Question about Canon Elura 65 Mini DV Digital Camcorder
Zoom i have a canon elura 65, the zoom keeps zooming in why
  • 2 more comments
  • speedybloke Jul 28, 2008
    I have a similar problem with a JVC GR-FX11. Whatever level you zoom to, when you release the zoom lever it zooms in to maximum. If I hold the lever, it stays where it is.
  • Anonymous Jul 30, 2008
    same issue. camera keeps zooming no matter what i do.
  • jheier Aug 18, 2008
    My Elura 65 started doing the same thing about a month ago. How can this be fixed and how much does it cost?
  • Lorna Tadic Jan 28, 2009
    the zoom seems to be stuck on tight,
My zoom problem was a combination of the software and hardware when it came to the neutral position for the zoom slider. When the camera is first turned on, if the physical zoom slider (hardware) is in the neutral position (you are not touching it) the camera software does nothing, but if you are pushing the physical zoom slider when you turn on the camera, the software resets the "zero zoom" position into memory. The solution to my problem was to push and hold the physical zoom slider towards the wide position and the software realize reset the "zero zoom" neutral position. This may take a few tries to get it right (if you over compensate, do the opposite and push the slider towards "T" when you turn it on), but I hope this will solve your problem and save you a few bucks.
Ryan
Posted on Nov 15, 2008
Our Canon Elura 65 Camcorder won't focus. The
First off I don't condone or advise hitting an electronic device but, from the advice of another post I did it and it worked. It shouldn't have but it did. I hit the bottom of the camcorder with the palm of my hand and it worked perfectly afterward.
Jun 28, 2010 | Canon Elura 65 Mini DV Digital Camcorder
Zoom by itsown
I had the same probem. I read on another forum that if you smack the bottom of the camera with the palm of your hand it will unstick the zoom. Worked like a charm for me!
Dec 02, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Zoom problem
The zoom is stuck. Smack the bottom of the camera with the palm of your hand. Worked like a charm for me.
Oct 23, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Canon Elura zoom problem
on mine the ribbon cable from zoom button was pinched where it goes around the door replaced cable
Jul 16, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Canon elura 65
on mine the ribbon cable from the button to the main board was pinched by the door and shorted
Feb 13, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Canon Elura 60 zooms by itself
Listen, I know it's a couple of years after this post but, try this: Remove cassette, push to close, close camera as if to use it, hold firmly in left hand, open hand slap it with your right hand once or twice, (I'm not joking) it worked the two times I had this problem. Problems with the zoom? Almost same process, push firmly on zoom button (to un-zoom) try doing this as your tapping it. These are last ditch efforts on an aging camera, it really has been a good one. I've put this poor thing through years of abuse, and it's held up pretty well. Good luck, Jeff S.
Oct 16, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Automatically zooming in
Hello:
I contacted Canon about this same issue in my Elura 65, and they said to send it to them, they would have their techs investigate the cause and then contact me with the costs to make the repairs. They said that if I didn't want them to repair the problem, after I found out the cost, that they would reassemble the camera and send it back.
Mine is out of warranty, even with buying it at Costco, who doubles the warranty time. In my researching the problem, I have found another person with the same problem who had it repaired for something like $175. I will weigh that against purchasing a newer model.
Someone else did reccommend wacking in on the top a few times, shutting if off and turning it back on, and that would often fix the problem. I don't want to take the chance of ruining an important shot that may not come around again, by having to Indian Leg Wrestle my camera to get it to work. Best wishes.
Oct 12, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Zooming problem
I have the same problem. I have no fix in rec mode but if it happens during playback; press menu and select the zoom options. You don't have to pick any but just keep the menu displayed on the screen. I do this while recording the tape to my DVD recorder and it solves the locked zoom problem. The menu display does not get recorded.
This zoom problem is a big pain. We should start a class action suit against Canon. It started within a year of ownership with mine. I bought a Panasonic recently and haven't looked back.
Panasonic doesn't have the slick Canon marketing/packaging but it is a much better machine.
Aug 20, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Canon elura 65
Hi There, Did you get any resolution for this problem? Even I have the same problem with my canon elura 70. Pls. share your thoughts. Thanks... Pradeep
Feb 08, 2007 | Canon Elura 65 Mini DV Digital Camcorder
Canon Elura 65 Mini DV Digital Camcorder Logo
348 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
