I have a Westinghouse LCD monitor It powers on but there is no display.
  • junicr Jul 05, 2008
    The cord is not bad since it works on other monitor. I had already turned it off and retried it so the solution of turning off and retrying won't work. Monitor model LN2410NM Westinghouse
    Guru:
  • 859 Answers
If another monitor works just fine and this monitor doesn't on another PC or laptop, then you have a dead monitor and should seek replacement under warranty, if it is under warranty. But check it on another PC or laptop first.
Worldvet
Posted on Jul 05, 2008
    Genius:
  • 3,422 Answers
Unplug all the cords from the back and then plug them back in after 30min.If this doesn't fix the issue,then try replacing the power supply cable with a new one.
No power Westinghouse LD4655BX
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 04, 2014 | Westinghouse Televison & Video
Westinghouse monitor l2410nm display comes on then dissapears
you must check the power supply board, look for a bulging electrolytic capacitor which may cause of voltage drop.
Mar 29, 2013 | Westinghouse 24" L2410nm 1920x1200 16:10...
I have model LCM-19v1 SL monitor and I need to know what type of power cord I need for it. and possible a picture
hi,
these are the specs for you monitor
Upgrade your desktop display in size and style with this Westinghouse LCM-19v1 19-inch LCD monitor! Its advanced HD-Grade flat panel technology lets you enjoy crisp, vibrant images while working on spreadsheets, writing email, watching movies, playing games and surfing the web.
Some key features include 1280 x 1024 native resolution, 600:1 contrast ratio, and a fast 21 ms response time. Its thin, sleek and sophisticated design will complement any office. Get yours today!
By law, California shipments of this product are subject to an $8.00
Electronic Waste Recycling Fee
Features/Specifications:
  • Westinghouse LCM-19v1 19-Inch TFT LCD Flat Panel Monitor
  • General Features:
  • Silver Cabinet color
  • 19" diagonal screen size
  • Native/Optimum Resolution: 1280 x 1024 16.7 million colors
  • Compatible Modes: VGA, SVGA, XGA, SXGA
  • Contrast Ratio: 600:1
  • Brightness (Nits): 300 cd/m2
  • Response Time: 21 ms
  • Viewing Angle: 170 degree Horizontal, 170 degree Vertical
  • Built-in stereo speakers
  • Connectors: 3.5 mm stereo mini-jack. VGA-in, DC-in
  • DC Input: 19V - 3.1A
  • EnergyStar compliant
  • Regulatory Approvals:
  • FCC
  • UL
Package Includes:
  • Westinghouse LCM-19v1 19-inch TFT LCD Flat Panel Monitor
  • Power Supply (100-24V 50~60Hz)
  • Power Cord
  • Stand
  • VGA cable
  • Audio cable
  • User's Manual
Additional Information:
  • Requirements:
  • Available power outlet
  • VGA adapter
  • Notes:
  • LCD displays may have cosmetic imperfections that appear as small bright or dark spots. This is common to all LCD displays used in products by all vendor and is not specific to any vendor or brand. Below are the acceptable amounts of "dot defects" for LCD displays that we sell:
  • 17-Inch to 18-Inch:
  • Total Defects: 8
  • Bright or Dark Dots (random): 4
  • Bright or Dark Dots (2 adjacent): 2
  • Bright or Dark Dots (3 adjacent): 0
  • Minimum distance between defects: 15 mm (bright to bright dots); 5 mm (dark to dark dots
for the adapter, already inserted the picture of it
Hope this will help... Your response is very much appreciated....
Jan 20, 2011 | Computers & Internet
L2046NV Monitor Does Not Display, but Another Monitor Will.
The problem is with the Westinghouse monitor. The video card inside the monitor is most likely faulty. There are 2 cards inside, 1 is the power supply and the other video. The power cards are typically OK if you are getting a green power indicator. The video card is most likely the culprit and will need to be replaced. If you open the case, BEWARE the capacitors, make sure you drain them before poking around.
Apr 13, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
My Westinghouse monitor fliker for 1 sec and dont diaplay anythin
Make sure all cables are tight if that doesn't work you need to put it in the shop if its still under warranty if not you need a new one
Mar 10, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
No power but ON button flashing
Quickest fix for this is probably to temporarily unplug the monitor power cord.
For your other outages, I assume the monitor is connected to a computer, make sure the operating system power-save features have not disabled the video output signal from the computer ... if so, monitor should re-activate when you use the mouse or hit a key on the keyboard.
If your computer has two video outputs, make sure the primary display hasn't been shifted to the other one ... try it by moving the LCD data cable to the other video connector on the computer.
Dec 26, 2008 | Westinghouse LCM-19v1 Monitor
Lcd monitor 20.1
The white screen is caused by a total lack of control over all pixels. The opposite effect; all black, happens when a failure turns all pixels on, blocking all but a small amount of light.
This could have more than one source; one output of the power supply has failed so the logic section no longer is receiving supply voltage or an external source has damaged the video input of the monitor. The backlight responsible for the white screen is obviously working as this is a separate power supply output to an inverter that powers the backlight lamp.  I'm afraid this is not a DIY repair.
Sep 17, 2008 | Westinghouse Computers & Internet
Computers & Internet Logo
David Payne
David Payne
