Question about Epson Stylus CX5800F All-In-One InkJet Printer
No Power Unit will not power on. Called the "help" center, but they said that because it was out of warranty, that I need to buy a new one. Tried unplugging it and replugging back in, but still will not power on.
  • 2 more comments
  • caversmom Jul 05, 2008
    Sorry, I don't have a way to test the power supply. It will power up, I discovered yesterday, and work after being unplugged for a couple of days, but this morning, I tried to power it on and it wouldn't. So, I unplugged it again, and we'll see if it will come back on later. It is plugged into a power strip with other things plugged into it that work.
  • Anonymous Sep 02, 2008
    wont opwer up
  • Anonymous Oct 30, 2008
    I am having the same problem.  It worked two days ago & now won't power on.  And of course my warranty expired already.  I tried moving to different outlets.  Any advise would be appreciated.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is the power supply any good if you test it?
  • Epson Master
  • 2,794 Answers
Some computer stores can test it for you and probably wont charge for it since it takes about five minutes.
Posted on Jul 05, 2008
I have a 42 inch Maxent plasma flat screen. Won't turn on. last use picture came on then faded to black. Now at start up, power comes, then there is a relay click and that's it. The only way to turn green...
You have a problem on the power supply on the main board and on the video converter.
Your unit will not power up unless you isolated the faulty parts on the power supply section.
It is quite technical and not DIY so I've advise you to look for a qualified repair shop.
A series of test will going to perform to trace the defect on the unit.
But first before that check if your unit is under warranty. Avail it because the manufacturer of your tv will fix it for you for free or a little charged only. If warranty is already void then it is much better that you will bring your unit to their qualified service center near you.
You can also call the service center to estimate the cost of the service fee plus parts to have an idea if you will send it to repair or buy a new one....
Pls rate my help...
Thanks for using fixya.
Jan 10, 2011 | Maxent MX-42X1 42 in. Plasma Television
The gps was working fine and took me to my destination. It would not power up to return. The device was purchased less than 1 year. I tried charging it two days. The charge light is green but it will...
Hi Eugene,
The reset hole is located on the bottom center-right of your unit. I suppose you've already tried that, but just in case, try holding down the button for 10-15 seconds. Try it more than once if needed. Make sure external power is connected also.
Since many of these Insignia units came from Best Buy, and may have a one year warranty, try that route for service. If you need the manual for this unit, get it here:
If all else fails, call Insignia at 1-877-467-428. I hope you get it fixed. If I can help further, let me know. Thanks.
Regards, Bill
Sep 17, 2010 | GPS
Samsung SyncMaster 920nw suddenly went black now squeaks/flickers
The 920nw did have a 3 year warranty on the unit but they will be out of warranty now. The flickering power light is an indication of a failure in the power supply board. When the board fails it can't start up correctly and the power shuts down over and over so you get the blinking light and no display. This is a very common failure point on all LCD monitors after a few years of use. There are parts called capacitors on the power supply board and they filter the output power. When they fail the power is not properly regulated and the power supply shuts down and tried to restart so you get the flashing. Here is a link to a repair guide that will show you how to dis-assemble the unit and then what to look for and replace to get it back up and running again.
The repair guide has pictures and videos to guide you through the repair.
I hope this helps, if so please rate my solution.
Nov 14, 2009 | Samsung SyncMaster 920NW Monitor
APC back-ups es500 alarm continuously sounds why we power it off and alarm stops everything works fine then we power it back on and alarms sounds again
It means it has an internal fault. if still under warranty period, just call APC and ask for replacement. if it out of warranty bring it to service center or better if you have to buy a new one because as far as i am concerned repair cost of this unit is much expensive than a new unit
Jun 22, 2009 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
No power at all, checked all outlets and plugs, called for warranty info, OUT OF WARRANTY, service center thinks it may be the power supply box, based upon my description over the phone? Is this a part I...
A replacement Power supply unit is probably available however I have to wonder what caused it to fail in the first place , with most things cause and effect is a main consideration .
whilst this new supply may bring your set back to life I have to wonder for how long ?. Phillips power supplies are noted for being fairly robust and forgiving so this makes me think that you have possibly a bigger problem ?. Should you wish to contact philips direct the company is called Combined Electronic services ,and the european headquarters is in Croydon London .
I should also like to point out that repair of the Power supply by a qualified engineer would probably be far cheaper than replacement and quicker . I hope this is of help to you Regards Vortash
May 13, 2009 | Philips Televison & Video
Will not power up
hi the problem sounds like the unit has overheated this is common problem with ps3 i see alot of these problems all the time sometimes you can be lucky and just replace the power relay transformer inside the ps3 but most the time its the whole board that needs replacing.
The best thing to do is check your warranty and get it repaired this way as getting it repaired would cost as much as a new ps3 also its not a repair you can do yourself as you might need the software reinstalling as after they overheat it usually corrupts the data on it.
How old is the ps3 the only other option you have got is buy a damaged one off an auction site but buy one that lights up but dont come on then you might be able to make one out of the two.
I have been buying ps3 that dont work for next to nothing but i had to buy 8 or 9 before i could get one to work by swapping parts.
Let me know what you want to do check your warranty as this is common fault they might even repair it if warranty has run out it has been known if its common fault
Jan 21, 2008 | Sony PlayStation® 3 (60 GB) Console
Screen frozen on Auto Power Off
Try inserting a pin into the reset buttoon on the back of the unit. Guess what? I called Samsung Help center and Brendon tells me to post the unit back to the service center so the technician can "look" at it!! What a NIT!
Hope it helps...
Sep 28, 2007 | Samsung YP-K3 MP3 Player
Epson Stylus CX5800F All-In-One InkJet Printer Logo
65 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
