Question about Whirlpool Refrigerators
Whirlpool ice maker water line frezees in the frezzer section.
  • 481 Answers
  • usually when this happens the water valve is slowly leaking water. this small amount of water will freeze inside the fill tube for the icemaker; eventually blocking the water flow.
  • you might need to change your water valve going to your icemaker.
Posted on Jul 04, 2008
Hi I have a Whirlpool Refigerator and it drips water from the frezzer into the refigerator thru the two opening up in the back middle opening from the frezzer to the refigerator. It does this off and on
sounds like the drain live from freezer to outside is clogged. the water isnt making it you the condensate pan but coming out in the refrigerator. try finding and cleaning the drain line.
Mar 02, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice make did not refill, what should I look for?
it could be one of the following:
- bad water inlet valve
- frozen water supply line in freezer
- bad ice maker
the water inlet valve would need to be tested with an ohm meter, you could manually check the water supply lin in the back of the freezer section that supplies the ice maker. the ice maker would need to be properly checked by a trained technician.
Oct 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
REFRIGERATOR LEAKING WATER INSIDE THERE IS NO
Remove the food and remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you
see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Nov 07, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker not making ice
i had same thing happen the line going to the ice maker was froze i too everything out of frezzer and let line unthaw for about an hour now works fine
Apr 28, 2009 | Whirlpool GD2SHGX Refrigerator
Amana Side by Side - will not make ice - has new filter
did u try to check the solenoid valve in the water intake to the ice maker?.. it might be damage, check the frezzer temp.. might a little bit high, and check is there water in the ice maker, or theres is no obstruction in water hoses behind the refrigerator.. i hope this helps! :)
Mar 15, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Jan 25, 2009 | Whirlpool ED5SHAXM Side by Side...
Ice maker not working water working
somtimes the line to the ice maker frezes.you could test by putting 110 volts to the water valve direct[or inspect]water should then enter ice maker .your post dosent say your brand but most ice makers you can start by pulling on the harvest rake till starts.[mechanical only] if water valve good and line not frozen .then could be loss of power to ice maker[check at ice maker plug in at frezer] if thats ok then ice maker has failed,replace God bless,tom
Jan 10, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker and water dispenser not working
well there is two things it could be low water pressure or ur ice maker is defective try replaceing the ice maker this should work if not u need to get a frig repair man out to help u because if the problem is in the frezzer door it is not easy to fix on ur own
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
Refrigerators Logo
115 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
