Question about Denon Audio Players & Recorders
Denon DRA 345R. no fm reception. have am reception. fm freqs display correctly and the antennas are connected correctly. Help
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: No radio
The front end is bad on this reicever. Your going to need special equipment to trouble shoot this problem, as Its all RF. It is most likly not worth repairing as a shop will most likly charge you more then its worth
Posted on Sep 16, 2006
petraman7
  • 1175 Answers
SOURCE: Denon DRA 345R. no fm reception.
Hi...
What are you using for an antenna?
Also, do you have aluminum siding or aluminum sheet in your house insulation?
Steel roof? Any of those will kill reception.
Posted on Mar 24, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: FM antenna is not providing
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
Posted on Sep 14, 2011
SOURCE: DRA-345R stereo receiver. FM is gone, poof! just
I have a denon DRA-345R and when I put on position mode cd I can listen music and then after 1 minute the mode change automaticly to position FM. Tell me please what a have to do?
Posted on Nov 15, 2011
My Denon Stereo Receiver (DRA-345R) (quite an old model but has worked perfectly up until now) has a very static reception on AM. FM is fine. It started when I had my DirecTV upgraded with a Genie (whole...
it's obviously getting interferance fronm that whole house broadcast unit (not abnormal!) best and only thing you can do is to move the stereo to a place where you can get the MOST am stations the loop ant. is exactly what it says it is a loop of wire with two ends..both ends connect to the ant. input on the back of the unit..however if that whole house broadcast unit is the devil then an ant. no matter what or how it's made will only recieve more static not built to reject static! so you've got to move it unfortunately ..fm is a totally different band obviously fm isn't being affected by that whole home broadcast unit..you're lucky! on that count
Dec 12, 2013 | Denon AVR-2307 Receiver
FM antenna is not providing reception, despite cable connected to powered antenna amplifier. TV also connected to powered antenna amplifier (splitter) works fine. FM mode produces only static. I purchased...
Sep 14, 2011 | Denon DRA-37
DRA-345R stereo receiver. FM is gone, poof! just like that. nothing looks burned. where do I start? No change to the antennae has been made
Jan 31, 2010 | Denon Audio Players & Recorders
AS SOON AS I TURN ON MY DENON-395 RECEIVER IT TURNS OFF
I REMOVED THE AM LOOP ANTENNA. AND THE UNIT WORKED. TO MAKE SURE THIS WAS THE PROBLEM I REMOVED AND REPLACED IT SEVERAL TIMES. EACH TIME IT WENT OFF AND. I THEN PUT ON THE FM INDOOR (WIRE) ANTENNA. THE UNIT BEGAN TO PLAY BEFORE EVEN BEFORE I CONNECTED IT. JUST GETTING IT CLOSE TO THE FM COAX. MADE IT WORK.
Oct 28, 2009 | Denon DRA-395 Receiver
Grundig g6 airband in khz and poor reception
I think having the display showing MHz for the air band would have been a better choice on Grundig's part, but it really doesn't matter that much. Its just a matter of moving the decimal point to the left three places.
As far as getting better reception on the air band, here are some tips:
1. Use an antenna.
2. Try other antennas.
3. Find a known active freq.
4. Find a freq. low of FM spurs.
5. Turn up the volume.
I own and use a G6, and get decent results with it on the airband.
Aug 20, 2009 | Grundig G6 Aviator Radio Buzz Aldrin...
Air Band not receiving well and not showing Mhz Showing Khz
1. Use an antenna.
Jul 15, 2009 | Grundig G6 Aviator Radio Buzz Aldrin...
Hi...
Mar 23, 2009 | Audio Players & Recorders
Denon receiver (DRA 397) will not speak to iPod dock
IF YOUR NOT USING A DENON IPOD DOCKING STATION IT WILL NOT FUNCTION CORRECTLY.
YOU CAN CONNCET OTHER TYPES OF IPOD DOCKING STATIONS BUT YOU WILL NOT HAVE CONTROL THROUGH THE DENON AND ONLY CONNECT THE AUDIO FOR THAT DOCKING STATION TO THE DENON AS ANOTHER SOURCE INPUT
Oct 13, 2008 | Denon DRA-397
No radio
Sep 16, 2006 | Denon AVR-1100 Receiver
208 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
