Question about Kenwood FreeTalk XL TK-3101 (15 Channels) 2-Way Radio
Kenwood TK 3101 two way radio problem
I have 2 radio's that were power backwards. What I mean is they were hooked up to a car power adapter. The problem was the wires in the cigarette lighter were reversed. Before both worked great, afterwards both would not power up. I an hoping there is a internal fuse or something cheap to fix. Can you help?? Thanks Smitty
  • smitty141 Jul 06, 2008
    Thanks Freetek, It was simply my poor judgment. I use these radios as
    a bike to bike (motorcycle) communications. I use a Autocom battery
    adapter that hooks to bike power. Were I went wrong I was connecting
    power to a tank bag. I reversed the wires on "power out" and plugged
    the first radio in. It did not work, and like a dummy I grabbed my
    spare and you can guess what happen next. In the end, two bad radio's.
    Thanks Smitty
  • 5,568 Answers
Most devices that can be operated from external supplies have a diode across the the power jack that will short the source if the polarity is reversed.
Since this is a pretty small part without much chance of surviving the current available from a cigarette lighter socket, the only hope you have is that the fuse almost always found in these 'adaptors' will blow before the diode fails.
If the radios will not operate from batteries, I'm afraid they are badly damaged.
It son't hurt much now if you open the case and check near the power jack for burned parts. The diode(s) probably aren't there at all any more since they are commonly capable of no more than an amp or two and the typical fuse in those car adaptors is 5-10 amps, enough current to cause the diode to explode before the fuse blows.
I don't know where you reside, but in the US there are many sources for low-cost digital multimeters (<$20 US) that would have prevented your problem simply by checking the polarity of the jack before plugging it in.
I don't think the lighter was at fault; I believe the adaptor was wired for a particular item, just not for your radios.
It's always chancy to use a power source only because the plugs match.
Most devices have a small symbol molded into the plastic near the power jack showing which polarity input is correct.
Posted on Jul 05, 2008
I have 2 walkie talkie but one cant work like receiving but cant talk when i push the button
I would suspect that the frequency setups don't match.
The only way to know on the TK 3101 is connect it to a computer.
I have the cord and program for the TK 3101.
Let me know if you need help.
Apr 22, 2012 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
How to reset tk 3107 keenwood
The Kenwood TK-3101 are programmed through the old DOS based program and a program cord. The only way to "reset" is also through the cord. Finding both the program and cord might be difficult but i do have those and let me know if you need assistance?
Apr 04, 2012 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
How can I program my Kenwood TK-3101 Radio?
Here is a link to the Kenwood TK3101 Manual which explains how to program this radio.
http://www.hitechwireless.com/pdf/Kenwood/TK3101-manual.pdf
If you need custom programming please contact us.
HiTech Wireless 888.511.5162
Mar 18, 2009 | Kenwood TK-3101 Radio
Compatability
The Kenwood TK-3200LU15 is the 2Watt replacment model for the TK-3101. the TK-3202 or TK-3203 are 4 watt models that can be used. Although, they have to be programmed with the frequencies and codes you are using. The TK3101 came with defualt GMRS/FRS frequencies.
HiTechWireless.com
Jan 14, 2009 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Fixing kenwood tk-80
If you have the schematics try to follow the voltage lines with a volt meter. If this is beyond your capabilities then I would suggest taking the radio to a service center or sending the radio to Kenwood.
Nov 18, 2008 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Kenwood TK-3101 is sensitive to Motorcycle RF
After a lot of experimenting, I decided to try powering the Autocom with a 9v battery and that fixed the issue. Evidently, the power from the bike was dirty - I'll have to filter the power line, find a different place to tap into or remain battery powered.
Apr 01, 2008 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Kenwood FreeTalk XL TK-3101 (15 Channels) 2-Way Radio Logo
726 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
