Question about GE (PSS26MSRSS) Side by Side Refrigerator
Low flow on ge profile side by side water dispenser
Why does it take so long to fill a glass with water from the dispenser? is there a way to boost the water pressure?
  • aaladd Jul 16, 2008
    I have the same problem with m water dispenser - the flow has been getting weaker every day, and now it's almost nothing. If I pull the filter out and then put it back in, I get a good burst of water, but only for a second, then it goes back to almost nothing. The filter is fairly new - could it be clogged, or is the problem elsewhere? If it is a clog, how do I find and fix it?
  • 481 Answers
  • the water filter may be clogged (if equipped)
  • or it could be the screen in the water valve clogged a little.
  • or the water supply line could be clogged if it has a needle piercing water valve.
Posted on Jul 04, 2008
The water dispenser on our GE side by side Profile refrigerator is not working. When we press a glass against the pad water goes out onto the floor. The water will also not fill the ice maker. Please help....
Solonoid assembly probably went bad. Can purchase part and install yourself if you are somewhat mechanically inclined. Same part functions for both ice and water. Good appliance repair shop should have or be able to order the part
Nov 05, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Our GE Profile side by side refrigerator is making hollow ice cubes and the water dispenser comes on by itself sporadically for about 3 seconds a few times a day. Over night it filled a whole glass of...
Hello. Hollow cubes is caused when there is not enough water going into the ice cube molds. That said, since you have too much water going into the water dispenser I would suspect that the valve needs to be cleaned or possibly replaced. Joe
Mar 27, 2010 | GE Profile¿ Arctica® Energy...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water from dispenser very slow
You could have a piched H2O line somewhere near where the door connects at the bottom front corner or a bad water valve could be the issue. There should be a water container in the rear of the inside of the fresh food side that stores water. Make sure its not leaking or has any obstructions to it or the lines to and from it.
Sep 21, 2009 | GE Profile Stainless Bottom-Freezer...
Low water flow after changing the water filter in a gf profile re
Just a suggestion, you could try installing a filter on the water supply line to the fridge. A nice one should dramatically lessen the frequency of replacing the one in the fridge. As for your the pressure being low, look for a kink or pinch in the water supply line.
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Jun 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
434 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
