Question about LG Flatron F700P 17" CRT Monitor
Opening an LG computer monitor
How do I open an LG LCD computer monitor? Are there tabs somewhere that need to be depressed with a screw driver? Please email me at s_fazl@yahoo.com. Thanks in advance.
I have same problem fcasa@sympatico.ca
Posted on Jan 29, 2009
How i can open my LG flatron w1943sb
In LG w1943sb monitor, screw is not used. .In this type 'press-lock' of cover is used. Did you have opened IR remote control, most remote control also used as this monitor's lock, and you can open with a flat screw driver.
Sep 02, 2011 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Hello, i have a major problem with my lg flatron L1919 S, it doesn't start.one day I started my computer and my monitor didn't start.is it fixable?i think it may have to do with some dust inside,but i...
Plug a spare monitor in the computer to see if works, if it does! the LG monitor has issues and not cost effective to have it repaired. A final thought! make sure the power and video cord are snug tight on both ends of the LG monitor. If the same problem persists in both monitors, the computer has a Video Graphics Card issue.
Jan 07, 2011 | LG Flatron L1750S 17" LCD Monitor
Lcd monitor not starting. dead. how to open the monitor to change the fuse?
More likely to have bad caps like the L1751S: http://s807.photobucket.com/albums/yy352/budm/LG%20L1751S/
Remove all the screws and stand then use flat blade screw driver to crack it open starting at the bottom edge and work you r way around and be careful on any cable attached to the front bezel.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 19, 2010 | LG Flatron L1750S 17" LCD Monitor
How to open a 17" LG L194WT LCD monitor
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L194WT%20&kategoria=&kat2=all
I usually open it at the bottom edge first and work it all the way around using thin flat blade screw driver.
Sep 17, 2010 | LG L194WT 19" LCD Monitor
How is open the monitor
Remove the stand and all the screws on the back, use flat blade screw driver for cracking open the case at te bottom edge of th case, be real careful on the front panel switch assembly wires.
Service manuals:
http://elektrotanya.com/?q=showresult&megnev=lg&megnev2=l1730&kategoria=&kat2=schematics
http://www.badcaps.net
Jun 08, 2010 | LG L1730SF 17" LCD Monitor
How to open the HP 19 inch flat screen monitor
You need to remove the stand first, and then using small flat screw driver to release the four tabs at the bottom edge of the monitor.
I myself never have to replace the power switch on these series yet.
Jun 03, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
LG1917S-BN Access to power supply - Rear cover removing
You need to use flat thin blade screw driver to crack open the case, starting at the bottom edge of the case first, you may need two screw drivers, when it starting to come apart, leave one screw driver in the partially opening section so it not snap back together while you tackle another section of the case. Most monitors cases these day do not have small slot to show where you should crack open the case at, they just do not want you to fix it.
Feb 23, 2010 | LG L1917S-BN 19" LCD Monitor
How do I Open / disassemble LG Flatron
Remove all the screws from the screen that you can, check for screws under all soft objects and labels, after all screws are removed, use a flat screwdriver or a case opener tool to start snapping the display cover open, it is hold in place with plastic clips, these will clip open but be carefull not to break any.
Sep 11, 2009 | LG Flatron L1750S 17" LCD Monitor
Why does my LG flatron 1953T LCD monitor (19') goes white
Because the fuse on scaler PCB is blown. Open the monitor, open metal cover, disconnect all cables coming between display and boards, take the chassis off the display.
On back side of display you will see metal cover, mounted with tiny screws, take them off. Unscrew the board also and carefully tilt it up. Observe tiny chip fuse (referenced F1 or FU1 or something with "F") somewhere nearby the connector, ring it, replace it with solder drop.
Take everything back together.
Dell 1704FPTt 17" TFT LCD Flat
I used to repair LCD monitor from Dell. There are 4 screws for rear panel and no screw for front frame. If there is no visible screw, you have to look for "capped" screw holes (little covers that fit flush with the case to hide the screws). If you don't see these neither, this must be a tension fit case. So, face the screen up and look for "rectangular hole" on the side edge (usually at the bottom edge of the screen). This will be a challenge to open without breaking it. You'll need a very thin flat screw driver and wedge it into that narrow rectangular hole. You can use any prybar if you don't have screw driver. It is not too deep. You may stab something important inside and pry it. Once it starts to spread, start sliding it along the seem and you should feel the tension tabs start "popping" open. Continue to work your way around until it's off. Hope this will help you to get the rear panel off. If there is anything I can help you with, feel free to let me know.
Thank you,
Mar 02, 2008 | Dell 1704FPTt 17" TFT LCD Flat Panel...
LG Flatron F700P 17" CRT Monitor Logo
691 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
