Question about Dual Strata Antenna System - Checkpoint Systems Microphone
Dual boot Windows XP & Vista Home Prem. x64
I have XP on C:\ drive with backup files on D:\ I want to add a 3rd sata drive and load vista 64 bit on it. Do the drives with OS installed have to be in drive order? (C, D. E) Drive E:\ has my DVD/CD writer. If I disconect the two sata drives and install Vista 64 bit and then reconect the drives will XP re-letter the drives without fault?
    Scholar:
  • 134 Answers
It should work just fine, it is actually the best way to dual boot, that way you are not affecting the other OS(s) There is an article about that here : http://www.cas411.com/ShowArticle.aspx?ID=64
Alex
Posted on Jul 31, 2008
THE MITSUBISHI CP8000DW DRIVER IS DISCONTINUED HOW CAN I FIND THE DRIVER?
What OS is your computer running? I found the drivers for supported OS versions here: http://displays.mitsubishielectric.eu/resources/product/CP8000DW . The direct links are listed below. (All are .zip files so you will need to unzip them.)
Mac http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000m_macos.zip .
Win95-98 http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000dw_win95-98.zip .
Win NT and Win2K
http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cpd8000n_wnt4_0.zip .
If you have a newer Windows OS, you can try the compatibility mode. (The NT driver will likely work in XP. If you have Vista or Win7 32-bit OS, it's possible they will work but maybe not. If you have the 64-bit version, the above files will not work directly.) For executable files in Windows, right click on the .exe file and choose properties. Select the Compatibility tab and check Always run this program in the Compatibility Mode. Select the appropriate older version of Windows. Then click Apply. Close the Properties window. Then right click again on the file and choose Run as Administrator (required for Win7 and Vista).
To check if you have the 64-bit OS, click Start > Control Panel > System and Security > System (for Win7). In Vista, the steps may be slightly different. If the version name ends with x64, you have a 64-bit OS. Otherwise, you have the 32-bit version.
If you have a 64-bit OS, you need a 32-bit OS for a work-around. This can be a true second computer, a dual boot system (2 partitions with different OSes loaded), or a virtual computer with an older version of the OS. If you have Windows 7 Pro or Ultimate, you can install a virtual XP computer for free. Go to microsoft.com and download Virtual PC and the XP mode program. Install them in order. Then install your printer under XP as if it were the only computer running. (Note some computer hardware limits may stop you from using this option.) There are other virtual computer programs (VMWare, Parallels). However for the other virtual computer programs or the dual boot or second computer options, you need a licensed copy of the older OS.
I hope this helps.
Oct 03, 2011 | Mitsubishi Color Printer 8000DW Thermal
Tip
Windows Password Key 8.0 is considered as the best tool to reset local...
You can change a Windows User Account password that is on any Windows computer from any other Windows computer regardless of whether the User Account is on a workstation, a stand-alone server, or a Windows domain controller. Additionally, it makes no difference whether the password being changed from a workstation, a stand-alone server, or a Windows domain controller. This is true for any NT 4.0, W2K, XP Pro and Windows Server 2003 computer.
To change a user's password at the command prompt, log on as an administrator and type:
net user danielp * /domain
(This is only an example, use your own username)
When you are prompted to type a password for the user, type the new password, not the existing password. After you type the new password, the system prompts you to retype the password to confirm. The password is now changed.
Alternatively, you can type the following command:
net user danielp 123456 /domain
When you do so, the password changes without prompting you again. This command also enables you to change passwords in a batch file.
Note: If you type these commands on a member server or workstation and you don't add the /domain switch, the command will be performed on the local SAM and NOT on the DC SAM.
on Apr 28, 2010 | Microsoft Windows XP Professional SP2
Tip
Want to Backup and check your Windows Activation use WinKeyFinder
The latest version of this program is v1.73 released March 2010 I use this to encrypt my Windows Activation keys the v1.72 is great for backing up and restoring your wpa.dbl activation file
  • Supports Windows 98, 2000, XP, Vista, 7 and more - 32 bit
  • Supports Windows XP, Vista, 7 64 bit versions
  • Supports MS Office 2000, XP, 2003, 2007, and 2010 - 32 bit and 64 bit
  • Many Enhanced features
  • Removed the title RC from it.
This New version has the following Features Removed that were in version 1.72RC:
  • Removed Password Generator
  • Removed Activation Backup/ Restore
  • Many Internal features
I liked it so much I created a U3 installer file for v1.72 to backup my activation files for future installs download the installer HERE from my Sky Drive make sure that you also save a copy of your Volume Serial for the Primary Drive Partition this will change each time you install another copy of the DOS or add a Hard Drive
on Mar 31, 2010 | Microsoft Windows XP Professional
I have no sound driver
Please use the below link
For all drivers.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+945+Express+Chipset+Family+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D945GCCR
select the operating system then
select DRIVERS in select download type.
then download the sound drivers. and install.
For Audio drivers: Click on download
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19472&lang=eng
AUD_Vista_Win7_6.0.1.6201_PV.exe for vista or win7 AUD_XP_5.10.0.6201_PV.exe for xp. If you satisfy with my solution please rate/vote for me.
Rating/Voting will encourage me to help others
Jul 02, 2011 | Intel D945GCCR Motherboard
Can i convert a 32 bit to a 64 bit
You can use the Upgrade option during Windows 7 installation, which preserves your files, settings, and programs, only if you're currently running a 32-bit version of Windows Vista and you want to upgrade to the 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only perform an upgrade to a 64-bit version of Windows 7. For more information, go to Upgrading to Windows 7: frequently asked questions on the Windows website.
If you want to move from a 32-bit version of Windows to a 64-bit version of Windows 7 or vice versa, you'll need to back up your files and choose the Custom option during Windows 7 installation. Then, you'll need to restore your files and reinstall your programs. For more information about performing a custom installation, see Installing and reinstalling Windows 7‍.
gl_ico.png Notes
  • To install a 64-bit version of Windows 7 on a computer running a 32-bit version of Windows, you'll need to start, or boot, your computer using a 64-bit Windows 7 installation disc or files.
  • If you start your computer using a 64-bit Windows 7 installation disc or files, but your computer isn't capable of running a 64-bit version of Windows, you'll see a Windows Boot Manager error. You'll need to use a 32-bit Windows 7 installation disc or files instead.
  • Windows Easy Transfer can't transfer files from a 64-bit version of Windows to a 32-bit version of Windows. If you're running a 64-bit version of Windows Vista but you plan to install a 32-bit version of Windows 7, you can move your files to an external location manually or use Backup and Restore in Windows Vista. For more information, go to Back up your files and
Apr 08, 2010 | Dell Precision Workstation 490 - MT -...
System requirements of vista
For Vista Home Basic >>>
  • 1 GHz 32-bit (x86) or 64-bit (x64) processor
  • 512 MB of system memory
  • 20 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics and 32 MB of graphics memory
  • DVD-ROM drive
  • Audio Output
  • Internet access (fees may apply)
Additional requirements Actual requirements and product functionality may vary based on your system configuration. Windows Vista Upgrade Advisor can help you determine which features and edition of Windows Vista will run on your computer.
While all editions of Windows Vista can support multiple core CPUs, only Windows Vista Business, Ultimate, and Enterprise can support dual processors.
For Vista Home Premium, Business and Ultimate >>>>>>
  • 1 GB of system memory
  • 40 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics with:
    • WDDM Driver
    • 128 MB of graphics memory (minimum)
    • Pixel Shader 2.0 in hardware
    • 32 bits per pixel
  • DVD-ROM drive
  • Audio Output
Home Premium / UltimateTV tuner card required for TV functionality (compatible remote control optional).
Home Premium / Business / UltimateWindows Tablet and Touch Technology requires a Tablet PC or a touch screen.
UltimateWindows BitLocker Drive Encryption requires a USB Flash Drive and a system with a TPM 1.2 chip.
Windows Vista minimum supported system requirements Home Basic / Home Premium / Business / Ultimate
  • 800 MHz processor and 512 MB of system memory
  • Support for Super VGA graphics
  • CD-ROM drive
Regards.
Sep 21, 2009 | Microsoft Windows Vista Ultimate Edition
Can i window vista install in 512mb ram?
Windows Vista recommended system requirementsWindows Vista Home Basic
Source: http://www.microsoft.com/windows/windows-vista/get/system-requirements.aspx
Jul 11, 2009 | Microsoft Windows XP Professional
Want to add 2nd hard drive to vista64bit hombuilt.
In one system that I have seen this one, we had loaded optimized defaults. One item you could look at are the jumpers and the SATA ports if the connections are correct.
Jun 02, 2009 | Microsoft Windows Vista Home Premium with...
1,752 people viewed this question
Top Dual Audio Players & Recorders Experts
Jerry Naidoo
Michial Gueffroy
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
