Question about Remington Polesaw Wizard
Remington Pole Saw
I have a Remington electric pole saw and the switch has gone bad. The Model# on the pole os RPS96. Can you help me find a switch for it. Otherwise the saw works great as I attach a cord directly to the saw, however the saw is running continuously.
  • Anonymous Nov 10, 2008
    Chain Gear
  • mg_brown90 Jan 23, 2009
    I also have a remington pole saw that has hardly been useed and yet the switch on the pole will not work. Where can I get another switch?
LOOK UP ( PARTS FOR.COM ) FOR THE TRIGGER SWITCH
Posted on Oct 08, 2010
  • 41 Answers
From looking at the breakdown, it looks there are replacement parts for the chainsaw but no replacement parts are listed for the pole . The switch on the pole is what I need. I wonder if the switch on the saw would work on the handle?
Posted on Jul 15, 2008
Need manual of a remington pole chain saw model 108526-01
I input 108526 and got the following (your model not on cover of OM).
OM
http://shoppingcart.msservicecompany.com/msservice_net/product_files/RPS96/RPS96_OM.pdf
IPL
http://shoppingcart.msservicecompany.com/msservice_net/product_files/RPS96/RPS96_BD.pdf
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 04, 2010 | Remington Electric Pole Saw
Conector from pole saw to chain saw
You provide no model number, my results may not apply to your saw,
I went here:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Typed "RPS96" into the "Model #:" window, then clicked search.
  • Clicked the RPS96 - 8 Ft. Electric Telescoping Pole Saw "View Model" link.
  • Clicked "View Illustrated Parts Breakdown" I think you want item 7, 107551-01, Pole Saw Assembly
  • Clear the "Model #:" window; type “107551-10” (coupling nut) in the “Search for your parts by Part #:” window and click search. NLA (Internet search for “Remington 107551-01 also NLA at every site that lists it.)
  • There is also a part number "111304-01" (thumb latch) depending on the pole you have installed. It is NLA at Remington but appears to be available at "Master parts"
http://www.masterparts.net/Merchant2/merchant.mvc?Screen=PROD&Store_Code=MPD&Product_Code=111304-01
Part #: 111304-01 Price: $9.60
Description: SPECIALTY PARTS: *KIT, BRACKET (DSSP-SH3) (REM-17)
If this is also NLA, try an Internet search for "Remington YourPartNumber". eBay may be your only source.
RemingtonPower has stopped production, Replacement parts are mostly exhausted. Eventually every part will be NLA.
I worked fairly hard to provide this answer. It is a very thorough answer and it is not fair to punish me if you are unhappy with Remington. Good Luck HTH
Lou
Feb 13, 2010 | Remington Polesaw Wizard
I have a remington pole saw #108526-01 with a torn oil cap. Can I replace it?
Remington.com
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
107512-01 is the part number $4.72
RemiongtonPower is no longer in production and eventually eBay will be your only source for parts. HTH
Lou
Feb 08, 2010 | Remington Electric Pole Saw
Where can I find a bar & chain for a remington
You provide no model number for your saw. What is pictured is a RPS96.
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" (RPS96) into the "Model #:" window, then click search.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
There are 8, 10, 12 and 14" chains on the IPB depending on the actual model pole saw. RemingtonPower is no longer in production, and parts are often difficuilt to find. All 4 chains listed are available and range form $12.92 to 15.95 plus shipping and handling. You can take your saw (or just the chain) to a local saw outlet and have one fabricated in about 5 minutes. It is rarely more expensive at a local outlete and you save shipping and handling fees. HTH
Lou
Jan 25, 2010 | Remington Polesaw Wizard
Remington pole saw
Problem is most likely in the trigger switch on pole. Bypass switch and test bu plugging lamp into power cord coming from pole
Jan 07, 2010 | Remington Electric Pole Saw
What is the part that you need to secure the electric pole saw to the pole? I know it is a black plastic piece that I have lost. Please advise.
An IPL for 3 different types of Remington Pole Saws can be found here:
RemingtonPower has ceased production. Parts availability is limited to what is on hand.
If these aren't your saw provide the correct model number and we'll try again. HTH
Lou
Oct 18, 2009 | Remington Polesaw Wizard
Pole Saw RPS96 - - Saw 108526-01 - - The outer clamp/nut that holds the pole at the selected length has split. I guess I could use a clamp to secure it, but I'd like to replace with the correct part. Can...
Your pole saw is at the bolttom of the page here:
http://www.desaparts.com/remington-chainsaw.html
The parts list that appears is a chainsaw. Please phone them @ 1-800-475-5660, ask for assistance and explain this little glitch. Thanks HTH
Lou
Oct 03, 2009 | Remington Electric Pole Saw
I need an oil cap for my pole saw 108526-01
An IPL (exploded parts list) for your pole saw can be found here: (I recommend you save a copy)
Page 2 Item 8 pn 107512-01 $3.98
Can be ordered here:
The model you provided enabled me to fully answer your question. Atta boy/girl. Thanks
Lou
Sep 29, 2009 | Remington Electric Pole Saw
Does my remington chain saw model #m15014AS go with the remington ext.pole model #rps96
No, the largest electric pole chain saw that can be attached to a pole with the Remington Pole Saw kit, is a 10" saw.
You can go to Master Distributors to find out more detailed info about your situation and speak with one of their reps.
http://www.remingtonchainsaw.com/
Hope you found this very helpful, best regards!
Aug 07, 2009 | Remington Electric Chain Saw
Need locking latch for Remington Electric Chain saw
You've got the one version of the Remington Pole Chain saws that doesn't have a separate parts breakdown online.
However, here's a owners manual for your pole saw and a parts breakdown that can be used for most replacement parts, as the RPS-96 is a similar version of your model.
You might want to contact the factory to verify that the parts are the right ones before ordering them by calling 1-866-672-6040
Hope you find this very helpful and best regards!
Aug 07, 2009 | Garden
Remington Polesaw Wizard Logo
3,135 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
