If what you say is that all functions are working (start, speed up , down and incline up,down) then the upper console lighting may have loose wire harness( check first) bad soldier connection or the components that generate the images on the LCD are defective. If you have good connections on the wire harness then you may need to replace the upper console.
Yes that does have and ethernet port, (1) LAN (RJ45) the (1) means one and RJ45 is the type of ethernet port.
Floppy disks aren't available in the new computers, no one uses them anyway due to USB's and external hard drives etc.
most nokia phones have the lcd screwed against the board and they are connected by a little grey sponge thingy that presses against it and is right behind the lcd.
if the lcd is doing weird stuff like dissapearing half or fading out and in this connector is your problem sometimes taking it out cleaning it a bit or turning it around helps.
Its an LCD problem. if you have the means to take the phone apart, carefully remove the LCD assembly and clean its contacts and the circuit board pads. If its still the same, only a replacement can solve it.
