Question about Lexmark X4270 All-In-One InkJet Printer
Cannot scan Each time I try to scan the program freezes but the computer continues to function fine. I hooked up scanner to my laptop and it works perfectly. I have reinstalled the program and it's still the same. Any Ideas
  • Anonymous Jul 10, 2008
    it will print, fax but will not scan what do I need to do
    Guru:
  • 1,049 Answers
Does specifically the scanning software freeze or is it the application your scanning into? For example....does it freeze if you insert a picture into word using TWAIN as a source?
If it is actually the scanning component that freezes I would look for third party software that might be conflicting with it. Scan using Adaware or Spybot for spyware, remove the Google desktop and Yahoo toolbar applications if installed, and look for other similar programs like the HP picture viewer which tries to pull media from SD cards and cameras and may be similarly trying to access the scanner.
Posted on Jul 23, 2008
Why Symbol LS2208 keyboard wedge not scanning correctly?
Do you have more than one of this model scanner? If so, I would test a different one on the same computer to make sure it is not a computer issue. Be sure to test it in the same USB port to get an accurate test.
Having a second scanner would also allow you to switch out the cable connecting the scanner to the computer. The end of the cable which plugs into the scanner is an RJ45/Ethernet end. You will need a flat head screw driver to push down on the tab to release it from the scanner. Swap the cables and see if the problem follows the cable or the scanner. If it follows the cable, you can replace the cable for cheap. If it follows the scanner, I would plug the scanner into the working computer and reset the scanner to factory default using the Symbol Book of programming barcodes.
Try a different USB port with the original scanner.
You can also reset to factory default if you don't have a second scanner using Symbols book of programming barcodes.
Sep 20, 2014 | Symbol LS2208 Handheld
My computer keeps freezing and I have to shut it down numerous times before it works again. When it continues to work, it freezes after a while and I have to shut it down again.
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reginout
Oct 29, 2010 | Dell Inspiron 1525 Laptop Midnight Blue
HP C5280 all in one prints but does not scan
2 ways to scan from HP printers
First* try from "my computer" ... near the bottom of the page you should see "scanners" in there, try clicking that and follow prompts
Second* go to start/ programs/ HP/ HP Solution Center
all scanning choices should be on the left
Please don' forget to rate me : )
Oct 01, 2009 | HP Photosmart C5280 InkJet Printer
HP 2410 prints & copies fine but won't scan.
Well if you are able to copy from your printer,it suggests that the hardware is perfectly fine.Its just an issue with the software.May be you are using an old software that is not compatible with the new operating system of your computer.If this is not the problem then try uninstalling and then reinstalling the software.And mind that when to uninstall the software do it completely from the registry,program files as well as add/remove programs.If you want any further support, an online technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
Jun 18, 2009 | HP PSC 2410 All-In-One InkJet Printer
Fujitsu fi-4120C2 scanner
There are two generally components for a scanner to work, One the Hardware Driver, which connects to the Comp and Two, a program to scan using the hardware connected. Sometimes, both may be available in the same program. For example, after installing the Device Driver, you can use any scanning program, to scan. Hence please check if you have loaded the Device Driver. You may be just using the scanning software, whcih is not able to detect the device!
S. Mohan, Chennai, India
Jan 20, 2009 | Fujitsu ScanPartner fi-4120C2 Path-Through...
Lexmark 1270 scans but will not print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Dec 13, 2008 | Lexmark X1270 All-In-One InkJet Printer
Scanning function doesn't work
If it copies fine, then it IS scanning. If you are trying to scan to your computer then you will need to open the program and follow the instructions.
May 24, 2008 | Dell 924 All-in-One InkJet Printer
Barbie idesign ultimate stylist cards will not scan in
Not sure if this will help as my cards would scan but I was having problems with the game shutting down when we tried to "photograph" her outfits, fashions not transfering to other sections of the game and not saving the cards we had scanned. I'm running windows xp on a new computer and had to change my daughters user account to administrator (from limited). The game is now working brilliantly and is everything it promised to be. Still it's very frustration that I had to spend 3 hours today solving this myself instead of reading a simple 1 liner on the Mattel website FAQ's!!!
Feb 18, 2008 | Computers & Internet
Coolscan 8000 Program Buttons not functioning
Have you changed computers -to say VISTA? Tell us more about your computer
Aug 08, 2007 | Nikon Super Coolscan 8000 ED Film Scanner
Lexmark X4270 All-In-One InkJet Printer Logo
82 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
