Question about Philips 60PP9363 60" Rear Projection HDTV-Ready Television
Pithcer to big for screen
The pitcher does not fit inside the screen when on the lowest seting
  • Philips Master
  • 3,459 Answers
Is it shrinking and expanding?
Posted on Jul 05, 2008
I can manually turn the blades inside the glass pitcher and I can turn the piece on the top of the motor base into which the pitcher blade attachment fits.
One of the parts is not being driven properly. Either the clutch on the top of the motor is not really attached to the motor shaft OR the clutch on the bottom of the blade is not engaging with the motor clutch OR the blade clutch is not properly attached to the blade shaft. On some models if you put the rubber sealing ring in the wrong place between the beaker and the blade housing it is enough to lift the clutches apart. The rubber wing goes between the beaker and the blade housing, not between the blade housing and the blade retaining ring.
Jul 14, 2015 | Blenders
Resolution to big
looks like you need open a game and find screen setings in it
Nov 14, 2012 | Computers & Internet
Own the 3 qt ice tea maker. When making tea it leaks around the seam in the front of the machine and pours out all over the counter and not into the tea maker; any fixes or suggestions to remedy this messy...
I have this same problem. There seems to be two sources of the leak, described below. However, I think Mr. Coffee should re-design the offending parts.
1) bad fit between the brewer and the pitcher, caused by a pitcher that stands too high, preventing the pitcher's spout from snuggling into the brewer. I avoid this problem by brewing without the lid on the pitcher.
2) the brewed tea does not flow straight down from the brewer basket, especially when the tab is set to "strong". In this setting, the brewed tea is forced through a tube, in order to spend more time steeping. However, if you watch the tea flow out and down, you will see it bend to the left and thus miss the catch spout of the pitcher (and flow onto the surface, leaving the impression that one of the parts is "leaking") . I think this is caused by buildup of particulate matter from the tea and/or hard water deposits. My solutions here: try the tab in the "mild" setting; and/or clean the basket drain holes occasionally, especially if you have hard water (soak in vinegar to remove hard water build-up). You may need a tiny bristle brush to clean the small holes in the basket. Also, try to fit the pitcher into the brewer as far to the left as possible.
Hope this helps.
Gary in Torrance
Mar 02, 2011 | Mr. Coffee Iced Tea Maker TM1S
The intermec is show a "ribbon fitted" error on the machines screen
its because the printer is setup Direct Thermal, and the sensor see ribbin present. need change setings.
May 21, 2010 | Intermec EasyCoder® PX4i Label Printer
Top rack doesn't get clean. It's like the spray bar isn't spraying out water.
Sounds like a loss of water pressure from the pump due to a clogged debris screen (keeps big stuff from entering pump). Check this screen at lowest point inside the washer where water enters water pump. Typically, some disaasembly of lower spray arm is required. If machine has a chopper/food disposal option, then clog is most likey at the screen in chopper assy.
Hope you find this helpful.
Mar 19, 2010 | Kenmore 16602 / 16604 / 16609 Built-in...
Anyone solve the pitchers in puzzle 78
1) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher. (leaves 7 litres in Pitcher 16)
2) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher. (leaves 2 litres in Pitcher 9)
3) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
4) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
5) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 5 litres in Pitcher 16)
6) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 4 litres in Pitcher 9)
7) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
8) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
9) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 3 litres in Pitcher 16)
10) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 6 litres in Pitcher 9)
11) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
12) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
13) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 1 litre in Pitcher 16)
14) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 8 litres in Pitcher 9)
15) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (Pitcher 16 also has 8 litres)
YOU NOW HAVE 8 LITRES IN THE 16 & 9 LITRE PITCHERS.IN 15 MOVES.
Apr 24, 2009 | Nintendo Professor Layton & the Curious...
Screen Resolution
THE DRIVERS MAY NOT SUPPORT THAT BIG OF MONITOR AND THE VIDEO CARD GRAPHICS MAY NOT BE ABLE TO SUPPORT THE SCREEN, PUT IT ON 720X600 SEE WHAT HAPPENS OR PUT ON LOWEST SETTING ON THE PC GRAFTIC SETTING OR LARGES RESULUTIONS SETTING, THE SOFTWARE MAYNOT SUPPORT THE TV, VESA - VERSA
MANUFACTOR IS NOT COMPATIBLE. AND I MAYBE TOTALLY WRONG
LETS SAY THE VIDEO CARD AND GRAPHICS ARE MADE FROM BOTH MANUFACTURES THAN CALL THE VENTER AND SENT THE CONVERSION SOFTWARE TO DO THAT .
JUST THINK WHEN THEY MAKE A MOVIE IT IS ON A LARGE SREEN AT THE THEATER 6-8 FT
SCREEN AND THAN IT COMES ON TO DVD THEY HAVE TO USE SOME SOFTWARE TO REDUCE THE PITCHURE SO IT CAN FIT ON THE TV SCREEN OR YOU WILL ONLY SEE PART OF THE SCREEN THAT CAN FOCUS ON
CANDYMANGANDY
Feb 17, 2009 | E-Machines T2682 (000002965) PC Desktop
All the sudden pitcher is bowed and colors are sepertated
This is convergence. First read FL231 fuse problem in tips and trick section to see if this may be the problem
Jan 22, 2009 | RCA HD52W58 52" TV
D61W20 RCA TV 1080i image problem
Theres most sistem pal/ntsc not a set of this menu seting www.wehot.biz
Jun 06, 2008 | RCA D61W20 61" Rear Projection Television
Philips 60PP9363 60" Rear Projection HDTV-Ready Television Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
