Question about Averatec 3500T60 Tablet PC
The Pen On my 3500, the pen doesn't work. Nothing happens when it touches the screen. I already changed it to different setting and it still doesn't work. Could it be broken, if so, Can I replace it with another pen?
    President:
  • 2,976 Answers
I have the same model. The pen has a 'AAAA" battery in it. Make sure the replacement is put in properly. You must calibrate the pen, in the pen settings area of the control panel. The 3500 is not a touch screen computer, Only the proper pen will work. I heven't found an application that will allow erasing with the back end of the pen though.
Posted on Feb 21, 2009
Thers a aaaa (quad-a) battery in pen, also`be sure your using xp tablet edition
Posted on Aug 05, 2008
  • Averatec Master
  • 13,433 Answers
I'm not familiar with your laptop but judging from all the pdas I've had with touch screens the pen itself is only a pen, you could basicly use a wooden stick to poke at the screen and it shouldn't make a difference to the computer.
this laptop has a touchscreen If I'm not mistaken and you should be able to use it even with your fingers.
You might have a faulty touchscreen or then you need to install a driver for the screen?
Posted on Jul 05, 2008
I have a Toshiba tablet M780-s7230 and i tried reinstalling the touch screen driver and my tablet pen and touch screen still don't work what else could i do?
Have you turned on the Touch feature on Windows 7 yet? That could be the reason why your touch screen feature is not working.
To turn it on please follow this:
1. Open your Start menu and type "Touch" into the search bar. This will show a variety of options, including the "Pen and Touch" options. Double-click it to open the "Pen and Touch" window.
2. Check the boxes next to the "Use your finger as an input device" and, if preferred, check the "Enable multi-touch gestures and inking" box as well.
3. Click "Apply" to set the options and click "OK" to exit the window.
Hope this helps!
Apr 10, 2011 | Toshiba Portege M780-S7230 Tablet PC
Something happened to where when i use the pen there is this area on the screen that will not allow the pen to touch that area of the screen or go near it, it just skips it, why?
This seems to be a common problem with this Toshiba. I squeeze the molding around the screen near the areas that the touch screen is not working. It usually happends in long blocks that don't respond to the pen.Press along the top sides and bottom running along all the edges with pressure. You may have to work with it a few times but it seems the fix mine for a while.. hope this helps
Oct 02, 2010 | Toshiba Portege 3500 Tablet PC
My slate vision tablet pc is having some problems. The screen is not reacting when the pen touches the screen. I went into the control panel seems that everything set up correctly. Could it be the pen that...
Your tablet pc uses the Wacom Digitizer so the pen does not use a battery. It is possible that it could be the pen or the screen. It works with electromagnetic resonance technology and the screen produces this signal that the pen grabs, converts, and returns to the screen without batteries. The pen does contain compenents that can fail but so does the screen. You could try buying a replacement pen for around $20 dollars and see if that works. Worst case you would be out $20. If you had another tablet PC that uses a Wacom screen you could try the pen with that one or test the other pen with yours.
Sep 28, 2009 | FIC SlateVision Tablet PC
My pen for my computer won't work
I think the pen has gone bad on you, since your screen can still detect your hand and the track pad. I would think the pen is faulty. Try another pen cause I think your original is bad, if it was the touch feature that wasn't working I would say its a driver problem but that feature still works with the exception of the pen. Get another pen.
May 31, 2009 | Dell Latitude XT Laptop Computer Tablet...
Touch Screen not working or Pen?
in my opinon. you should be re instal this touch pad driver.
Mar 09, 2009 | Toshiba Portege 3500 Tablet PC
Fujitsu Stylistic 3500 Pen calibration in XP Tablet Edition
Well there is a few ways to try to fix it first with a usb mouse check that the resolution is at it's native pixel count. This can be found on the manufacture website. If it is already at that resolution ensure that the CIC XPen drivers are installed. Those should have placed a recalibration program in the control panel. If those both fail, try uninstalling the drivers and restarting, then reloading the drivers. Hope this helps! food luck and godspeed!
Jan 11, 2009 | Fujitsu Stylistic 3500 Tablet PC
Pen doesn't work
have u tried re-installing the driver... if thats the case even if u tried different pens it wouldnt work... plus even if ur driver was fine a different pen wouldnt work for that driver... after re-installation if the pen still doesnt work then theres a 50% chance ur pens not working... One more thing does ur monitor support it???
Aug 30, 2008 | Eaton 30311 Tablet PC
Intuos3 Tablet's pen is not working
Try reinstalling the software that came with the tablet.
Dec 29, 2007 | Eaton 30311 Tablet PC
Averatec 3500T60 Tablet PC Logo
502 people viewed this question
Top Averatec Tablets & eReaders Experts
Are you an Averatec Tablet and eReader Expert? Answer questions, earn points and help others
