The power button wires in a computer that was given to me were pulled out were do the plug in to the mother board?
    Problem Solver:
  • 15 Answers
Well find out the mother board make and model it should be imprinted on it some where flat probably in the center then look that up on the internet and find the manual. There it will describe the location on the board and which pins specifically. It will probably be on the bottom half of the board or the opposite side of the heat sink and RAM. The pins are pretty small and grouped in rectangles but once you have the manual for the board it shouldn't be that hard. If you still have the broken wire attatched to the pins though you could just take off the old wire and put on the new one.
good luck.
Posted on Jul 04, 2008
    Guru:
  • 1,342 Answers
Look for letters on the motherboard that match the markings on the wires. Like PW or PS for the power light, etc.....
Power button not working. computer won't turn on. I got a light on, on the mother board but computer won't turn on
This is usually caused by either a faulty power supply or a dirty switch. You can find out if it's the switch by pulling the wires off the motherboard where the power switch plugs in, and with the power supply plugged in, carefully short across the two pins. If the computer doesn't start, that rules out the power switch. The other likely culprit is the power supply. If you can get ahold of a different power supply, try hooking it up and power up the computer. If that daesn't work, chances are that your motherboard is shot. Good luck.
Apr 13, 2010 | Computers & Internet
I press the power button at the front of the tower and it doesn't activate the PC power.
The most common reasons for this are: 1. Switch failure (the button is broken) 2. Power Supply not working
If you can go inside the case of your PC (if confident that you won't mess up with any other thing).
First of all remove all power cords (even the monitor's wire) open up your case again if confident but its better if you get it checked by a technician. By the way to check the switch the method is given below (i expect that you have a reset button)
There must be a wire on which PWR would be written it will be directly connected to the mother board. To get to it look for the button inside the case and follow the wire, when you find the wire carefully take it out and carefully search for the wire of the reset button and connect the reset wire in the place where the power wire was connected.
Plug in all the wires back again cautiously and then press the reset button and check whether now it turns on or not.
If the above method works it means you have a faulty power button and if not then you have either a power supply problem or In some extreme cases the mother board can be burnt.
Mar 25, 2010 | HP Pavilion a620n (PC028A) PC Desktop
Power button on emachine t3882 have come loose
look on the mother board,, with it on its side,, power button facing you.. On the Mobo look at the bottom left were all the other small plugs are. that come out of the face of the computer.. it should be marked PWB or SW
Mar 01, 2010 | E-Machines eMachines Desktop PC
Hello, first of all I need know where the serial number for an iwill motherboard is usually located. and my main problem is when i plug the pc in i get a power light but nothing happens when i press the...
Serial nos of mother board is located in near the ram slot.
Check the ON button if your pc not ON.
check where the jack pin of power button is inserted in motherboard pull it out and short that both pin using wire(touch ones), if again computer not ON then check your SMPS power supply, if again PC not ON then it means your motherboard need repairs no matter the light is ON or NOT.
if u get power light then wire formula will work. Good Luck
Nov 25, 2009 | Iwill Computers & Internet
Lost book on mother board and i accidently pulled the case wires from the mother board. need to reattach in order for the mother board to have power and thus the computer to power up.. need to see...
Hi there.
Get a strong flashlight and a magnifying glass (if you have one). On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW. On some boards there are no colours but the markings are the same, so a good close look.
Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Good luck and thanks for choosing FixYa!!
Jun 11, 2009 | EliteGroup ECS L4VXA2 (CDL4VXA2)...
Where to plug power button into mother board
Open the case of the server, and look on the side panel that you removed. It should have all of the server options detailed right on the inside of the case for you.
May 22, 2009 | Dell PowerEdge 2500 Server
Replaced mother board, forgot where power switch plugs into
you can look for the power switch terminal by its label.like PW for power button and PLED for power led.reset is RS.
May 20, 2009 | E-Machines eMachines Desktop PC
The wiring config for the power hd led, power button etc
You must specfy which mother boar you are using. I could tell you in a better way. Anyway, visit the manufecturer's website and download the user's manual from support or download section. Usually such information is given in the users manuals. (ehteshamhusain@gmail.com)
Apr 21, 2009 | Computers & Internet
Dell Dimension 8300 wouldn't start
Sounds like a power supply. You are getting the standby voltage and not the switched. plug all your wires in except the big 20 or 24 pin motherboard connector, take a small wire and short the green (PSU_ON) to black (ground) wires. This will simulate the computers "ON" signal. The fans should all spin up and your plugged in accessories should work, which means bad motherboard, if not bad power supply.
Mar 24, 2009 | Dell Dimension 8300 PC Desktop
Red light and monitor will not start up
you need to shut down the computer and pull the power cord off powersupply then remove the wire harness that goes on to the mother board then press the and hold the computer on button for 3 seconds then plug in the the harness back on the mother board and and plug in all power cords then try to turn on the computer it should give u a beep or the monitor should go from orange to green good luck e-mail me if u want tbirdfan1@yahoo.com
Aug 07, 2008 | Intel Motherboard
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
