read your user manual as it could be a suds saver operation meaning that the machine pumps water back from a washing tub to conserve water when washing
Is it SUE or SUD code?
Sud
SUDS LOCK (Overdose of detergent detected during the wash cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check / Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
to much detergent,sud is for suds.try running the washer with nothing but water,after 5 minutes drain out the water to get the suds out.are you using H.E. detergent and if so it should only be like 1/4 of a cup,any more can damage the machine,the extra detergent can damage the spider gear in the washer.
Check for clogging in your drain hose, block inthe ddrain valve/ drain pump and foremost the voltage to the drain pump must be present when the machine program is reached.
If not the controller can be defective.
The SUDS message relates to overdose of detergent detected during the Wash Cycle.
This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds.
If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
