Question about Dewalt DC011 AM/FM Radio
Does not accept power from mains & does not charge ... only stereo works from battery. My only guess is that the charger assembly may need to be replaced. Is there anything I can do to fix this without complete replacement or test this myself without professional assistance?
  • triscuit Jul 06, 2008
    I'm not hearing anything when plugged in.
    I have only located one fuse. Where are the two located?
    Thx!
    Champion:
  • 313 Answers
When you plug it in to ac volt did you hear any single click sound from the radio?. if no it could be just the fuse problem only. remimder radio has 2 fuses 1 for ac & 1 fuse for dc operation..fuse rating not the same.
Posted on Jul 06, 2008
  • mr aicnelav Jul 07, 2008
    if you open front cover the board on the left side is for ac.where the ac cord are connected. the other one is located at the board where you insert the battery back side of the board. fuse rating 2A & 3Amps read the fuse rating.if the 2 fuse are ok then the problem is the board.see www.toolpartsdirect.com for parts & diagram. select dewalt & type in model #. thanx & good luck
Lenova tab s8 wont charge help
Hi, it maybe possibly your battery to drained flattened to the point where it cannot accept a charge from the wall charger. the best thing to do is to try and trickle charge your tablet from a low voltage/amperage connection. Either a powered on PC USB port to the charging connector on your tablet, or from a low power phone charger (5v/500ma). It has been pretty well documented that lithium batteries do not like to be drained fully & it may be that the battery in your tablet has drained so low that it cannot accept a charge from the Lenovo a/c charger.
Try a trickle charge for 8-10 hours (or longer) on your tablet & see if that gets enough charge into your battery to enable it to recognise & accept a charge from the a/c charger.
Else it replacement of charger or some hardware failure in your tablet
Oct 04, 2015 | Computers & Internet
Is charger not working?
If you have a DC voltmeter and can see the contacts in the charger, you may be able to see it the charger has a output. But with the newer electronics for battery charging, the battery may need to be in the charger to get a reading. My guess is you do have a bad charger.
Jul 26, 2015 | Dyson DC44 Animal Digital Slim Cordless...
Battery indicates being charged but is not being charged.Is this an indication that battery is in need of replacement
if the screen is showing that the battery condition is charging then power is getting to the battery
whether the battery is accepting charge or not would depend on the battery condition
if the charge light is on the charger ,it indicates that the charger is working but not necessarily supplying a charge to the battery
I suggest that you take the phone and the charger to a shop that specialises in batteries and have them both checked out
Jun 27, 2015 | Nokia E Cell Phones
Laptop will not accept a charge
replace the battery, perhaps you are using the wrong charger, or even charging for too long.
Apr 02, 2014 | Gateway MD2614u Notebook
Batteries for Renegade power wheel chair won't charge
if the batteries are OLD they are quite possibly totally dead and need replaced
Apr 10, 2017 | Health & Beauty
WENT YOU PUT THE MAINS IN THE NEEDLE ON THE PAD SAID IT FULY CHARGE BUT THERE IS KNOW POWER LIGTH AND THE DC AMPERES IS NOT WORKING. CAN YOU LET ME KNOW IF IT THE BATTERYS. ARE IF YOU THINK IT MAY-BE...
Hi, if the meter is not showing a charge , it could be a number of problems, firstly make sure the lead from the charger pot is connecting okay to the batteries, you will need to remove the whole footplate to expose this, now having done that and convinced yourself that's okay , are you sure the charger working okay ?,,,, the last thing being the batteries will not accept a charge...sadly...the needle in the meter could be stuck,, is the scooter running okay and giving the impression the batteries are fully charged ? regards gewiz please rate this...
Sep 01, 2011 | Pride Sonic 3 Wheel Portable Scooter
I turn rocker switch on with one battery I show full, plug in a different battery, turn on rocker switch get nothing, both batteries show a full charge on charger. I think one battery is 3 years old other...
Hello
Check the following:
* Circuit breaker on main control box is tripped
* Fuse blown (check fuse in main control box assembly).
* Incorrect polarity at battery terminals
* Dead batteries.
* Charging cable is still connected to charging receptacle
* One of the cable connections at the main control box is loose.
* Control connection cable disconnected
* Broken key switch
* Throttle stuck fully open
* Throttle control potentiometer broken.
* Speed potentiometer broken
* Battery voltage too low.
* Faulty charging cable.
* Charger not working.
* Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary
* If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Aug 22, 2011 | Shoprider SL73 Echo 3 Wheel Scooter ()
Dell inspiron 1300 wont work from the AC adapter
Is the laptop working without the battery, directly on AC. Have you tried using another charger or battery to see if its charging.
Jan 28, 2009 | Dell Inspiron 1300 Notebook
Charging Problems with FUJITSU SIEMENS AMILO PRO V2055
SOunds to me like the charge board inside the laptop has gone bad. If it will not run off of the mains supply without the battery and will not charge the battery, this is your problem. AS far as where you can get the parts or have it repaired. I am unsure of because I would need the full model and make of the laptop which didn't fit in the listing title bar above If you could send me more info, I would be glad to try to help.
Dec 30, 2008 | Computers & Internet
My Vector Vec157 Flashlight won't Charge...
It is the battery, I have a similiar Vector light for a few years and tried re-charging the battery but only the little LED light would come on. I have another Vector light, same model and switched batteries from the worjking one to the non-working one and now it works fine.
I then proceeded to purchase a new battery for the non'working one and when I arrived home I installed it and turned on the main light, still won't turn on, I tried the LED's, they work. I figured maybe the new battery needs a good charge so I plugged the charger in and charged the light for 12 hours, still no main light.
I guess the new battery is defective, so now I will return it and exchange it for another one.
Aug 22, 2008 | Vector 20 Million Power Series Spotlight
Dewalt DC011 AM/FM Radio Logo
608 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
