Question about Kitchen Appliances - Others
Paddle won't turn in the breadmaker with any resistance
My breadmaker paddle won't turn under pressure. I put all the ingred. in and turn on the machine. It starts the mixing process but the paddle doesn't turn when there is a little bit of resistance. My husband has taken it apart and the belt is good. He can try and fix it but with no instructions, it is hard. Can anyone help me?
  • Anonymous Jan 17, 2009
    Help - I want to make bread and the paddle won't turn for the knead cycle - any suggestion
It is the little metal plate that locks the paddle shaft to the big sprocket. the little flat spot is worn away. now where do I get a new one, it is may be worth a penny.
Posted on Jul 11, 2008
Why won't my paddle turn
My paddle won't turn in my Breadman TR 400. - Fixya
www.fixya.com/support/t20366573-paddle_turn_in_breadman_tr_400
Sep 27, 2013 - Posted on Sep 28, 2013.
Breadman TR850 Plus Bread Maker Paddle turn ... - Fixya
www.fixya.com > ... > Breadman > Breadman TR850 Plus Bread Maker
Paddle won't turn in the breadmaker with any resistance My breadmaker paddle won't turn under pressure. I put all the ingred. in and turn on the machine.
Amazon.com: Customer Reviews: Breadman BK1050S 2 ...
www.amazon.com/Breadman.../B003ZDNKSI
Amazon.com, Inc.Breadman BK1050S 2-Pound Professional Bread Maker with Collapsible ... So thepaddle turns and kneads while it goes in one direction. ... So, while I still love mymachine, I do a lot more bread by hand now. ..... Maybe I got a defective unit... but Iwon't be risking it... sending it back and exchanging for another brand.
Amazon.com: Breadman 34923 breadmaker paddle.: Bread ...
www.amazon.com/Breadman...paddle/.../B0041TMO...
Amazon.com, Inc.
Rating: 3.9 - ‎61 reviews
Turn on 1-Click ordering for this browser .... If I don't scrape down the sides a couple of times during the initial mixing, the loaf won't turn out correctly. ... This paddle fit my Breadman TR520 Programmable Bread Maker for 1-, 1-1/2-, and ...
Jan 01, 2016 | Breadman Bk2000b 2-1/2-pound Bakery Pro...
This machine is a Black and Decker model 2300 breadmaker. One paddle turns well but the second one doesn't turn under pressure. Is this repairable?
Are you certain that it is on the right rod? Have you tried changing it with the one that works? This would help in defining the problem. Best wishes
Jan 24, 2015 | Kitchen Appliances - Others
The spindle that holds the paddle won't turn. It's stuck tight.
It may be hard to turn by hand but does it turn when the machine is
turned on? If so it is OK even if you can't turn it by hand
Nov 28, 2012 | Breadman TR555LC Bread Maker
Does taste of plastic paddle on older black and decker b1561 bread maker get into the bread itself
It's likely a harder, heat resistant type of plastic and the breadmaker does not get hot enough to cause the paddle to release any toxic chemicals.
Feb 06, 2012 | Black & Decker B1561 Bread Maker
The machine gets warm but the paddle doesn't turn.
Hi, The paddle should turn freely by hand with the bread pan out of the machine. Make sure the pan is inserted in the machine correctly. If the motor shaft turns but the paddle doesn't then the sealed bearing that the paddle rotates on has failed and is frozen so the paddle does not turn.. You may need a new bread pan. Hank
Jul 01, 2010 | Kenmore KTR2205SPR Bread Maker
Kneeding seems to jam frequently
Hi, Take the bread pan and paddle out of the machine and see if the paddle spins freely by hand. If it sticks then the sealed bearing is failing. If everything is good here, check the tension on the belt pulley. The belt may be too loose to spin the paddle freely under load. Belt and motor is inside the base of the machine. Good Luck..Hank
Mar 13, 2010 | Cuisinart CBK-200 Bread Maker
The paddle on my panasonic breadmaker has stopped turning. Without the pan the mechanism revolves but once the pan is in place the paddle does not move.
If you take the pan out of the machine and can't turn the paddle freely by hand, then the sealed bearing is frozen. You can try putting warm water in the pan and soaking it. After a few tries if it does not free up then the sealed bearing is broken and bread pan needs to be replaced. Good Luck..Hank
Feb 06, 2010 | Panasonic SD-YD205 Bread Maker
Makes a bad loose sound when mixing dough
My Breadmakers Hearth was making the same sound, so after taking it apart I found that it was only the Bread Pans "under paddle" that the machine reaches up and connects to to drive the Paddle. I wears loose and wobbles and starts to slip making that banging sound. You can either replace the Bread Pan or like I did INVERT the under paddle (requires removing the C-clamp washer) to extend the life of the Pan and use of the Hearth. Hope this helps you.
Oct 20, 2008 | Toastmaster Breadmaker's Hearth 1193 Bread...
Oster 5821 breadmaker
I had a paddle freeze on me too I took apart the lower end and lubricated it then put it back together
Sep 03, 2007 | Oster 5838 ExpressBake Bread Maker
Paddle won't come out
I've had pretty good results with a crochet hook (use a metal one that can be run through your dishwasher). Insert the hook through the hole in the paddle and it should catch on the far side just enough to pull the paddle out of the loaf. Best to do it before it cools and the crust hardens, though.
Sep 23, 2006 | Black & Decker B1561 Bread Maker
Kitchen Appliances - Others Logo
422 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
