Question about Refrigerators
Refrigerator We are looking for a refrigerator that is less than 27 inches wide or deep so that we can get it through a rather narrow door into the kitchen. Do you carry a refrigerator of those dimensions?
    Novelist:
  • 161 Answers
It is fairly easy to remove the doors on a top mount fridge without any dispenser in the door. This should make almost any fridge less than 27" deep. When you remove the doors keep all spacers and washers seperate so you can replace exactly where you found them. When putting the doors remember the holes on some hinges are bigger than the screws so you can align the door before tightening the screws.
Posted on Jul 05, 2008
Tip
New Refrigerator and Refrigerator Depth
When buying a new refrigerator many people like the look of a built-in refrigerator but find that they are very expensive and will require extensive remodeling to make them work for their kitchen. The answer becomes the counter depth refrigerator. These refrigerators depth can vary in the depth between 23 and 27 inches. This will keep the front of the refrigerator back about six inches more than a normal refrigerator which often run between 30 to 34 inches in depth. While the front of the counter depth refrigerator may still have to stick out beyond the cabinets so that the door can be opened, it does not require that it stick out way beyond the cabinets, as many normal depth refrigerators do.
The configuration of many counter depth refrigerators is the double side by side door model with a freezer the full length on one side and the fridge on the other side. They also come with the freezer in a drawer on the bottom and a double door fridge on the top.
Because of the depth limitation many of the counter depth refrigerators are wider and/ or taller then the standard depth models. This gives the room for the refrigerator cu ft or refrigerator cubic feet (internal size or capacity) to be larger with less depth. If you are considering one of these models, make sure that you measure the space available to make sure that you can fit the refrigerator into the hole that you have for it.
The price of the counter depth refrigerator will also be a bit more then the standard depth refrigerator. While this cost may be more, they are still much less then a true built-in refrigerator. If you check you can also find counter depth refrigerators that will allow you to customize the front panels with wood, just like true built-in refrigerators.
What refrigerator best meets your needs can only be decided by you. A new refrigerator will often last about 15 years. Take the time to check carefully into what type and size will be the best for you.
http://www.fixya.com/support/r4326839-refrigerator_maintenance_tips
http://www.fixya.com/support/r4327013-refrigerator_efficiency
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4326731-new_refrigerator_size_or_refrigerator
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
http://www.fixya.com/support/r4020581-moving_refrigerator_best_way
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
on Mar 13, 2010 | Refrigerators
How many cubic feet is a refrigerator that is 29 inches wide 64 inches high 27 inches deep?
If these are the inside dimensions then the answer would be:
V = H x W x D/1728
= 64 x 29 x 27/1728
= 50112/1728
= 29 cubic feet.
Mar 05, 2015 | Refrigerators
The width of my refrigerator is 27. Inches. What is the cubic feet
That depends on how high and how deep the refrigerator is.
For example, if the height and depth are both 27 inches then the volume is about 11.39 cubic feet. If the height is 36 inches and the depth is 27 inches then the volume is about 15.19 cubic feet.
May 25, 2014 | Refrigerators
Cubic feet calculator
That would depend on the depth. A refrigerator that's 60 inches high by 30 inches wide by 1 inch deep would be just over one cubic foot. A refrigerator that's 60 inches high by 30 inches wide by 30 inches deep would be 31.25 cubic feet.
Mar 17, 2014 | Office Equipment & Supplies
Home Depot lists a depth dimension for a GE refrigerator. Is the handle included in the depth dimension?
no. depth is measured from the back of the box to the front of the box but does not include the handles. The depth of the cabinet is used to determine if the doors will open sufficiently to clear countertops and half walls or appliances. Also helps determine if enough space will be available to open doors in small kitchens such as "c" shape, "L" shape or narrow galley kitchens. for small kitchens, the best frig is a side by side. The doors are smaller and less swing space is needed. A 25 cubic foot side by side uses less swing space then a 15 cubic foot single door. If you are worried about depth, you can also get a counter depth frig which will stick out past your countertops by about 2 inches rather then 8-10 inches with a standard frig. standard depth is about 28-36 inches from the back wall when plugged in. Handles get in the way most often in width measurements because they prevent the doors from swinging past 90 degrees if located next to a wall.
Dec 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I am looking for the dimension and capacity of fridge 69852990
Measure Exterior Height & Width and Depth for Dimension.
Interior Space = Then, Measure all open accessible area inside the fridge and add the two together, following the formula of H+W+L Freezer and H+W+L Refrigerator,add together and BAM ya got cubic inches.= Square inches, then divide by 1,728 (the number of cubic inches in a foot (3) Cubed.
Example 1: 60 inches tall, 42 inches wide, 30 inches deep = 75600/1728 = 43.75 Cubic Foot AREA
Example 2: fREEZER dIMS = 24 DEEP x 18 HIGH x 36 WIDE =15552/1728 is 9 CuFt. Refridgerator 36 wide, 36 high 28 deep = 36,288/1728 = 21 CuFt. + 9 CuFt. = 30 Cubic Foot Capacity.
By the Math Wiz RUDY :)
Apr 18, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
How msny cubic ft. is my 106.9750610 Kenmore refrigerator?
I tried downloading a manual for your Kenmore Top-mount refrigerator-freezer but it is no-longer available. the next best way is to measure the inside dimensions of your refrigerator. Measure the depth, height and width in inches. Times them together and divide by 1728.
example: if your inside of your refigerator is 30 inches wide by 20 inched deep by 50 inches tall you get 30 x 50 x 20 = 30000 cuin / 1728 = 17.36 cuft. Do the freezer section seperate to know thier individual measurements and add them together to get the total. I hope this helps. - subdriver
Mar 25, 2010 | Refrigerators
What are the dimensions for the samsung rsa1 dhmh please?
The demintions are 35.9 inch wide x 33.8 inch deep x 70 inch high
Mar 09, 2010 | Samsung RS2556 Side by Side Refrigerator
GE Profile 25.1 cu. ft. fridge is too large for door entrance
yes you can, or just removed the bottom drawer, open the upper doors and slide the refrigeraro thru the doorway by just swinging it thru. a mover friend of mine showed me that trick at it work great.
Jan 24, 2009 | Pds GE Profile Bottom-Freezer Drawer...
Refrigerators Logo
126 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
