Question about Ricoh Aficio 450 Copier
The 1224C Ricoh Photocopier keeps on displaying SC571 error message.
  • jdsnsnw May 11, 2010
    What does SC571 refer to? I couldn't get the "107" solution to work--tried as many combinations as I could. I did empty the used toner trays in case that's applicable.
  • Hadley Hudson May 11, 2010
    do you know how to enter service mode?
    Novelist:
  • 158 Answers
Try 'clear', '107', 'start' buttons. If that does not work, try different combinations, but '107 should be correct.
Posted on Jul 06, 2008
Hello i have ricoh aficio 1224c color . but the is have problem error sc792 . please help me best regards Salar
SC 792 :Finisher error .
The machine does not recognize the finisher , but recognizes the relay unit .
Possible causes :Defective connector
defective cable
incorrect installation
Aug 10, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh 1224c Error SC-421 Please help
Hello!
Well, that is not an easy error. Your machine is detecting a short circuite in the discharge plate. It could be just a defective harness between the High voltage supply unit and the BICU.
So... The best advise i can give you is to call your technical support.
Jul 12, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh aficio service code sc571
solution found on copytechnet.com
sc571 on this machine means fuser oil overflow.
check the oil out sensor connector.
use sp5 810 to reset this and most other codes.
Apr 02, 2011 | Office Equipment & Supplies
Please show me how can I unlock the error code SC305 for Photocopier Ricoh Aficio 1224c
This is a Corona cleaning unit error. You either need to get the issue with the corona cleaning unit fixed or have a service technician turn off the automatic cleaning function. SP Mode 2 801 3 (technican will know what this code means) I can not tell you how to do this as you can total mess up the machine if the service mode is not used properly.
Turning off the cleaning will solve the error code. Technician can clean the coronas himself on service calls so automatic cleaning is not required.
Good Luck
Dec 07, 2009 | Ricoh Aficio 2015 Copier
How to clear error code SC571 on Ricoh 1232c copier
See thread I left you this morning on this. I hope it helps.
Press the yellow button. Press the 107 keys. Press and hold the red clear button for a few seconds until the service mode screen appears on the LCD display.
Oct 30, 2008 | Office Equipment & Supplies
Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Jun 18, 2008 | Ricoh Aficio 2015 Copier
Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Jun 18, 2008 | Office Equipment & Supplies
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
Ricoh Aficio 450 Copier Logo
457 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
