Question about Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit
Wiring the Hampton Bay
I have three wires at the receptacle- Red White and Black. I have two wires coming from the fan Black and White. There are three wall switches . Two of them have a a black and a red wire and one has two black wires. The black wire has voltage and the red wire does not. What do I do with the red wire at the receptacle?
Thanks,
R
  • Sparkky May 11, 2010
    I need to know if you get voltage on the red wire if you turn on any of the switches. Probably one of the ones with a black and red on it.
I need
Posted on Sep 17, 2009
Need a wiring diagram for a hampton bay ceiling fan
most of the manuals have wiring instructions - check out any one of the manuals here
Jul 12, 2012 | Hampton Bay 24002 Ceiling Fan
I have a red, black, white, copper wire coming from the cieling. I have a hampton bay remote with orange, two sets of black, two sets of white, and a green wire. I connected everything exept the red...
this is for a three way switch do you have two switch if so hook the red to the orange and black to black and white to white make sure you ground it to the fan and everthing shoul work fine good luck
Aug 08, 2011 | Hampton Bay 24002 Ceiling Fan
Just installed a new Hampton Bay 36" ceiling fan.
I suggtes recheck your wires, could use this wiring guide (click image for zoom)... support/t9590572-hunter_fan
Jun 29, 2011 | Hampton Bay 24002 Ceiling Fan
No wiring diagram with fan ( hampton bay three speed fan with light)
white to white, black to black, blue to red, & green to ground.
If you don't have a second hot house wire(red), then put black & blue from fan to house black.
Nov 29, 2010 | Hampton Bay 52 In. Cameron II Plus Ceiling...
Hampton Bay Wiring?
You have two switches right? One for the light and one for the fan? White should be neutral. Green should be ground. Black should be hot from one switch and red should be hot from the other. Hook black to black and blue to red. If you wire blue and black together then one switch will turn on the fan and the light at the same time.
Feb 17, 2009 | Hampton Bay 48670 Flemish Pewter Finish...
Need Wiring instructions
no problem just wire the black to black and white to white. connect the ground and cap off the blue wire, its used only for ooptional light assy
Apr 03, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Jan 15, 2008 | Hampton Bay 46056 Callaway II Ceiling Fan
Hampton bay Windward III
Green and copper are the ground wires and I believe you can connect both these to the green wire from the fan (I only have the copper wire in the actual ceiling box). Black and Red can be treated as both black and both can be connected to the black wire from the fan (this is what I did in all my fans and it worked). White is the neutral wire and can be connected to the white wire from the fan (this is what I did in all my fans and it worked).
My ceiling box has the copper, red, black, and white wires. The ceiling plate for the fan I bought had a green wire. I connected the green wire from the ceiling plate and the copper wire from the ceiling box to the green wire from the fan.
Dec 29, 2007 | Hampton Bay 52 In. Black Huntington III...
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit Logo
73 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
