user, if you don't have one, please create a new administrator account and log in.
3. Navigate to C:\Documents and Settings folder, backup the data of your original corrupted profile, then delete the corrupted profile and all the temp profiles.
4. Open Registry Editor (type "Regedit" without quotation mark in the start menu blank and open it), search for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\ProfileList, under the profileList subkey, delete the key named SID.bak.
5. Restart your computer; you will be able to log in the normal profile again.
hope this helps
Sep 23, 2012 | HP Pavilion G4 G6 G4-1000 Series...
My hp pavilion g series is loged on to a tempery profile so every time i log off everything is erased
•Guests
•Domain Guests
1. Click Start
or
hope this helps
or
hope this helps
On start up I hit F8 and got to the "Repair Your Computer"; went there but when the username and password came up, it was blank. I filled in my regular information (only user created on the...
Rough. Alright, might have your back on this one. So, did you type in your log-in name and leave the password field blank and click "OK"? If that didn't work, there is another option. Instead of entering "Repair My Computer" choose "Safe Mode". Often times, there is a hidden administrator account on some systems that doesn't have a password. If you only see your profile listed when you get to the log in screen, then shut it down and restart. If you do see the administrator account log in and delete the user account. If you only saw your profile listed, log in to Windows in normal mode and check the Start>All Programs list for an Acer Recover Utility that might allow you to begin the process from within windows.
Aug 23, 2011 | Acer Aspire 5315-2191 Notebook
The windows loads up and the "dell scree" loads
load up in safe mode. Keep Pressing f8 when you turn on the laptoptill you get a menu use the arrow keys to select safe mode. when windows loads you will see your usual login and another called administrator , click on the administrator and log into that one, click start > control panel > user accounts and click on manage accounts then click create new account, called it what ever you want. then once you have created the account restart the laptop and then log on to the new account instead of yours . Report back here if you are able to login to windows ok using this method
Mar 25, 2011 | Dell Inspiron 1525 Laptop
When I put in my password it tells me "The User Profile Service service failed the log on User profile cannot be loaded
switch the laptop on and then after the post messages appear and before windows starts press f8 repeatedly until the startup menu appears choose safe mode then log in as administrator. click start control panel > users > click manage user accounts then click create new user and create the account with administartor rights. Restart the laptop and log in to the new account you created then open computer up and right click on local disk c and click properties then click on tools click the button next to error checking saying check now. It will say windows cannot check a disk while it is in use and would you like to schedule a check on nxt restart or it will have a button saying schedule disk check, if its the latter click it. restart the pc and let it check the disk
after it has started windows try to log back in to your old account
if you cant log in to your old account you may be infected with a virus, scan your laptop.
If you find this useful please vote for me
Feb 26, 2011 | Computers & Internet
Buenas noches, apenas enciendo mi portatil dell 700m me pide clave de bios, la lleve a un tecnico y creo que no la trabajo bien y no la logro desbloquear, que puedo hacer?? soy de colombia y la verdad no...
Use a floppy disk or USB memory key to create a password reset disk using the following Microsoft instructions: How to Create a Password Reset Disk
The easiest way to recover from a lost password situation is to use a password reset diskextlink.gif. If you have a reset disk, follow these steps:
  1. At the Windows logon screen, click Reset password.
  2. Insert the recovery diskette or USB key.
  3. Follow the instructions on-screen to create a new password.
  4. Log onto the account using your new password.
new_note.jpg Note: Password reset disks are valid for the account they were created on. If you use a password reset disk to recover your password, you do not need to create a new reset disk afterwards.
Issue 3: Resolve Error: The User Profile Service Failed the Logon
The following Microsoft Knowledge Base Article provides instructions on how to resolve The User Profile Service Failed the Logon. User profile cannot be loaded error.
"Error message when you log on to a Windows Vista-based computer by using a temporary profile: "The User Profile Service failed the logon. User profile cannot be loaded"extlink.gif Article ID: 947215.
Issue 4: If You do not have a Password Reset Disk
If you have lost or forgotten your password, and a password reset disk is not available, reinstalling the operating system is the only recourse. For information on reinstalling Windows, refer to Dell Knowledge Base Article, How To Restore or Reinstall Microsoft® Windows® on a Dell™ Computer
Nov 07, 2010 | Dell Inspiron 700M Notebook
Inability to load personal profile
Make sure Windows has been activated. If so, try to create another profile with Admin privileges. Is the computer infected with a virus. Some viruses, spyware or malware will deny access to your profile. Have a professional Computer tech try to scan for viruses.
Apr 19, 2010 | Dell Inspiron 1501 Notebook
The user profile service service has failed to log on
Start in safe mode as administrator.
Create a user profile
restart
use new profile
Jan 04, 2009 | Microsoft Windows XP Home Edition
Dell Inspiron 6400 Notebook Logo
93 people viewed this question
Alun Cox
