Question about Sony RDR-VX525 DVD Recorder/VCR
Dvd recorder HI DVD RECORDER is shuck on DVD1 snd needs to be on DVD3... How do I change to correct settings? Thanks
  • littlebarbra Jul 05, 2008
    Sony RDR-VX525
    The dvd recorder is stuck on dvd1 and I need to change it to dvd3 but it will not respond to the remote control to set up system menu to change it! How do I reset the dvd recorder for it to respond
    President:
  • Sony Master
  • 1,314 Answers
1. Press system menu.
2. Select setup, press enter.
3. Select options, press enter.
4. Select command mode, press enter.
5. Select DVD3, press enter.
6. Set the command mode for the remote so that it matches the command mode for the recorder you just set, i.e., DVD3. You do this by: Hold down enter, while pressing enter, press then number 3. Keep them pressed down for 5 seconds.
7. Press return to return to the previous display.
To check to make sure: Press stop on the recorder when the recorder is turned off. The command mode for the recorder should appear on the display.
Posted on Jul 05, 2008
    President:
  • 2,712 Answers
The following should give you access to a service menu containing controls for macro-vision and region coding. You can change the regional settings from there.
1. Set your player to Standby
2. Press Title, Clear and Power
  • Swilin Sampson
    Swilin Sampson Jul 05, 2008
    Here is the link to a user manual. May prove helpful :)
    http://www.docs.sony.com/release/RDRVX52...
    Should you find my solution helpful, kindly take a moment to "Accept" it. If it didnt work, please post back, and I will try to assist you further.
    Thanks.
  • Swilin Sampson
    Page 22 in the user manual will explain how to rectify this.
I accidentally changed the command code from dvd3 to dvd1 and now my remote doesn't work, and I don't know how to access the systems menu to change it back.
Since unit has been set on DVD1 remote mode so you need to set remote control itself on dvd1 mode to communicate with unit.
Press and hold Enter and 1 numeric key on remote control for 5 seconds, this will change remote control to dvd1 mode, now unit will accept remote control signal and you can operate it normally.
Thanks.
Jan 02, 2011 | Sony RDR-VX535 Player
My Remote doesn't work, replaced the battery's works for the TV, but not the recorder, is there a default reset on the recorder? because I've changed the dvd3 to dvd1 so I'm not getting anything to display...
make sure remote and dvd select the same setting DVD1 on dvd recorder, so DVD1 on the remote, ther is some writing in the manual how to change the remote from dvd 1 to 2 and 3
Dec 31, 2010 | Sony RDR-HX825 DVD Recorder/HDD Recorder
I can't return to command mode dvd3 (default) from dvd1. Now my remote is useless and I can't find a way to bring up the main menu so I can get back into command mode dvd3.
Slide remote lower cover and look for DVD Command mode set switch, set it to DVD-3 position, your RDR-VX530 will accept remote commands.
Thanks.
Dec 21, 2010 | Sony RDR-VX530 DVD Recorder/VCR
My Sony RD-VX525 DVD Recorder got set to DVD1, is there any way to set it back to DVD3 so I can use the remote again?
On the remote press the System Menu botton when opened, press Enter and scroll down to Option and press Enter then scroll down to Command, press enter and you'll find DVD1,DVD2 and DVD3 scroll down to it press Enter set or reset your unit as desired!
May 17, 2010 | Sony RDR-VX525 DVD Recorder/VCR
I have a Sony RDR-VX560 DVD Recorder / VCR Combo, accidentally put it to dvd1 instead of dvd3...ive tried holding the enter button and all that and nothin works..any way to get factory reset or any help?
Hold down Enter button on remote and while holding Enter press and hold 1 (numeric) on remote for 3 or 4 seconds, now remote is set on dvd1 mode and dvd recorder will accept its commands.
Thanks.
Mar 19, 2010 | Sony RDR-VX560 DVD Recorder/VCR
Set up sony RDR-VX535 recorder to DVD1. now remote does not work.
See the manual on page 22.
The solution is to reset your remote code to DVD1 (default is DVD3).
Press the ENTER button and NUMBER ONE button simultaneously for at least three seconds. Viola, control returns.
Feb 22, 2010 | Sony RDR-VX530 DVD Recorder/VCR
COMMAND MODE SETTING HAS BEN CHANGED FROM DVD3 TO
press enter and 1 or enter and 3 hold for 5 sec should match whatever unit set to
Oct 02, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Command mode change disabled remote
According to Sony, if you turn the power on and hold the Enter key and the #1 key down together for at least 3 seconds, everything will default back to factory settings.
Mike
Feb 01, 2009 | Sony RDR-VX515 DVD Recorder/VCR
DvdRDR-GX360
It´s is easy to solve. Your DVD was seted to DVD1. Push enter button plus 1 no remote control.
Now you are able to commnad your DVD and go to System Menu and change to DVD3 again.
After it, don´t forget to backup your remoto control to DVD3. Push enter button plus 3
Dec 13, 2008 | Sony RDR-GX300 DVD Recorder
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Sony RDR-VX525 DVD Recorder/VCR Logo
189 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
