Hi there. Open this link http://www.mediafire.com/?yan3ytvdumt and download the software.The install the software and click on the reset button.Open this link for more detailed info http://tricks-collections.com/reset-canon-pixma-mp150-mp160-mp170-mp180-mp450-mp460-mptool-software/
SOURCE: Waste ink absorber full - contact service center for replacement
STEP 1:
- Disconnect printer from AC power
STEP 2:
- Press and HOLD the POWER button, and
connect printer to AC power
This simple power off procedure worked on my IP1500!
Cleaning the absorber was also easy. Power up with the cover open until the head moves to the left side then disconnect the power cord so the head is now positioned away from the pads.
The two pads can be lifted up easily with a pair of sharp tweezers then rinsed in running water. They will become white again and can be blotted with paper napkins then air dried in a warm location (I used an industrial oven set to 40°C). The wells in the rubber holder can be cleaned with cotton swabs before returning the two pads (left side first, then press down the right side).
SOURCE: waste ink absorber full
my printer is very broken in this so absorber full,it make reset manual,can helm me
SOURCE: I have the message: Waste ink absorber is full.
If pineworks solution does not work, you may want to clean the print heads.
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your ip3000 print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
Time necessary 45-50 minutes
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your ip3000 in new condition.
Happy Printing .
SOURCE: Pixma IP1500 stops
Temporary Fix
This always works in case you need your printer for Emergency ^_^.
SOURCE: The waste ink absorber is full. It won't print
Contact service centre :)
or you can reset the waste ink tank and keep using the machine but it will damage ur printer and may gone permanently..
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
