Fax only mode will not stay on so it does not pick up
Panasonic compact plain paper fax with copier-model no.KX-FHD332C
    Genius:
  • 3,422 Answers
HI,
Buy a service manual for your model.
It will help you to troubleshoot the problem.
Posted on Jul 04, 2008
Dear sir,good day, during copying two blank(white) column detected on paper .can u help us ?
I do not know your product .any way this two blank lines means :-
1-the charge roller is not clean .
2- the corrona wire is dirty
3-first of all the glasses should be cleaned.
i hope thats help
Jan 13, 2017 | Office Equipment & Supplies
350 Toshiba copier paper is stuck where is the problem
Need mush more information on this problem to assist in any way.
Jan 13, 2017 | Toshiba Office Equipment & Supplies
How does an automatic feeder detect paper
Hello hope everything is okay coming back to your question on how ADF detects the paper is that on top of ADF of the copier or printer there's apart called ADF tray then under that tray there's a sensor which help the machine to sense that there's a document or a paper.
We have a fellowes shredder. It got full and jammed. After cleaning and emptying it will not turn on. Is there a reset button? Thanks. Betn
We've found that when the container is overfilled with shredded paper, it will begin pulling shredded paper back into the cutters and jamming the machine. Sometimes reversing the machine will spit the paper back up, but if it is thoroughly jammed, only way to unjam it is to UNPLUG it first, then manually remove the paper from the cutters. Then, be sure to dump the container BEFORE it is filled with paper.
Jan 12, 2017 | Fellowes Office Equipment & Supplies
How do I replace the pf kit on a brother mfc-9325cw. I have the replacement parts.
Laura, you get the necessary tools, get access and remove the old parts and replace with new ones. Make sense?
Jan 10, 2017 | Brother International Brother MFC-9325CW...
Toshiba estudio 455 Error Code E030
E030 indicates jam error on exit...U need to see where the paper stop and why...
Jul 28, 2015 | Toshiba Office Equipment & Supplies
How do i solve an error e000-0000 canon ir 2202 please
Dear
Its related to the fixing temp. do the error clear on service mode. then check the fixing film assy. heater circuit contact points for corrosion. Replace it.
Thanks.
Dec 12, 2014 | Canon Office Equipment & Supplies
I can't figure out how to feed paper into the printer
hello
i assume you refer to ML591, dot matrix ?
go to this link, and download users guied and/or manual http://my.okidata.com/PP-ML591.nsf?opendatabase
how feed the paper http://my.okidata.com/PP-ML591.nsf?opendatabase
Jan 11, 2011 | Okidata 591 Printer
My fax wont work in my ricoh aficio 1515 mf??
Using the 1515 as a fax machine is a pretty simple procedure if everything works right. All you have to do is hook a working phone line up to the phone jack on the back of the copier (the one labeled LINE, not TEL).
Why won't the fax work? If it is giving you an error message, what is the message?
If you are not getting a dial tone when faxing, unplug the fax from the phone line and plug a working phone in, and see if the phone gets a dial tone. If it doesn't, there is a problem with your phone line.
You can also try plugging the fax machine into another phone line. If the fax works on that line, then there may be a problem with the first line.
Are you having problems sending faxes or receiving them, or both?
Jan 05, 2010 | Office Equipment & Supplies
Paper jams consistely and then continues to feed, even if only printing one page
check your paper size setting on your print menu. i had this problem when i set the paper size smaller than the printer is able to handle (3x5 card) ... i just switched to 4x6 and don't have any problems.
Oct 24, 2008 | OKI C5100n Laser Printer
k24674
