Question about Baumatic B187 Stainless Steel Electric Single Oven
Oven not heating up but fan and light on
Indesit oven model k642r
  • 2 more comments
  • MKIELY Jul 28, 2008
    At the weekend the fan oven stopped heating, although the grill element seems to heat up fine.
    The fan & light also come on.
    It had been making a rattling noise in the last few weeks & this weekend it caused the fuse to flick off and once we turned it back on the oven stopped heating when in fan mode.
    Thanks,
    Martina
  • Anonymous Jul 31, 2008
    oven only 2 yrs old, looked at element still looks like new.
  • lovetosing Aug 15, 2008
    My oven is 9 years old. Recently, I used the self cleaning feature, which did a great job of cleaning the oven, but after that, the oven no longer heats up (fan and light work).
  • Anonymous Sep 30, 2008
    Fan comes on and so does the light but oven does not light!
Oven not heating up but light coming on fan working and grill working . it allso heats up on other settings but not enough to cook
Posted on Oct 04, 2008
    President:
  • 1,462 Answers
Circular element is open circuit. reasonable cost part and reasonable to fit
Posted on Jul 05, 2008
Have a neff oven no heat 6yrs old ,fan comes on along with light ? any ideas how much to repair?
Posted on Oct 21, 2008
I managed to resolve this. The thermostat on the cooker was gone and caused the element to overheat and warp. As a result of this it was causing it to hit off the fan, hence the rattling sound.
I had to replace thermostat and element and all is working fine so far.
I was told that the element life can be as low as 2 years so this can go anytime after especially if you use the cooker a lot.
Thanks,
Martina
Posted on Oct 10, 2008
Why does the Fan rattlle in my new indesit oven
It is used to cool down the heat.....just to protect the board and surrounding hardware components from over heating which in turns increases the life span of the hardware
Aug 25, 2014 | Ovens
Simpson Harmony Nova electric oven heating problems (oven heats but no fan and light)
The Fan has ,in most cases, two functions - to maintain the oven temp and to clear any condensate or smoke coming from items being cooked. If your oven is over heating it could be the thermostat sensor faulty and giving a faulty reading to the fan. If you set you oven at 350F then sensors control the heat by kicking the heating elements off and in some models and makes the fan aids cool down. Make sure it is at a temperature that would trigger the fan to cool it down. It mostly relies on the regulation of the heating elements to control the temp. Only if it were to get hotter than the elements kicking off can control should the fan kick on. Not being at the site and actually seeing the stove it is hard to determine but if the fan is working every where else it should work when the oven is heating. Again check and see if there is a seperate sensor that monitors the temp of the over and triggers the fan. Not much help but that's where I would look first. Hope this was of some help.
Col. Dana Gillespie
May 11, 2014 | Ovens
Indesit cooker
I would contact indesit on there tech help line .Its on line on there site
Apr 21, 2017 | Ovens
Hi right my indesit 29229 fan oven is not working it blow the power in the house now the top oven is work but the bottom one wont heat up the fans working and thats it do you think its the element thats...
To blow the house trips it must be the element
Thermostats do not normally go short circuit.
The elements can be replaced quite easliy and cheaply
I would check that the fan is turning freely before you buy the element
Feb 24, 2010 | Ovens
Hi,my electric tripped.i have an indesit k642r vsg.the oven light is on but it still is not heating the oven up.the fans working fine,why is this?
If it is a electrically heated fan oven, then in all probability, it is the oven element that has failed.
This is usually located art the rear of the oien compartment behind a removeable cover.
Hope this helps.
Feb 09, 2010 | Ovens
Indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Oct 23, 2009 | Ovens
Oven does not heat up
Generraly speaking, if the fan is working o/k , then it is more than likely that the oven element is faulty, and will need to be replaced.
Please rate my solution.
Thanks.
Aug 06, 2009 | Ovens
Fan assisted oven is not heating up
Hi.
Yes it is more than likely to be a faulty oven element, more so if the fan is workin o/k.
Please `rate my solution.
Thanks.
Jul 28, 2009 | Ovens
Fan Oven cooks at high temp when on any setting
Sounds like main oven stat is faulty.
Is the stat sensor fixed properly inside the oven?
Could have been disturbed when element fitted
Please leave feed back.
Thanks
Nov 25, 2008 | Jenn-Air JJW8530C Expressions Collection...
Baumatic B187 Stainless Steel Electric Single Oven Logo
944 people viewed this question
Top Baumatic Ovens Experts
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
