2004 Ford Explorer Logo
Posted on Jul 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2004 ford explorer radio
Would you know what pins on the back of the radio( 6 disc) would be the 12v pins cause I had my radio removed and left 6 cds in the radio and need to know what pins so I can jump them to power up and remove cds. Thanks. 2004 ford explorer
Anonymous
Level 2:
  • Expert 169 Answers
  • Posted on Aug 31, 2008
Anonymous
Expert
Level 2:
Answers
169
Questions
0
Helped
103351
Points
528
You need to plug this back in to activate the player and remove the cd's or disassemble the unit to pull them out.There is too much to happen to just power up one circuit. Good Luck.
2helpful
I have CDs jammed in side 6 disc changer (factory)> I have tried resetting the system by removing and replacing the fuse, but still get CD Error> If I need to remove the unti, is there an easy way...
Press and hold eject button,insert a credit card under cartridge
Push card fully in and move left /right right/left
This will locate micro switch to release cartridge
1helpful
2answers
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
2helpful
Got 2002 ford explorer and the 6 cds will not come
OK I am no expert but I have has this exact same problem......TWICE. I just addressed it again this afternoon by disconnecting the battery. Once reconnected the radio "initialized" and I was able to eject all cd's and use the player again. I can only speculate as to the cause but it could be because at least 3 of the cd's contained MP3's burned from my ITunes library. I will stick to audio cd's and see if it happens again!
My 6 disc cd changer won't read cds
unplug the power to the cd player for about 10 minutes or so. usually that reqiures unhooking the car battery. if that radio is of the anti-theft variety make sure you know the code and how to enter it before you remove power
2answers
Cd error on my Ford 2004 expedition
I have seen this often..assuming there isn't a CD jambed in it....usually means you have to send it out for repair...its most of the time an internal problem.....you can try first is disconnect the plug at the back and reinstall them and turn it back on...If it still shows ERROR....replace the radio... If its a stuck CD...FORD radios DO NOT LIKE homemade CDs, they are to thick, and labels hang it up...If this is the problem use a "needle nose pliers" and extract it the best you can AND DON'T USE COPIED CD's....hope this helps you..GL
CD P;LAYER HOLDS 6 CDS DOESN'T WORK
radio is bad needs to be removed and repaired
Ford focus 1999
Pin --- Color --- Stripe --- Function
Harness 1
1 --- White --- Black --- Left front +
2 --- Gray --- Black --- Left front -
3 --- White --- Purple --- Left rear +
4 --- Gray --- White --- Left rear -
5 --- White --- Red --- Right front +
6 --- Gray --- Red --- Right front -
7 --- White --- (none) --- Right rear +
8 --- Gray --- (none) --- Right rear -
Harness 2
1 --- (not used)
2 --- Black --- Green --- Radio Ground
3 --- (not used)
4 --- Orange (thin) --- Black --- Radio Illumination
5 --- Green --- Yellow --- Radio switch
6 --- Black --- Yellow --- Radio Ground
7 --- Orange (thick) --- Black --- Radio 12V
Harness 3
1 --- White --- Green --- Speed sensor
2 --- (not used)
3 --- (not used)
4 --- (not used)
5 --- (not used)
6 --- (not used)
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
