Question about Fuji FP-988D 19" Flat Panel LCD Monitor
Black Screen I recently replaced the fuse in my Fuji 19" LCD monitor after finding out that the power wouldn't come on. Now the power LED flashes every half second and the speakers make a popping noise as the led cycles on/off. The screen is blank, absolutely black. What do you think the problem is?
    Champion:
  • 293 Answers
Edwards,
What you mean by replaced the fuse? Are you replaced the capacitors on the AC Adapter. If so, Then it's not the only problems. The main problems is the backlight inverter needed to be replaced. Go check out my website @ www.3rd-rocks.com
and click on LCD Parts. If you have any questions just email to to me @ cjt@3rd-rocks.com Have a nice...Happy July 4th!
CJ
Posted on Jul 05, 2008
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
Power indicator on, logo flashes briefly, but then no picture. What's wrong?
SEIKI Tv SC501TS has audio but no video, repair - YouTube
? 1:38
https://www.youtube.com/watch?v=cWpF4q_rBaw
Oct 19, 2014 - Uploaded by EurekaRecycler
SEIKI Tv SC501TS has audio but no video, repair ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD ...
LED TV Repair Main Board Overview Blank Screen-TV Has ...
? 2:57
https://www.youtube.com/watch?v=-TU2KSuect4
Mar 4, 2014 - Uploaded by ShopJimmy.com
Learn why your screen is blank and you have audio - No image LED TV Repair Review Main Board Problems ...
LCD & LED TV Repair - No Image & Blank Black Screen ...
Dec 13, 2015 | SEIKI Digital Seiki SE32HY10 32 720p...
I have x2Gen 19" LCD Monitor. I hooked up the
More likely to be the fuse for the backlight inverter circuits rated at 3.5 or 4Amps. It is PICO fuse.
The transistors that drive the inverter transformers may have been damaged, should check them out before installin a new fuse. In the mean time you can use 1 to 2 Ohms 1/2 Metal Oxide (MOX) resistor in place of the fuse, if the resistor overheatand open up then you have shorts circuits.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Nov 19, 2010 | X2Gen MG19MY 19" LCD Monitor
I have a Planar 1910(Black) LCD from a friend. It first had a problem where it would show no display but the power LED would flash green to orange. I fixed the problem by reseting it. Now that the display...
It has white screen becuase it may not be getting the 5vdc from the logic board to the T-CON board or the board has blown fuse.
Please see http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Also look to see if power supply/logic bd had any bad caps also.
Aug 14, 2010 | Planar PL1910M (Black) 19 in. Flat Panel...
2-3-4- years old benq FP19G = returned to office after lunch - burned out electronic smell in air - whole section of office electrically dead' - did reset = computer fired up ok - but screen blank...
Benqs have had some quality control issues but from your description the inverter board went on you. It needs to be replaced or repaired. Expect to spend about $100 for the repair so you may want to consider just replacing the monitor.
They can be fixed. The monitor I am using right now was one of those dead ones. It took a few hours to find as the rest checked out and it turned out to be a bad ground. Unfortunately when you smell burnt electronics you are not going to get off that easy.
Jul 15, 2009 | BenQ 19" lcd black 1440 x 900 19 inch LCD...
Black screen
Hey... friend,
It's seems your backlight inverter is burnt out...need to replaced a new inverter. Visit this site @ www.3rd-rocks.com There's a replacement parts for your FP988D LCD. Have a nice day!
Aug 05, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Power supply for Gateway FPD1975W 19 inch LCD
try replacing the crystal on the power supply 8 out of 10 times it is the problem
Apr 02, 2008 | Gateway FPD1975W 19" LCD Monitor
LCD screen goes black repeatedly
Have you checked the light on your power supply? My monitor will go black and I noticed the light on my AC power supply was off. It was very hot so I unplugged it and let it cool down. When I plugged it back in my monitor worked fine until the power supply started to over heat again.
Oct 25, 2006 | Fuji FP-988D 19" Flat Panel LCD Monitor
Screen lit up, but nothing displayed (black)
Hello Frank, I have the same problem with my monitor. I don?t have the answer yet to resolve the problem. if you want the first of us who find the resolution will advise the other. I sent an email to Xerox to get the info to remove the cover without breaking it. regards Sylvain
Sep 01, 2006 | Xerox XG-91D 19" LCD Monitor
Fuji FP-988D 19" Flat Panel LCD Monitor Logo
136 people viewed this question
Top Fuji Computers & Internet Experts
Computer Links
Victorman
Victorman
robert
Are you a Fuji Computer and Internet Expert? Answer questions, earn points and help others
