Question about Apple iPhone Smartphone
Frozen iphone my problem start from text message menu and frozen. i try too do like hold a couple second on off switch or try to come back to a main menu but i can't. when i connect to itune ,it come out message like i have to unlock a password from iphone. What should i do,please somebody help me!!!
  • 1,879 Answers
  • 52 Answers
What you can do is reset your iPhone and that should resolve your issue .
If that does not work then visit your local apple store if you need help locating one then give me your zip and i will locate one for you.
Thank you, Apple Care Technical Support
Posted on Jul 05, 2008
I've removed the cable from iPod to soon from a sync .... now ipod has frozen and nothing is working on iTunes at all
You need to Perform a Hard Reset on iPod Classic..To perform an iPod hard reset , start by toggling the hold switch from off to hold, then back off again. Press and hold down the Center button (middle of click wheel) and the Menu button. Continue to hold these buttons down until you see the Apple logo on the iPod screen (approximately 6-8 seconds).
If the hard reset doesn't work the first time, try it again a couple more times. Sometimes it works the second or third time around.
If the iPod hard reset is still not working, try connecting your iPod to a power source, or computer, and then doing the hard reset.
*For older iPod models, you may need to hold down the Play/Pause button and menu button, rather than the Center button and Menu button...Take care..
Sep 10, 2017 | The Audio Players & Recorders
How do you retrieve deleted text messages on iphone 4
Well, iPhone Data Recovery may help you solve your problem. You know, it is good at recovering iPhone data such as sms, contacts and more. You can follow the steps here in the following:
Step 1: Launch the program and scan to recoverStep 2: recover deleted SMS from iTunes backup files
Step 3: Start to recover iPhone text messages
For more details, read this guide:
Retrieve Deleted Text Messages on iPhone
Apr 12, 2013 | Apple iPhone 4 Black Smartphone
How to recover deleted text messages
As a matter of fact, every time you sync data between iPhone and iTunes, all previous data will be automatically backed up by iTunes and stored as a .sqlitedb file, which will be updated along with the later sync continuously. But those backup files can't be viewed or taken out unless you use some software using special algorithms to extract. Learn how to recover your iPhone data with step by step guides.
Mar 27, 2012 | Pinger Textfree Unlimited - Send Text...
My iphone 3gs is frozen on the contact screen. how do i unfreeze it?
Tricky but there's a couple methods
1. Try holding down the home button (bottom center) and tapping a couple times on the sleep button (top right)
If that doesn't work you can reset it into restore mode then kick it back out of it.
2. Hold the home button for 5 seconds. Then hold the sleep button for 15 seconds. The phone will go black.
Once that happens, tape the home button a couple times, then the sleep button.
Then hold down the home button for 5 seconds, and hold down the sleep button again and the apple logo should reappear.
It might take a coupe tries to get it to kick out of restore mode but it's possible.
I hope that helps
Jul 22, 2011 | Apple iPhone 3G
I cannot send text messages from my sony ericsson vivaz u5i, but i can recieve text messages, incoming calls and i can make outgoing calls.. what is the factory setting code so i can reset my phone?
First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your Sony Ericsson Xperia X10 is frozen, pull the battery out and reinsert it
  2. Hold the Left and right buttons located beneath the display
  3. Press and release the Power button
  4. Follow the on-screen instructions to hard reset your Xperia X10
All data including third-party applications will be deleted from the Sony Ericsson Xperia X8. Once the wipe is complete, the phone will reboot to its factory fresh state.
The password is user defined, try the second method if you did not set a password.
Good Luck!
Jun 16, 2011 | Sony Ericsson XPERIA X8 Cell Phone
My iphone is frozen!!
If your iphone is frozen generally you can unfreeze by a simple hard rest of the the iphone..
- Hold the on/off button and the home/menu button at the same time till you see the white apple logo appear
- once you see the apple logo let go and it should reboot to the main menu.
hope this helped
Dec 03, 2010 | Apple iPhone Smartphone
Frozen screen
First, make sure the lock slider is in the proper position.  I know, obvious, but you'd be surprised how often this happens.
Next, slide the lock slider to locked and then back.  Then press and hold the Menu and Select (center) button for 6-8 seconds.  Try a couple times if it doesn't work the first time.  The ipod should reset and work.
If that didn't work, you can reset your ipod.  But first, try connecting the ipod to your computer and see if it goes into sync mode. If so, wait for iTunes to load and then eject your ipod in iTunes and see if it works again.
To reset your ipod, slide the lock slider to locked and then back.  Next hold the Play/Pause Button and the Menu button for 6-8 seconds.  You may have to try this a couple times.  The ipod should reset.
The last thing to do is to let your ipod discharge completely by leaving it at the frozen screen.  Once your ipod is out of battery, reconnect it to you computer or a power adapter and let it charge.  Then try to access it again or repeat the steps above.
Nick
Jan 22, 2009 | Apple iPod nano
Frozen Screen I have a frozen screen which says "Disk Mode", then there is a large "tick" in the centre of the screen, and another message saying "OK to disconnect". Nothing I try unfreezes this - I have...
I do not know which ipod you have, but here are instructions on how to get a nano in and out of DISK MODE:
To turn iPod Disk mode off:
  1. Toggle the hold switch on and off
  2. Press and Hold the Select and the Menu button for more than ten seconds
  3. The normal selection screen should appear, your iPod is out of Disk mode.
To turn iPod Disk mode on:
  2. Press and Hold the Select and the Menu button for six+ seconds
  3. Release both buttons when the Apple logo appears
  4. Press and Hold the Select and Play button until the Disk Mode text appears.
If it does not work, you may need to reset your ipod. The following link has extensive instructions on that procedure for many types of ipods.
Good luck my friend!
Dec 28, 2008 | Apple iPod nano
CANNOT VIEW SMS TEXT
call in to here http://apple.com/support/iphone/
theres a message board near the bottom with all topics about the iphone .may some here will be able to guide to the answer .
good luck
riz.
Nov 06, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
136 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
