Question about Whirlpool Refrigerators
Ice treys are filling up but not dropping the ice into the bucket
Acme how to.com (Ice maker troubleshooting)
Posted on Jul 05, 2008
1 month old Samsung RF28HFEDTSR. No ice in upper ice compartment. All Ice drops to bucket in freezer section. I press reset button it dings and soon one group of ice falls in upper bucket.
I believe something's wrong with your new ice maker. Are you sure that the ice maker is not turned off on the display? And take a little bit of time and go through your user manual if you don't have the user manual let me know I will send you one
http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/1509233L.pdf
Appliance 911 Sea Breeze
Sep 02, 2016 | Samsung Refrigerators
Why isn't ice maker filling with water?
Water control valve for the ice maker is possibly defective. Fill the ice tray with tap water and if it drops the ice into the ice bucket then replace the water valve. Model number of the refrigerator?
APPLIANCE 911
Jan 27, 2016 | Refrigerators
Not making ice. Have water at fridge?? Please help?
If the ice slots are not filled with ice from the last time water filled the slots then it points to the=> Water Inlet Valve DA97-07827B If you fill the ice slots with water and allow it to freeze it should dump or drop the cubes into the ice bucket. If nothing happens then this points to the=> DA97-07365G Ice Maker Assembly List of=> RF4287HARS Parts I'm here should you have question, Thanks, Sea Breeze
Oct 10, 2015 | Samsung RF4287HARS French Door...
We have a Samsung RF4287HARS french door refrigerator. The ice maker seemed to not be working properly and I tried to pull out the ice bucket and it will not budge. Any suggestions as to why we can't...
I would suggest that the ice bucket has water around the base and that has frozen the bucket bin place . If you can, try filling the bucket with hot water to loosen the ice around the base.
Feb 11, 2015 | Samsung Refrigerators
Water keeps overflowing out of the sump trey continue running
Replace water fill float valve is letting water seep buy during freeze cycle and it will not make ice due to water too warm
Jul 26, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Not making ice!
Try removing it and let the ice thaw. The mechanism for the rake to push out the ice can freeze up.
Apr 30, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
I am not sure this is the right refrig. I have a model 253.78259800 top freezer with a model JD-21 ice maker. The ice bucket keeps filling up with a solid piece of ice. It makes and drops cubes, then water...
there s a adjustment but it only controls /like 1 to 2 oz of water . its prbably the ice mker unit or the water valve . .. ice mker tell water how long to let water in and if valve is bak it might not shop off causing water fill . change water valve first . then ice maker if needed .. icemker might have a bad tray and some cubes do not drop / if so next fill will over fill causing problem . mm
Dec 07, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Kenmore Ice Maker not dropping ice
Sounds like the arm which determines if ice bucket is full is hanging up on something. Does this arm move up and down freely? If not, you just need to replace the complete ice maker.
Nov 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Sub-Zero 632 Ice Maker Leaking into Ice Bucket
Ice Maker is overflowing and leaking into the ice bucket: There are several things to check for.
Go for the easy stuff first, make sure the icemaker is level, some of the plastic liner fridge's will move and allow the icemaker to tilt over and leak. Other troublemakers..... the fill valve
staying on and over filling the icemaker..... the finish sometimes comes off the icemaker body and all the ice cubes don't come out. This will allow the new water to fill on top of an icemaker
that still has a ice cube or two left inside the body, if you have had trouble with black specs in your ice cubes, this may have been the beginning of your finish problem on the icemaker body.
On the module style ice makers (Whirlpool, Maytag Family, Sub Zero) the printed circuit in the
module head often wears and the contacts become too long and allow the icemaker to over fill = new ice maker or new module head.
Older style icemakers: This gear is bad for breaking and the icemaker quits turning to eject the ice.
You can remove the front cover to see the gear.
This is a common parts breakdown of the older style icemakers
Water fill volume: The water fill adjustment screw will change the fill volumes by changing the fill time.
One half to one full turn usually ( approx ) is equal to 20cc ( 0.68oz ) to 40 cc.
The correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
When a water valve is replaced the fill volumes must be re-checked!
http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Aug 15, 2008 | Sub-Zero 632 / S
Refrigerators Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
