1980 Akai GX 4000 D does not record and has slow tape transport
  • 1,512 Answers
Hi wakjh
sounds like 28 years of service has gotten the better of the old girl. You will need to replace at least the capstan belt to get the speed back up. It will need attention in other areas also. reel idler tyres, takeup clutch, counter belt.
You can get a complete belt kit from here.
I am more than happy to answer any other questions you may have aboutit, please get back to me here, or use the ASK function to go straightto me :) If you are still unsure, have problems, or we need to look atthe situation more deeply, then before you give a rating for thisadvice, hit the ASK buttonThanks for using FixYa, If you consider the advice I have given you assound, a FixYa rating is a great reward for my efforts to help you.Cheers.
regardsrobotek
Posted on Jul 05, 2008
Have an akai GX-286d goes great in fast fwd until the last 2 inches or so tha slows down is this normal?
Most Reel-to-reel tape decks will slow down as they approach the end of a tape, since the momentum that had built up will have a hard time stopping at the end without stretching the tape (which will distort the sound upon playback)
Sep 20, 2017 | Akai Audio Players & Recorders
Akai GX-77 isn't erasing the old music on a new recording. Can hear the old music on the new recording. Please help. Thanks
Akai or Sony- just problem with erasing head. Usually erasing head looks like black and smoller near reading head. Can be problem deeper inside 'Tape Decks'- wire, no signal to the head and etc.
Oct 13, 2016 | Audio Players & Recorders
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
Although I placed both ends the necessary sensing foil ,when choose auto-reverse with my Akai GX-636 RtR only the right tension arm sense the foil and blocks without reversing.When in recording mode it...
I'm pretty sure the auto-reverse is NOT supposed to work during recording. What would be the point since it only records in one direction?
And I'm pretty sure there's only one reverse sensor, usually to the left of the heads and not necessarily on a tension arm. The sensor foil is supposed to be on the non-oxide side of the tape so it will adhere better and never contact the heads.
This picture of a GX-635 shows a typical transport ...
http://www.oaktreevintage.com/web_photos/Reference_Photos/Akai_GX-365D_Front_Face_Off.jpg
There's a knob for how the auto reverse. Is it set correctly? I believe infinite forward / backward play is possible if you have the knob set properly, a sensor foil on the tape and the tape counter set to 0000 at the beginning of the recording.
May 12, 2011 | Audio Players & Recorders
I need akai part number ms244708 for a 4000d
If you look around you will likely find many many Akai 4000 series reel decks for sale..some for parts.. Akai 4000 series decks used basically the same mechanism and same parts... 4000d, DS, DS II, DB, Incidentally, the Akai 1700, 1710, 1722, 1731 used the same basic mechanisms as the 4000. .
Oct 24, 2009 | Audio Players & Recorders
Akai gx-625 reel to reel tape deck has no sound
This could be a head fault? Another possibilty is the preamp stage. You will need to look for something that would take out both channels. Such as an IC.
Aug 26, 2009 | Audio Players & Recorders
How to remove the play, rew-ff levers and pause button to take off the front plate of a akai gx 4000 d reel to reel recorder?
Have you checked to see if there is a set screw in the handle which tightens onto the shaft? That's how most are secured. Look for a hole in the handle -- there should be a slotted screw which can be loosened with a very small scresdriver.
Apr 13, 2009 | Audio Players & Recorders
Unable to record with Akai GX-77
Make sure the cassett you are using has safety tab intact. Clean the heads and tape drive roller. If unit has a record level control, make sure it is set correctly
Apr 07, 2008 | Audio Players & Recorders
106 people viewed this question
 Grubhead
Grubhead
