Question about Sony LAMP BLOCK XL2100U Projector Lamp
Replacement Instructions I have purchased a replacement XL-2100U Lamp Unit and am looking for instructions on how to install it. Thank, Jay
  • Anonymous Sep 01, 2008
    remove cover to replace lamp
Hi
it's a simple switch out, first make sure your set is unplugged, open the panel concealing the lamp, unscrew the door, unscrew the lamp, pull it out straight towards you it is attached like an outlet plug, carefully switch it with the new one be sure not to touch the lens, screw in tightly replace the compartment door then the panel and your done....good luck }:)
Posted on Sep 22, 2008
I need LAMP DOOR Cover Mine got warpped from heat
Contact someone from sony, call or send them an email asking where you could purchase this replacement panel.
Jan 27, 2015 | Sony Replacement lamp for Grand WEGA or...
Sony KF-60WE610
Some of the ICs on the power supply block are damaged. This can possibly due to high voltage or defective IC. What you can do now is to get a new PS block. If you can get me the part number i can help you find it..
Feb 23, 2008 | Sony XL-2100U Projector Lamp for...
I am trying to figure out how to replace my replacement lamp, but do not know where it is located.
Lamp Access door for Sony KF50WE610 is below the screen on the front of the TV. This page shows location of Lamp access door and DIY bulb change instructions for most SONY LCD TVs:
DIY Bulb Installation Guide
XL-2000 XL-2100 XL-2200
XL-2400 XL-2500 XL-5000
XL-5100 XL-5200 XL-5300
This page shows Lamps and bulbs for all Sony LCD Projection TVs
Sony Lamp Gallery
Look at Optical Engine Faults before buying a lamp or bulb. Replacement bulb will not repair these problems.
Feb 05, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Red light blinks 4 times
Hi,If your tv is close to 6000-8000 hrs or 2-4 yrs and haven't replaced the lamp yet, it might be time.The part # is XL-2100 you can find it here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm and here's the instructions to replace it: http://www.fixyourdlp.com/guides/sony/XL-2100U.php
Mar 22, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Black screen with sound on xbr grand wega 70 inch
Hi,If tv is between 6000-8000 hrs 2-4 yrs and havent replaced the lamp it might be time to do it so.Here's your part # XL-2100 you can find it here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm here's instructions to replace it : http://www.fixyourdlp.com/guides/sony/XL-2100U.php Thank you and have a blessed one!
I have a sony wega 46 inch tv model number: KDF42WE655 the screen went black and the red light came on where it says "lamp" on front of tv Does this mean I just need to replace the lamp?
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on.But pretty much it does sound like the lamp.your part # will be xl-2100 and you can find it here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm and here's the instructions to replace it: http://guides.fixyourdlp.com/sony/XL-2100U.php Have a blessed one!
Feb 10, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
The red lamp light is flashing on our Sony KDF42WE655. What is the replacement parts I need to fix and instructions for doing so. Thanks.
You can find the documentation for your Sony on the Sony Documents & Downloads page.
The part is Sony XL-2100 or XL-2100U. Instructions are in the manual, page 16.
Feb 05, 2010 | Sony XL-2100U Projector Lamp for...
Sony KF-60WE610, green light flashes few times and return to red, what could be the problem TV only five years old
Your lamp (back lighting) is burnt out and need replacement. The instructions are in your manual
Nov 08, 2009 | Sony XL-2100U Projector Lamp for...
Need instructions on removal of the original lamp and housing and subsequent replacement with a new one on my Sony 42-inch LCD TV Model No. KDF-42WE655.
Hello! Here you have a picture guide and alos a video of how to replace the lamp, just go to http://guides.fixyourdlp.com/sony/XL-2100U.php good luck!
Jul 14, 2009 | Sony Televison & Video
Xl-2100u
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your Projector from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your unit Caution: Do NOT touch the bulb directly with your fingers.
  • Oct 19, 2008 | Sony XL-2100U Projector Lamp for...
    257 people viewed this question
    Top Sony Office Equipment & Supplies Experts
    shaun taylor
    Jaime Hernandez
    Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
