Question about Samsung ML1740 Laser Printer
Printer not compatable
No compatablility of my mac and my samsung ML-1740 HELP!! Please! Jan
    Sergeant:
  • 287 Answers
Try the drivers from HERE
there a few mac OS drivers so ensure you select the correct one
Posted on Jul 05, 2008
My computer will not recognize my samsung ML 1740 printer when I plug it into the USB jack. Is it because I have windows 7 and I need to upgrade to the latest version of the laser printer driver??
Yes, you need to update your printer's driver. The driver for Windows 7 can be found here:
http://www.samsung.com/au/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=ML-1740
Sep 16, 2011 | Office Equipment & Supplies
Driver for ml-1740 printer
Drivers for that printer can be downloaded from the link below.
Robert from Blitware
Jun 23, 2010 | Samsung ML1740 Laser Printer
I have a Mac running OS 10.5. Is there a printer driver for the Samsung ML-1740
try
http://www.samsung.com/download/FileView.aspx?cttfileid=196408&type=Printer&typecode=15&subtype=Laser+Printer&subtypecode=1501&model=ML-1740/TEC&filetype=DR&language=
Oct 08, 2009 | Samsung ML1740 Laser Printer
Why my powerbook G4 can not find my Samsung mp3 player and printer Samsung ML-1610. Both have USB connection. It can find everything else.
Samsung ML-1610 is a Windows only printer, but...you CAN get it to work.
Download a driver for the Samsung ML-1740 printer. You can get that here ---> http://boulter.com/downloads/samsung/20040507135703687_SPL_V2.5.sit
That should fix your issue.
As for your MP3 player...I don't have a good answer for you. Sorry
Oct 08, 2009 | Apple PowerBook G4 Mac Notebook
I have a Mac OS x version 10.4.11 and have brought home a ML 1740
Not Mac Compatible....see this link:
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view.jsp?isINPUT=Y&SITE_ID=1&PG_ID=0&AT_ID=19005&PROD_SUB_ID=0&PROD_ID=29
Mar 19, 2009 | Samsung ML1740 Laser Printer
Samsung ml-1740 printer - their driver not compatible with my Windows Vista
Try to install the software by clicking the right button of mouse on it and chose 'run as administrator ' from drop down menu.
Before installing do the following:
Unplug pinter USB.
Remove printer from installed printers (delete ) from Windows control panel.
Keep printer usb cable unplugged when you start driver setup software, you will be asked by setup wizard when to plug in the cable, or reconnect after installation.
If it still does not work, do a system restore to a date before you plugged in the printer for the first time, then repeate software setup as above.
If it still does not go you may need to reinstall Vista or replace the printer, one of the system files or regisries entries had developed a problem with printer driver, and is not easy to locate and remove the files concerned one by one.
Regards
Sep 01, 2008 | Samsung ML1740 Laser Printer
you must go to printer in control panel, then right click the desired printer icon, then click properties, then click on Port. then if using usb port, you must check each port untill you find the correct usb port that you are connected to (click apply each time). may take a couple tries untill you find the correct usb Port that the cable is connected to. worked on my HP desktop, finally
Sep 01, 2008 | Office Equipment & Supplies
Compatable with Mac?
 Get the ESP Postscript and the Samsung GDI driver from linuxprinting.org and install the two. Go add a USB printer in the OSX print center, hold the option key to get to the “Advanced Options” and add a “Samsung” printer, chose the ML-1210 driver and you’re done.
here is the link for drivers above http://www.linux-foundation.org/en/OpenPrinting/MacOSX/samsung-gdi
Oct 16, 2007 | Samsung ML 1610 Laser Printer
Samsung ML1740 Laser Printer Logo
75 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
