I have a SHARP VCR model # V C H818 and I am trying to get it to record from sattelitte-- why can't I get it to work ?
Thanks for your reply-- I still haven't got the problem fixed-- but I feel that if I have to pay for advice-- I will pay it to some oen that can come here to fix the problem.
Dizzylizz
Posted on Jul 05, 2008
I need instruction to set recording for sharp h952 vcr
You need remote to get menu to set the clock then go to timed recording setting. Then you load a new tape, then shut down the vcr and wait for the timer to start the vcr and recording for you.
If you need a manual, google for sharp vcr manual download free from sharp website.
Aug 26, 2010 | Sharp VC-H952U VHS VCR
Does my Sharp DV-RW34OU dvd recorder+vcr have microphone capability? If so can I purchase a compatible microphone online?
Ur Sharp DVD Recorder/VCR combo have any HDMI ports.Yes,Tries websites like Amazon.com,Ebay.com to buy a Digital microphone use the HDMI port it work fine.No tries researches buy the analog microphone.Just ask the vendors info.for the device functionable or compatible to ur device.
Jul 03, 2010 | Sharp DV-RW340U DVD Recorder/VCR
Adding VCR to Samsung LN40B630NIF so I can record programs.
No.
You can not recording on any VCR from a digital TV.
Nov 08, 2017 | Sharp VC-A410U VCR
Need to connect a sharp VCR Model NO VC AA350 to the computer
No Problems Melanie
Get hold of a stero 3.5mm (1/4inch) plug to 2x RCA plug lead of how ever long you need (2m is good)
The sharp VCR will have 6 jacks or maybe just 4 if it isn't a stereo vcr.
Now do you want to record into the vcr or into the computer?
your pc will have at least 2x 3.5mm sockets, one will be line in, and the other will be line out- this one may already have your speakers connected. (don't use the mic socket)
the sharp vcr will have an i and an out- you are only interested in the red and white RCA Sockets.
So the device you wish to record TO is the line in! and the other device is the line out!
TIP change the channel to AV1 on the Sharp to get it to work, and you may also need to setup Line in volume on your PC's mixer- it may not be selected.
Jan 17, 2010 | Sharp Multi-System Mini Component System...
Record from tv or vcr
Go to
http://www.retrevo.com/support/Sharp-VL-AH150U-Camcorders-manual/id/201dj688/t/2/
the VL-AH150U manual should be very close to the VL-AH-151U.
Let me know if this works for you or we can try something else. Thanks.
Apr 26, 2009 | Sharp Viewcam VL-AH151U Camcorder
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Jan 20, 2009 | Sharp Aquos LC-32D40U Television
Sharp vcr problem
The way to connect them is as follows:
1. Connect the cable from the wall to the cable input on the cable box.
2. Connect the cable box RF output to VCR RF input (VCR must be on channel 3).
3. Connect the RF output from the VCR to the RF input on your TV (TV must be on channel 3).
After all the connections are done, leave the VCR and TV on channel 3 and use the cable box to select the channel you want to record programs from.
Good Luck.
Jul 10, 2008 | Sharp VC-A410U VCR
SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Jun 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Disc error
I have this same problem so I called Sharp.  This model is  a little older.  When you buy the disks there is a number with an X after it.  If you buy the - R disk the number has to be 4X or less,  for the -RW it has to 2X or less.  Apparently they can still be bought at Office Depot or online.
Aug 11, 2007 | Sharp DV-RW340U DVD Recorder/VCR
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
