Question about Dell 922 All-In-One InkJet Printer
Black ink problems
Hello:
Can you tell me what the solution was for problems printing with black ink? My cart. is at 50%, but the black ink is skipping and getting very faint.
Thank you !
Karen
  • 36 Answers
Most likely there is a problem with the ink level reader. Replace the black ink cartridge.
Posted on Jul 23, 2008
Black ink alone not printing
what brand ink? does the printer utility software on thecomputer tell you anyhthing about the ink? are the ink lights flashing even though the cartridge is in? If so it's probably a bad cart
Aug 29, 2012 | Epson Stylus C79 InkJet Printer
My printer won't print black
Did it print black before you replaced the black cart?
If so try 1. purging the new ink cart. 2. reseat and purge 3. rpl it is defective.
Feb 21, 2010 | Canon PIXMA MP510 All-In-One InkJet...
New cartridges loaded in. error telling me no black cartridge. telling me also short circuit in print head has occured. help!
this is usually a print head problem with these type of ink jets. try unplugging the printer, remove the ink cart and take an alcohol pad or qtip with alcohol and clean the cooper contacts where the ink cartridges go. If the printer is not used alot the ink dries up and clogs the print heads. Once cleaned, re-insert the cart. and power on and see what happens. No promises here as this is the nature of dealing with ink printers.
hope it helps and good luck
Aug 06, 2009 | Dell 926 All-In-One InkJet Printer
Canon MX850 willnotprint from Large Black Ink Cartridge - PGI-5BK
Ink Carts do act finicky at times. Especially Canon carts.
In many cases, the ink carts have a small fuse built into the back of the cartridge that opens up if the cart has been removed for any reason. Replacement Carts come with the fused portion reset, thus when you insert it into the printer, it works great. If the cart is FULL, it still may not be observed as full or new by the Printer itself. Best way is to use a new cart, not necessarily a Canon Brand. Use an inexpensive company like
https://www.carrotink.com/canon-pgi-5-cli-8-combo-10-pack-ink.html
Feb 15, 2018 | Canon PIXMA MX850 Multifunction Printer
Black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Assuming genuine ink cartThis worked for me on a HP printer 1.Try print black text ,and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck Inkypete
May 01, 2009 | Canon PIXMA iP3500 Printer
I have a Brothers MFC 440CN . My Magenta ink cartridge is empty , how can I get the machine to print in black only ?
If you look at your printers software, there may be an option to "Print greyscale" or Print B & W Only.
Aug 14, 2008 | Office Equipment & Supplies
Printer won't print in black
This could be to several reasons:
1#  The black cart contains blue ink-> Change to a brand new cart.
2# The cart assy has a bottom that is a foil. Sometimes this foil leaks.
Ink will mingle: You need a new cart assy.
Run the cleaning cycle twice after inserting a brand new bk ink cart and print out a test print. If you still see blue instead of bk the assy is leaking.
BTW the bk is darker than blue (or better cyan). You must see bk! So it seems to be the prob with the right ink....
Nov 11, 2007 | Brother Multi-Function Center® MFC-215C...
Black stopped printing out. Dell 922 all-in-one ink jet.
clean contacts on back of blk cart and printhead with alcohol on micrfiber towel
Oct 14, 2007 | Dell 922 All-In-One InkJet Printer
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Dell 922 All-In-One InkJet Printer Logo
79 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
