Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Thermostat shows "Err" "FF"
Similar to another reader,. our kenmore bottom freezer (french-door) model displays ER on the left side and FF on the right side. We unplug the fridge and plug it back in. It goes away for a bit, but returns.
Refrigerator model #f795.77302600.
So, what part is broken and where do I get it and how do I replace it? Thanks for all of your help and assistance!
  • mndipper Jul 05, 2008
    An addendum - the bottom freezer appears to still be working. But the icemaker, which we do not use, is all frozen over; we are defrosting it at the moment. We have unplugged the appliance.
Well, this may be a solution, at least in our case. While were were unpacking the refrigerator and dumping food into coolers, we also unloaded the freezer, even though it appeared to still be running.
After clearing it out, we noticed that the icemaker device in the upper left corner was all iced up, like an old freezer does without self-defrosting. We thought our machine was a self-defroster and this made us suspicious.
We unplugged the appliance and defrosted this upside-down iceberg in the freezer. After it was cleared out, we plugged it back and and lo and behold, the thermostat came on! Here it is 12 hours later and it is still running.
So, it may not be the actual cause, but I can't come up with another solution at the moment. By the way, it makes us wonder if the error code "FF" that we had stood for "freezer fan". Perhaps that iceflow interrupted the fan or its circulation, somehow? In any event, other people with this same error code (FF) might check for icing forming around the icemaker.
Posted on Jul 06, 2008
On the display on door. The message says Er FF. What is this and how do it clear. When I press buttons, nothing changes.
Er FF is Error, Freezer Fan. The fan blade in the freezer is most likely blocked by some ice or frost. Clear that and the control will see the feedback from the fan showing that the motor is turning and the code will clear.
Feb 12, 2011 | Kenmore 73503 Stainless Steel Bottom...
The display is showing ER FF WHAT DOES THAT MEAN
error fresh food means refrigerator probably bad thermistor in refrigerator ( ff refrigerator ) fz freezer
Jan 27, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Door display shows eror code FF
This means your freezer fan is not working and you'll need to replace it. It's one or two small plastics fan that sits behind your freezer drawer. It's located behind one of the two wall panels behind your freezer drawer. They circulate the air flow throughout, one for your refridgerator and the other for freezer. I had to have both replaced and now my line holder in the bottom back right side of my refrigerator is leaking, so I had to shut off my water until we find the part number. Good Luck! I know I'll need it because my wife has all LG in the kitchen including a flat T.V and 2 microwaves.
William,
Aug 05, 2009 | LG LFX25960ST Stainless Steel French Door...
ER FF code
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 12, 2009 | Kenmore 77719 Side by Side Bottom Freezer...
I have code error "err ff"
I also had an "eR FF" message. I discovered that the fan inside the freezer compartment was locked up from accumulated frost. I unplugged the refreigerator for about 6 hours and left the freezer compartment door open so it could completely defrost. So far, it's been running smoothly (and more quietly!) for about 24 hours now. (My fingers are still crossed).
Feb 18, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite ER FF
Possible sesor error. Unplug for bout 10 min then plug back up.
Jan 30, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
283 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
