Question about HP Photosmart C6180 All-In-One InkJet Printer
Printer toner cartridge won't fit
I got a new color toner cartridge and it will not fit in my HP printer
  • brad923 Sep 08, 2008
    major frustration trying to put ink in this printer. I can't even get the old cartridge back in. The cartridges are right, the manual is in front of me but of no help - - something must have shifted because those cartridges are not going in! The directions say to 'Slide the new print cartridge forward into the empty slot. Then gently push the upper part of the print cartridge forward until it clicks into the socket.'
    It's a laugh because there's no way to get that in 'gently' and then no 'snap' -- i'm going to cry now
After loading a catridge it is showing " no print catridge ". how to solve this problem?
Posted on Jul 06, 2008
I have an HP Color LaserJet 2600n. Recently I had to replace the magenta cartridge. I bought a 3rd-party cartridge and the printer display shows that magenta is now "full." But, it won't...
I guess you should try to reset it ..and get the cartridge out and see if the toner (ink ) is getting out ..by pressing it (with the part where you removed the tape ) on some absorbent paper ..when it is working well it should leave a mark on the paper ..the mark should be not washed ...but real color and all...
If it do not ..just use a syringe and blow air in the cartridge ..just to agitate it ..and make sure it is not dry ..
Insert it back ..repeat the procedure until works ..and also if you have the procedure ..reset it ..
http://www.ehow.com/how_6881778_reset-2600n-toner-chip.html
Aug 09, 2011 | HP Color LaserJet 2600n Printer
HP Color Laser Jet CP1215: won't print at all since magenta is out. I changed printer to grayscale but just keeps blinking the magenta sing and the traiangle with ! sign next to it
I know the frustration being in IT for over 20 years working on various peripherals.
These printer MIX so that way there is a balance at the final phase. You have to purchase a magenta cartridge to get this working again. Bypassing this will make tis printer suffer and long term damage can cause a economical issue on your end in the long run.
Now if your at a critical point you can bypass but I do not professionally recommend this but here it goes.
1. Open the CP1210 Series Toolbox 2. OPEN System Settings 3. Then enable Cartridge Out Override 4. Then click apply
I hope this works for you, whilst you purchase a magenta toner. Please do not forget to leave a positive rating and feedback.
Best of Luck
Rulds2008
Jul 26, 2011 | HP LaserJet CP1215 Color Printer
HP Color Laserjet Cp2025n Printer - driver says it's out of toner and won't print. No true. I put in new toner cartridge last week. How do I get it toreceognize the new toner?
Did you purchase a new OEM HP toner or a refilled or remanufactured toner. It is possible that the chip is bad on the cartridge in which case if it is a true HP cartridge have them replace it. If you purchased 3rd party go after the vendor to replace it.
Jun 28, 2011 | HP Laserjet Cp2025n Printer
Right hand printer cartridge light is flashing - have taken it out and reinserted it, no luck, so put a new one in, still no luck. Only way I can get it to work is to take the right hand cartridge out and...
A Non-HP Toner Cartridge installed error message occurs in the following situations:
  • Non-HP cartridge is installed
  • HP cartridge is not installed correctly
  • False error
  • Sensor issue (hardware)
SOLUTION: The Non-HP Toner Cartridge installed error message could be cleared completing the following steps: All HP toner cartridges carry the Hewlett-Packard logo, and meet HP's high quality standards. 1. Verify that you are using a legitimate HP toner cartridge by going to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage. Click here to go to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl01270) . 2. Remove the toner cartridges, clean the metallic contacts by a dry linen cloth, and then reseat the toner cartridge, and check if the error occurs. To reseat the toner cartridge, see the instructions at the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage. Click here to view the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314345) . 3. If the issue persists, perform a firmware upgrade from the Download drivers and software page at www.hp.com. 4. Restore the factory defaults in order to restore the default settings: a. Use the left arrow or the right arrow button to select Service , and then press SELECT . b. Use the left arrow or the right arrow button to select Restore defaults , and then press SELECT . If the issue still persists, even after completing the troubleshooting steps provided, then use one of the following support options so that HP can work with you to resolve the issue, because it may be related to printer hardware where it needs a live interaction
Oct 26, 2010 | HP Deskjet 460c InkJet Printer
HP color laserjet 1600 wonte printe new toner color.
The supply status report is based on what the kill chip is reporting to the printer. If that particular color is not printing then it is likely that current is not flowing though a particular component in the cartridge. I would return the cartridge and get a replacement.
Feb 02, 2010 | HP Office Equipment & Supplies
How do i install a toner chip on my hp Cp2025
TONER CHIP on CP2025 printer:
This resource may help
http://resources.lasertekservices.com/hp-smart-chips-overriding-this-lockout-mechanism-with-reset-chips/
Gives types of chips to use, sales in USA, and certain things to take note of.
The toner reset chip replaces the original HP ID chip and is designed to be used only on refilled HP cartridges.
It is not recommended to force toner cartridges to run on empty, as this can cause damage to both the printer and the toner cartridge.
The reset chips are dedicated to one color only, so that user can not swap toners.
As for actual physical installation, just push the new ID chip in until it clicks into place. The correctly manufactured ones should be a snug fit.
I have seen techs using a drop of contact glue behind the chip-board to secure it.
Copper pads face outwards towards matching printer pins.
See photo for polarity 'square' pad.
My printer is Samsung, not HP, so your toner cartridge may be a different shape.
Nov 07, 2009 | HP Color LaserJet 2550n printer + HP Color...
I have followed the instructions exactly for replacing the black toner cartridge on my Magicolor 2300 DL, but i still have the error message "Replace Toner Black." I tried taking out the cartridge and...
If you have changed the toner cartridge, the printer must complete a calibration cycle (up to 150 seconds). If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
1. Open the Status Display (double-click on Status Display icon in the system tray on the lower right-hand portion of the task bar, OR click Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA magicolor 2300W Status), and then check which toner color is empty.
2. From the Print menu choose Toner Replace...
3. In the Color list box, select the color of the toner cartridge to be replaced (CYAN, MAGENTA, YELLOW, or BLACK).
4. Select the capacity of the new toner cartridge (1500 or 4500).
5. Click OK.
6. When the toner indicator on the control panel starts flashing, open the printer's front door. The carousel is automatically repositioned so that the appropriate toner cartridge can be removed.
2300-0.gif 7. Insert your thumb and index finger into the two holes in the front of the toner cartridge, and then pull the cartridge straight out about 6" (15 cm).
2300-1.gif8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
2300-2.gif9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each toner cartridge has a colored end that corresponds to a color inside the cartridge slots. Always install the toner cartridge in the slot of the same color.
2300-4.gif11. Support the middle of the cartridge with your left hand, insert the thumb and index finger of your right hand into the two holes in the front of the toner cartridge, and then insert the cartridge so that the guides on the cartridge fit into the rails in the cartridge compartment in the carousel.
2300-5.gif12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The printer must complete a calibration cycle (up to 150 seconds) after any consumable has been replaced. If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
Sep 01, 2009 | Konica Minolta magicolor 2300DL Laser...
Still using color toner when printing in black
Check the black toner cartridge. Most printers that use multiple cartridges will use the black cartridge as long as it has toner in it but will then start using the color toner to do the black/grayscale when the black cartridge is empty.
-Graye-
Nov 21, 2008 | HP LaserJet 2550L Printer
Printer Color problems..
Seriously, buy a new printer. Companies sell toner, not printers! The printer is basically a "freebie" and is a marketing vehicle to sell toner. I tossed my C510 into the dumpster. It had four new toner cartridges. System diagnostics said that everything was at 95% or better. The printer had about 1600 prints on it. The first set of toner cartridges (full at purchase!) printed great. Then, I got dotted lines on clean prints. Or, I would get washed out, yellow tinted print and often, there was no black print. I called a printer repair shop and they laughed and told me to chuck the printer - they were suprised it lasted through the first set of cartridges. Lexmark literally "ignored me to death."
I will NEVER buy another Lexmark. The Brother and HP color lazers are probably the best bet. I have two HP B&W's that are paper pumps - an old 4V and a 6MP. The sad part is that I paid a bit more for the Lexmark than the competing HP. You live and then you learn!
Feb 25, 2008 | Lexmark C510 Laser Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
81 people viewed this question
Ben Johnson
