Question about Lexmark X7350 All-In-One InkJet Printer
NO COMPUTER CONNECTION
I CAN PRINT WITHOUT USING THE COMPUTER BUT I CANNOT SCAN OR PRINT ANYTHING ONLINE HAVE DONE EVERYTHING WILL NOT DOWNLOAD CANT EVEN FIND PRINTER AT ALL ON AFTER HAVING ERRORS I DELETING NOW NOTHING
  • 1 more comment
  • Michelle Stanley Jul 05, 2008
    already did that it still want find my printer and the printer says computer not connected i uninstalled it because it was not working and now i cant reinstall because it cant find my printer when i hook it into the usb port have other things hooked up so i know it works and plus its new bought new for my camera old one tore up now something has happened to printer please help
  • j_karoo Jan 29, 2009
    i have installed the driver and everything. I can print the test page using just the printer. But i cannot do anything using the computer. It says it does not have a connection. what a lousy printer
  • Anonymous Apr 04, 2009
    printer says computer notconnected
    Sergeant:
  • 287 Answers
Go HERE and download the driver for your operating system and install it.
then post back results
Posted on Jul 05, 2008
  • Dave Jul 06, 2008
    try this,
    unplug your printer from the USB
    Click Start > Programs/All Programs > Lexmark 7300 Series > Uninstall Lexmark 7300 Series.
    reoot pc
    install driver again and plug printer in when asked to NOT before. IF not asked, then plug in after driver install completed
Problems with HP Photosmart C6280 All-in-one Printer
Populate the destination list You must populate the destination list in HP Solution Center for the Scan To function to work. Follow these steps to populate the destination list.
NOTE: HP Solution Center is the software that came with the product. You must make sure the software is installed on the computer for all the product functions to work correctly. The software is also necessary for completing this procedure. Install HP Solution Center if it is not already installed.
  1. On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center . HP Solution Center opens.
  2. Click Scan Settings .
  3. Click Scan to... Setup .
    NOTE: It might take several minutes for the list to populate. If the appropriate programs are already listed as scan destinations, discontinue this procedure. You must reinstall the software.
  4. Click each program to include on the Scan To Destination list. Figure 2: Add destinations c01404190.gif
  5. Click the Add arrow. The program listing moves from the left side of the screen to the right.
  6. Click OK .
Jun 23, 2009 | HP Photosmart C6280 Printer
I have an issue with my Dlink DIR-625 wireless and cable modem
it isn't syncing up with your modem, try a hard reboot, disconect everything, even the cable, after 5 minutes , first screw the coax cable back to the modem, that will re establish the cable connection, plug everything back in, and if that pc light still is still doesn't work, the router may be bad, look on the Dlink site and download the latest firmware, as a last resort, but also reset the router first before trying anything, there is a reset button on the router. Sometimes certain routers don't work with certain modems, if you try the reset, then the hard reboot, and the firmware, you have covered all the bases
Mar 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
Scx-4216 network scan not working
The solution is using the software smarthur3 that come with the CD, then download smarthur4 on both server and client computer......
smarthur3 will run as network, and use smarthur4 to scan.
on client in smarthur4, under scan , then setting select the network name.
everything work now....
smarthur4 even have pdf format.
let me know if you still have problem.
Mar 06, 2009 | Samsung SCX-4216F All-In-One Laser Printer
Problem scanning on MFX-1430
I am not sure why all scan to email is deleted, but you cant use scan-to-email or any of those scanning features using a USB anyways. Must be connected to the network
If connected by USB, you can download some twain scan utility (purchase one or download free one online) on your computer and install/set it up to use the Muratec as the scanner. Anytime you want to scan, open and use that utility.
Jun 22, 2008 | Muratec MFX-1430 Copier
Printer offline
First try to scan from the computer to check whether the connection is fine between the computer and the all-in-one. We experience this issue when there is no communication between the computer and the all-in-one.
If we are able to scan then remove the USB cable from the computer and open the printers and faxes folder in control panel if you are using XP. Then clear if there are any pending documents and right click on the printer icon and select user printer online and again right click on the F380 printer icon and click on properties >> advanced tab >> print directly to printer and click OK.
Now try to print from the notepad and check for the results.
If the issue persists then download the print diagnostic utility from the HP website and then run it.
Jun 02, 2008 | HP DeskJet F380 All-In-One Printer
Keeps telling me the printer isn't communicating with computer
Before I can help you I need the model and manufacturer of the printer you are having problems with. Also what operating system you are using?
Jan 10, 2008 | Office Equipment & Supplies
HP Deskjet F380 All-in-One Compatible with vista
I had the same problem. I could print, but not scan.
However, if you open up Paint and go to file and scan, it will scan your document. For some reason, using the scan button on the printer itself will not work with Vista, but using Paint will. I also heard that using Windows fax and scan will also work.
good luck
Nov 21, 2007 | HP DeskJet F380 All-In-One Printer
Cant scan from hp 3110 photosmart printer
You are having hardware communication problems caused, very likely, by driver installation troubles. Go into CONTROL PANEL and then SYSTEM and then DEVICES and look for the scanner there under IMAGING DEVICES and check to see if it has an exclamation mark next to it, or if any other device has this mark, meaning that drivers are not installed for it. If there is no scanner but you have a warning icon labeled UNKNOWN DEVICE, this is the problem. If you find any non-functioning hardware devices, this is probably it.
Try this as a fix. Unplug the cable to the printer/scanner.
Go online to HP and download the latest drivers and utilities for the scanner/printer and save them to your desktop.
In CONTROL PANEL, open ADD REMOVE PROGRAMS. Scan down and remove (uninstall) anything related to the HP printer or scanner, everything. Then reboot. Then install the drivers and utilities on your desktop you saved previously, plugging in the unit when prompted to do so. If you are never prompted, plug it in at the very end when everything is installed. If this routine fails, try rebooting the system without the HP scanner plugged in, wait for a complete start-up, and then plug the scanner into a different USB port and follow the directions on screen taking note of any failure messages. PS: the scanner/printer needs to be powered on through all of this, of course. :>)
Good luck
Nov 16, 2007 | HP Pavilion dv4000 Notebook
Lexmark X7350 All-In-One InkJet Printer Logo
73 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
