Question about Kirby Generation 3 Bagged Upright Vacuum
Floor Attachment I took off my floor attachment, but now the belt seems to be off and I can't seem to get it back on right. I can't use the attachment and I don't know why it's so hard to figure this out. They say, just turn it to belt off, but when i turn it it lift's it up and can't line up with the belt off label. Then, when I turn it the other way, it's off. So I've been trying to pull it off so when it lines up with belt off, it's off. But the I turn it the other way and it's still off and not catching the belt. This is really annoying but I'm sure it's simple. Please help, I have cats and need my vacuum to work again.
    Problem Solver:
  • 7 Answers
Try this,
With the floor nozzle off the machine spin the belt lifter around until the red arrows match. If you look at the side that attaches to the vacuum you should be able to see the belt up on the hook. If is not on the hook offf the machine you will never get the belt on. Once the belt is on the hook attach the floor nozzle to the front of the machine. At this point you need to spin the belt lifter back to where the green arrows match. Oh and another suggestion make sure your hieght adjuster the pedals with arrows are all the way up. Hopefully that helps you out.
Posted on Aug 23, 2008
  • 357 Answers
My Dyson DC14 Animal brush stopped spinning after I cleaned out the hair on the brush. I took everything apart thinking something got stuck, and nothing was found. I took off the grey floor attachment and...
I'm sorry to hear you're having difficulties with your DC14. If you haven't already got in contact with us directly, I'd encourage you to do so. One of our experts will be happy to run through some troubleshooting over the phone with you to identify the cause of the issue you're experiencing, and will be able to recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Sep 04, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Cannot remove attachment from proteam super quarter vac
Greetings, The ProTeam backpacks us a 1.5" hose and attachments. The way that the floor tool is removed is by unscrewing the collar of the attachment. Simply turn counter clockwise on the the part of the attachment that is secured to the wand and doesn't rotate. This should loosen the floor attachment, and you may then pull it off. The other floor attachment can be fitted, and then screwed on by rotating the opposite way, clockwise which will secure the attachment to the wand. I really hope that this information was helpful to you. If you ever need parts or supplies for your ProTeam, please be sure to check out GoVacuum dot com. If this was helpful to you, please rate the repair as helpful by clicking the 4 Thumbs up icons in the top part of the repair. Thank you very much, Chris J. GoVacuum
Mar 23, 2010 | Vacuums
I have a Harmony vacuum and need it only for bare floors. The attachment I have seems to be too rough on the floors. I just need a simple attachment with soft bristles for a bare floor that will fit this...
Take the lower portion of your wand to a vac shop and ask for a universal fit wide floor brush with NATURAL bristle. The soft bristle is much better quality and will clean deeper into grooves in your wood floor or and tiled area.
Dec 26, 2009 | Electrolux Harmony Canister Vacuum -...
Vacuum doesn't vaccum!
Sounds like there is a clog near where the hose conects to the lower brush part.. Try to look up in there.. Under the brush there should be an opening that goes into the hose.. There might be a clog there..
Jul 08, 2009 | Bissell Upright Vacuum - The Pet Hair...
Floor attachment does not suction, no clog in the hose, hand held works when dettached from floor attachment
Have you checked the floor head? Use a pipe cleaner or twisted metal to carefully and gently see what's in there. It sounds like dirt or something has definately sealed up the main suction channel.
May 07, 2009 | Vacuums
No suction in floor attachment *& brush not turning
Lay the machine on the floor with the front side down. Undo the 3 large plastic screws with a coin of some sort, then remove bottom panel. On the back of carrage where the roller bar sits their should be a clear plastic tube check this tube is free of dirt. Check around inside the carrage for hair string etc. Check belt for breaks and swelling in the rubber pull ont roller bar and check the end caps on the roller can spin freely. If not pull off the end caps these will be very tight and wash out all dirt and fluff, dry thourley and lubricate centre pin and end caps inside the roller with baby oil or wd-40. replace roller bar and belt, turn roller bar twice slowly to centralise the belt, replace bottom panel making sure that the clips on front are sitting in their holes. fastern the plastic screws and leave two hours before usage
Oct 17, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Kirby G6 attaching fluffer brush on shampooer
Sure can,
You have two choices,
1.) To use your shampoo attachment, you'll need the fluffer shield, To set up the attachment seperate the tray assembly (the part that holds the roller brush) from the nozzle assembly (the part that attaches to the machine). Now seperate the roller brush from the tray (easiest way is to pull the belt). Insert the roller brush into the fluffer shield (it only goes one way). Insert the fluffer shield with the roller brush installed into the nozzle assembly the plastic shield will be faced towards the front of the machine. Turn belt lifter to where the red arrows match and attach to the front of the machine. Turn belt lifter to where the green arrows match and you should be in business.
2.) Your using the floor buffing attachment it the easiest method just put on like the floor nozzle (thing you vacuum with).
Jul 21, 2008 | Kirby G6 Bagged Upright Vacuum
Dispensing problem w/attachment and maybe floor partion
The F5914 has a hose that must be attached to the pump when using the upholstry attachment. Make sure that the solution hose is pushed onto the pump valve all the way. Try pushing the hose down and then pushing the locking collar down to secure it. This will insure that the hose is fully engaged.
Jan 21, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Kirby Generation 3 Bagged Upright Vacuum Logo
52 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
